Step 3Drilling holes / preparing playing surface
G: Drill the holes according to the grid you've just created. Use a dremel and drillbits with a diameter of 1mm (or 1/32 inch) to do the drilling. This job is time consuming, but do not rush. Otherwise you'll break a lot of drill bits.
In total we drilled 96x48=4608 holes, breaking 3 drill bits.
H: Use a sanding machine to remove the burrs on the other side of the sheet. This side will become your playing surface. First sand the surface down with rough paper. Then smoothen it further with fine sand paper. Make sure that the holes are free from waste.
How did they get it into the basement?
We demolished it because there was no one else that wanted it. Remember, the kids that had built it initially were now 35 years older!
