DIY Airplant Terrarium and Sculpey Cow Skull
15,335
402
23
Posted in CraftClay
Introduction: DIY Airplant Terrarium and Sculpey Cow Skull
If you're a plant enthusiast like me, then you've probably run into air plants before. They're pretty affordable, low maintenance, and look great in glass bulbs like these. At the same time, there are other even lower maintenance things you can do that look great too. In this tutorial I will show you how to sculpt a little decorative cow skull that you can add to any similar no-maintenance terrarium.
First Time Author Challenge
First Prize in the
Indoor Gardening Contest
Third Prize in the
Step 1: Materials
You will need:
  • Sculpey/fimo and access to an oven (or clay if you have a kiln)
  • Some sort of glass container (whether or not you want to hang it is up to you)
  • Pebbles or sand
  • Some dead ol' twigs
  • A tool with a rounded end about a quarter to a half inch across (I used the end of a paintbrush)
  • A tool to cut (I just used a sharp knife)
  • A tool to poke (I used a kebab skewer)
  • A brush and acrylic Paint: some sort of white or ivory, and brown
  • Possibly some clear sculpey varnish if you want to waterproof it.
Gather your materials. These glass bulbs are pretty ubiquitous these days, and can be found all over the place. These particular ones are actually meant for candles, but work great for this purpose as well. You can buy decorative pebbles at most plant shops, but you can always go out hunting for them as well. Alternatively, sand would give it a nice wild west/desert feel. I found the twigs in my back yard.
Step 2: Form the Basic Shape
Find some sculpey and make a ball. It doesn't really matter how big you make it, but mine was about an inch and a bit wide. Take your ball of sculpey and squish and pull it into a sort of triangle shape, letting the base flatten out against the table. If sticking is a problem, you may want to use a piece of parchment paper. Make a slight indent between the points where the horns will go, and keep the snout fairly rounded.
Step 3: Create the Eye Sockets
Now take your tool with the rounded end (in my case the paintbrush), and hollow out the eye sockets on either side of the skull. Try not to go too deep, or you'll lose structural integrity. You can now use your fingers to make slight indentations on either side of the "bridge" of the snout by pinching just below the eyes.
Step 4: Create the Snout
Now it's time to make the nose. Take your poking tool and make two holes on the snout, and then pick up your knife. Cut just between these holes and pull the blade down through the sculpey to the table. You're essentially splitting the end of the snout in half. Now take the two halves and pinch them together along the line you just cut. You should still be able to see the line you created.
Step 5: Create the Horns
Time for the horns! Go back to your sculpey and make two small balls. There's no ideal size, so you may have to eyeball it and make the horns a few times until the proportions are right. To create a horn, place the ball against the table and pinch and roll the top of the ball until you have a sort of cone shape. I suggest that you leave the cones a little shorter at this time so that you can lengthen the tips of the horns once they are already attached.
Step 6: Attach the Horns
Attaching the horns can be tricky, so try to be as gentle as possible. Using your knife or poking tool, scratch the base of each horn, and then the surface where you will be attaching them on either side of the skull. Once you have attached the horns and smoothed out the place where they join, you can pinch and roll the end of each horn to more of a tapered point, curling it in slightly.
Step 7: Add the Final Details
Now you just have to add the last little details. Take your poking tool and make two small holes on top of the skull between the eyes (as seen in the picture titled step eight). Now grab your knife and make two shallow cuts from each of these holes up diagonally towards the horns. Finally, cut another shallow line down the center of the skull.
Carefully lifting the whole skull off the surface, use your knife to press upwards along the bottom edge of the skull to create some subtle teeth markings. Give everything one last look-over and pop it in the oven, following the instructions on your sculpey's packaging.
Step 8: Paint Your Skull
Once it's all baked and cooled, you can use some acrylic paint to give it some colour and definition. Give the skull a base coat of some white or ivory mixed with a small amount of brown. Then take some dark brown and fill in the eye sockets, nose holes, and indentations. Seal it with varnish if you like, pop it in your terrarium, and you're done your skull!
Step 9: Styling and Caring for Your Air Plant
Styling your terrarium is simple. Add your rocks or sand to the bottom, gently place your plant, and add whatever other decorations suit your theme. Tiny figurines can make the scale of your setup more interesting as well!
Air plants, or tillandsias, are very unique plants. They have grown immensely popular in the last few years because of this, and make a wonderful addition to hanging terrariums. Unlike ordinary house plants, they do not need to be planted. Most prefer cool temperatures, and bright, unfiltered light.
Mist your plant every 4-5 days with a single spray for smaller globes, and 2-3 sprays for globes 3-5 inches. The smaller the globe, the longer the plant can bask in the moisture, so be cautious of over-watering.
If your plant ever goes too long without watering and is looking a little sad, try soaking it in water for half an hour and then letting it dry before you put it back in the globe.
- Happy growing!
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    23 Comments
    well done , im going to try that with air dry Clay
    greetings from holland
    looks really classy.
    That skull came out great, and the final product looks fantastic! Where did you get the glass?
    Thank you! I got the glass globes (originally meant for candles) here: http://www.cb2.com/whirly-hanging-candle-holder/f2447
    Check Green Tree Dollar Stores, they have all kinds of clear glass "vase" and nothing over a dollar, they have all kinds of glass beads and stones . Good luck.
    You can get these on eBay for about $17 or so USD for 6--shop carefully and you might be able to find free shipping or a nearby place that won't need a high shipping cost---use the SEARCH BY NEAREST FIRST option (top of page on RIGHT hand side)
    You can also find many sellers of the air plants which I have not found in person here in Upstate NY. But bypass paying for the "adhesive" for the plants--this is just regular old E-6000 and is MUCH cheaper at WalMart or craft and fabric stores.
    Thank you! Excellent advice. I know the globes and the air plants are easy to find here in Vancouver, but I don't know the situation in the US.
    What exactly would your search for? Not sure how to phrase what these glass things are.
    On eBay they are calling them "Plant orbs" or "Party Orbs" or "Candle Orbs" and "Globes"---they are used with the little plants and also with tea lights.
    I am having more problems finding the plants--either they are being sold by people who don't offer "hot packs" or they are not in stock locally til summer or they DO offer hot packs but at higher prices for the plants--and $3.00 USD for a hot pack., And of course the people who are selling the cheaper orbs or globes are NOT the same people with the plants---I was going to do this for teacher gifts but that might have to waitl til end of school to avoid the chance of the plants freezing!
    good luck.. ist beutiful kreatif
    and here is how you add real skeletal parts...
    http://www.sciplus.com/p/OWL-PELLETS_48325
    One could use a real skull, for instance one from a very small dog--or a rat--just kidding!
    Haha! And bypass all that tedious work? Where's the fun in that!
    This made me curious if it would take longer to make one your way or properly skin and prepare a real skull of a small animal.
    I'm no taxidermist, but I'm guessing this would still be faster. Unless you're Norman Bates, of course.
    Ewww.. Instructables for budding serial killers. Also just kidding.
    Love it!... i was looking for something cool to put in the terrariums i had made.... and this will certainly do the trick!!
