DIY AA Battery Holder
15,201
114
12
Published
Introduction: DIY AA Battery Holder
Need a battery holder in a pinch? Make your own with a few bits from your junk drawer.
Step 1: Gather Materials
Adhesive glue squares
Wires
Matchbox
Small scrap of copper sheeting
Step 2:
  1. Strip wires at both ends about 1/4 "
  2. Poke two small holes in the end of the match box and insert the wires, bending to hold
Step 3:
  • Cut the copper sheet in the following sizes
    • 2 @ 3/8" x 3/8"
    • 1 @ 1 1/4" x 3/8"
  • Cut the glue squares so that it just covers the bottom of the copper bit on both 3/8 " pieces and place over the wires to the bottom of the matchbox (make sure that you don't interfere with the copper and wires making contact)
  • Place the larger copper sheet on the opposite end with a glue square
Done! Now wire it to your 3 volt projects as needed!
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Make it Move Contest
    12 Comments
    aluminium foil is almost as good and much cheaper
    Awesome Jugaad ! ;P
    "Jugaad (alternatively Juggaar) is a colloquial Hindi-Urdu word that can mean an innovative fix or a simple work-around"
    Simple and cheap but great build....
    Very interesting!!!
    Great idea to use a match box! Every electrician needs too know this! It's easy and cheap! Great idea!
    I'm sure every electrician know basic electricity.
    Not EVERY electrician, unfortunately. I can name ONE that needs to go back to school. But there are probably rules against my naming him here. More's the pity. I'd actually be doing a public service.
    It is maybe low cost, but for something that cost less than a buck I don't know if would to make such an effort. Even if it was made but 3D printer it also waste of time and money.
    If do you want to upgrade your item?! Make the bettery case from wooden matches, it would be look much more creative than this one.
    I suppose you could attach the wires to the corresponding wires of a solar garden light and use it as a solar battery charger. Thanks for the 'ible. Simple and efficient.
    I like this both as a hack and an instructable. I say this because as a hack it is cheap and effective and as an instructable, it showcases something that is not only cool but can also be easily incorporated into all of my own projects.
    nice and very simple cheap ..can b easily made...
