3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY 5.1 Surround Sound Headphones!
If you've got a PC with a soundcard that supports 5.1 surround sound via speaker jacks, then this is for you! An amazingly easy Instructable that gives amazing results.
Step 1Get Ready...
Get Ready...
I found a decent set of over the ears stereo heaphones with padding for $15 at a local outlet store. These will serve as the Subwoofer and Center Channel.
You'll also need two sets of cheap earbuds. One will serve as the Front Speakers, and the other as the Rear Speakers.
Now, before we go on, I will say that I fully realize that there is really no such thing as 5.1 Surround Headphones in the traditional sense of the word. This design does, however, closely match that of the high-end "5.1 Surround" headsets, such as the ones reviewed at http://www.extrememhz.com/ezonics638-p1.shtml .
20 comments
Jan 16, 2008. 10:54 AMDtrainBCca says:
While this is an innovative approach and will MIMIC 5.1.This is truly not 5.1 as the center speaker will only come out of one of the main headphones.A better approach would be to have the center channel in "phantom" mode( simulated between the left and right channels) and to have a small subwoofer under your seat at a low volume and only one set of mini headphones to handle the rears.Without testing this myself I wonder how realistic the spacial effects would be considering the fact that you are basically creating a bi amplified headphone.To get positional audio there has to be some seperation in the speakers or basically your brain thinks its one speaker.Either way this is a good effort and a step in the right direction.Props to babblin.
Aug 26, 2009. 5:02 AMkarossii says:
Actually, there are many (okay, perhaps 'many' is relative - let's go with 'several') retail sets of surround sound headphones that use this same basic principle to create surround sound. Sennheiser is my favorite brand which does this - though I may be biased as I know people in the company. While you are correct that it isn't truly 5.1 audio, who cares? 5.1 is all but outdated anyway, with 7.1 and better systems coming cheap nowadays. The point (in my opinion - I'm not the author so maybe I am wrong) of this 'ible is not 5.1, but surround sound. You are both right and wrong about positional audio. Yes there needs to be some separation, you are correct. However this minuscule amount, when in nearly direct contact with the ear, is plenty. As mentioned previously, several companies market surround sound headphones, and if you haven't tried them... well you have no idea. The distinct quadrants (not really - it is much finer than just a quadrant separation) are amazing. At last year's (2008) CES, I tried a set (made by Sennheiser) which had a demo track in which the main speaker was pacing back and forth in front of you giving his sales pitch, in the middle of which a fly or other insect buzzed behind your head, and you could so distinctly tell where the fly was; above/below your ears, near/far, left/right... my (and everyone else I saw) reaction was to think there really was a fly buzzing around... and I looked for it. Then they went into gaming effects and movie soundtrack effects and it was just crazy. And this was a year and a half ago... these things are out there on the market now. So the moral of the story is, positional audio in a set of headphones is very doable, and I would believe (without having tried this 'ible out yet) that this method may not yield amazing quality as I encountered in those professional headphones, but a heck of a lot better than stereo!
Mar 3, 2008. 8:09 PMdabusff says:
I see what you mean, a subwoofer would be nice to have under the chair. However, I think that he was going for a system that would be entirely headphone mounted, so as not to wake anyone up. Definitely a nice instructable, although my computer only has 2 channels >:( I have a sweet speaker system though, so it's OK. Have you tested this system for low end range? My woofer goes to about 25Hz and still makes a reasonable amount of wall shaking.
Sep 11, 2008. 11:34 AMjosh92176 says:
Hi, I think I have the same laptop as you and I was wondering how you managed to plug all the jacks in as on the laptop there is only one headphone jack and one microphone jack. Did you use an external sound card?
Jan 24, 2008. 2:47 PMClodester says:
Fantastic instructable, and I really want to make this! However, my problem is that my IMB laptop doesnt seem to have enough earphone jacks. So, unless I am mistaken, I cannot make it! :( But yea, great all the same!
Nov 24, 2007. 5:59 AMTwevie says:
I've been wanting to do something like this for awhile, never thought to use earbud headphones though. Thanks for the idea. :D
Nov 25, 2007. 9:06 AMa_d777 says:
Well, this is a nice idea....but, why doesn't some one out there code a USB device/Hardware to accept the 3 outputs in it and then further plug that into the USB port of a computer?
Dec 12, 2007. 5:32 PMYerboogieman says:
thats pretty kool, newegg has always had really nice stuff
Dec 12, 2007. 5:24 PMYerboogieman says:
if you think about it its kind of 4.2, great idea
Nov 18, 2007. 8:16 PMjamnoopers says:
This is genius! Thanks!
Nov 18, 2007. 7:05 PMbarnes says:
I might have to give these a try! Thanks!
Nov 17, 2007. 3:35 PMmintyhippo90 says:
for even clearer sound, try merging this idea with the jack-hammer headphones ive seen a few times on instructables. plenty of room in the headset casing for all the speakers, and lots of sound isolation
Nov 17, 2007. 9:30 AM!Andrew_Modder! says:
cool :-), iv tryed something close to this, every once in a wile, ill wear ear-buds and over ear head phones at the same time. (i put the ear-buds at a lower volume, and headphones higher, so i can hear both, bass from the headphones, and more trebel from the ear-buds) .. ill try this
Nov 17, 2007. 1:29 AMventsi says:
exactly what i needed awesome
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
110
Author:babblin5
