This project saves money and also might be useful if there aren't any retail stores close to you.
Make sure to check out the DIY Air Hockey Table instructable!
If you've got any remarks or anything else to say, don't hesitate to comment.
Remove these ads by
Signing UpStep 1Requirements
I've tried to make making mallets as easy as possible, with the most common materials. You probably have these materials lying around:
Disc
A piece of plywood which is at least 13cm x 13 cm and is about 2 cm thick.
Handle
A PVC tube with an outer diameter of about 4 cm and a length of about 7 to 8 cm. You can consider the option of using the end of a broomstick, if it has the right diameter. This handle can be a little shorter.
Scratch preventive material
An old piece of circular sandpaper (those with soft backs). You can also use a piece of felt.
TOOLS
-Drill and Hole saw (with an outer diameter of 9.5 and 4 cm)
-Hack saw
-File and some sandpaper
-Close contact glue
nee ik ben niet zo geïntereseert in het
woon in belgië
maar mijn hersen vraagen wel af hoeveel je er aan hept besteet zonder blazer
maar ik vind het wel een geslaagde instructable
