Introduction: DIY 9”x13” Casserole Warmer/Carrier
About: In a valiant attempt to keep myself from dying of boredom, I create.
Last year, I got one of these for Christmas. I had seen it on Pintrest, so it already was on my, “when I can get to it” list. A friend saw it when I delivered a casserole to a funeral dinner recently.  She wants written directions on how to make one as a Christmas gift.  If I am going to write a pattern, I might as well write an Instructable while I am at it.  So here is how to make your own 9”x 13” Casserole Warmer/Carrier.
Step 1:
Supplies:
1 – 12” (30cm) length of double quilted material (got beige color)
2 yards (180cm) of 1” (2.5cm) wide strapping (this is 100% nylon)
10” (25cm) hook and loop fastener (used what I had, pink)
Thread (in a complimentary or contrasting color)
Scissors
Sewing machine
Straight pins
Step 2:
First trim off the excess batting on each edge of the quilted material.
Step 3:
Then pin down the edges that you just trimmed.   Pin down each half of the hook and loop fastener along the same edge
Step 4:
and sewed them in place, being sure to sew down the edges that are not held down held down by the fastener.
Step 5:
Next, I melted each end of the strapping and the zigzagged the ends together to make a circle.  I used a straight pin to determine where the halfway point on the strap was.
Step 6:
Next, I determined where the center of the width of the material and were the center of the length were located, by folding them in half and marking each place with a straight pin.  Do all this on the inside of the carrier.  The straps will be carrying a the weight of the casserole filled dish, so I centered the sewed edges on one center line and then halfway point about 1/3 of the way from the  hook and loop fastener covered edge.  Pin the 2 parts of the strap down from edge to edge of the material and then sew them in place, sewing long each edge of the strap.
Step 7:
The handles need to be on the outside of the carrier, so pin the straps around the edge of the material.
Step 8:
Then fold the material so that the outsides will be inside along with the straps.  Pin the edges together.
Step 9:
Sew a ¼ inch (½ cm) seam down each side.
Step 10:
Go over these edges again, only this time, use zigzag stitches, between the seam and the edge.  Trim away all the extraneous pieces of thread.
Step 11:
Turn the carrier inside out and it is pretty much done.
Step 12:
I put the casserole dish I use most into the carrier to see how it fit.  Wonderful!
Step 13:
Just one more thing to do; personalize it so that it becomes a wonderful Christmas or Wedding or Birthday gift.  I grabbed a metallic permanent marker and wrote the capital letter, of the last name, of the person it will go to.
Step 14:
That looks really nice and it only took about 1 hour of work.  Enjoy!
