Step 2Get Set...
iImage Information
Now, take a pair of scissors and cut sits in the main headphones just below the center padding. Insert the left side of one set of earbuds through the left side slit, then do the same with the right side. Use a piece of colored tape to mark the plug of the earbuds for reference as the Rear Speakers. Now tuck the left earbud under the back side padding of the primary headphones. You can fix them in place later with a hot glue gun or other method, butyou might want to adjust the positioning for maximum effect before doing this. Now, repeat the process on the right side.
Now, do the same with the other set of earbuds, tucking them under the FRONT side of the padding. These will obviously be the Front speakers. Once you've placed these, you're ready to test them out!
