Introduction: DIY Alarm With Phone
About: Stephanie Hicks. Curiously creative expert mess maker who is not afraid to try anything a couple of times to get it right. who is not afraid to try anything a couple of times to get it right. My specialties ar…
Ever wanted to know how to make your own alarm system? Believe it or not, you can make your own alarm for about $10 with a few simple hacks to a prepaid cellphone. You can easily catch intruders who set off the tripwire, because this neat little gadget calls your cellphone right when it happens.
This instructable shows you how to make such a device, and all it’s going to take are a few common tools, a couple of hours and a $10 Tracfone from Target.
Like this project? Check out my other instructables, my favorite survival stuff, my cool DIY Projects and my paracord tutorials.
How to Make a DIY Alarm/Tripwire
Follow these simple steps and you will soon have an awesome little gadget that alerts you to any unwanted intruders. You will immediately get a call on your phone alerting you that your tripwire has been activated.
phone
Supplies and Tools You Will Need:
  • 1 Pre-paid phone (We used a $10 Tracfone)
  • 1 Soldering Iron (You can get a cheap one at Radio Shack)
  • 60/40 Rosin-Core Solder
  • Some wire
  • 1 Box cutter
  • 1 Small phillips head screwdriver
  • 1 Hot glue gun with glue
  • Tin Foil
  • 1 Clothespin
my-instructions
Step 1:
Begin by following the instructions in the phone’s manual to activate the phone. We went online to activate ours, but if you don’t have an internet connection there’s a number you can call as well. All of this information can be found in the box that the phone came in.
Cheesewizz
Step 2:
Next, we need to program the phone’s speed dial function to call your phone number when the number 8 key is held down.
First, Enter your phone number into the phone by going to: Menu >> Contacts >> Add New Contact
Once you’ve added yourself to the phone’s contact list, pair your number with the phone’s number 8 key by going to: Menu >> Contacts >> Speed Dial List
cheese
 Select cell number 8, and then select your name from the contacts list.
cheese
 If you’ve done this correctly, it will look like this.
cheeses
Step 3:
Remove the screws from the back plate and disassemble the phone. There are five screws total.
cheese-pizza
The arrows show you where you will find the screws you need to remove.
Use a small Phillips head screw driver to remove the screws.
homemade-diy-cheese-pizza
Remove the screws one by one.
Step 4:
Once the screws are out, you can use your box cutter to pry the back plate from the front plate. It takes a bit of force and will make a loud snapping sound as it separates, so don’t worry about breaking it because you wont. Once you’ve created some space with the box cutter, you can use your fingers to do the rest of the work.
crutches
Using a utility knife, gently pry the edges of the cell phone apart. When you’ve pried it apart, it will be in three pieces.
pool-hall
The phone will come apart and you will have three pieces, front plate, middle, and back.
Step 5:
You’re going to work with the middle piece. Locate the button that corresponds with the number 8 on the keypad by cross referencing it with the rubber keypad on the front plate. Each foil circle is a button and you’ll notice that the layouts match up. The number 8 button on our phone is the second one from the bottom of the middle row. Once you’ve found it, cut the metal foil from it with a box cutter.
cheddar-cheese
Locate the button on the middle piece that corresponds with the number “8″ on the front plate of the phone, where the numbers are. This will expose a copper ring with a copper circle in the middle of it. We need to solder a wire to each of them without crossing them.
gluten-free-cheese
IMPORTANT NOTE: YOU NEED TO KNOW SOLDERING BASICS
If you screw the next step up, then the phone will be ruined and you’ll have to buy another.
Don’t worry, it’s not that hard. But you’ll probably want to practice on a circuit board before proceeding.
TIP: You can buy circuit boards like this from Radio Shack for $5. They also sell wire, solder and soldering irons.
diy-photo 4-3
Once you can solder wires this close without having the solder touch, you’re ready to move on to the real deal.
white-cheddar
Step 6:
With a soldering iron, place a small amount of solder on the tip of a wire.
string-cheese
Don’t go overboard. This much will do.
goat-cheese
Now solder the wire to the copper circle in the middle of the copper ring. The solder can not touch the gold ring around it or the button will be ruined. This is why you practiced first
milk
Step 7:
Repeat the same steps with another wire, this time soldering it to the outer ring. Again, make sure the ring stays separated from the circle.
phone10
Step 8:
Test your soldering by touching the two wires together. The phone should work normally as if you were pressing the number 8 key on the keypad. If you screwed it up, nothing will happen.
photo 4 copy 3
Step 9:
Use the box cutter to cut the number 8 from the keypad.
phone11
Step 10:
Thread the two wires through the keypad and then reassemble the phone.
cheese-burrito
Once the phone is assembled, drip glue from a hot glue gun into the hole to keep the wires secure.
no-cheese
Step 11:
Now, take a strip of aluminum foil and fold it over the end of one of the wires.
photo 2 copy 7
Using your fingers, bend the end of the wire back onto itself.
arm
Wrap the aluminum foil around the wire to secure the fitting.
arm-cheese
Use a clothespin to clamp the end of the wire as shown.
arms
Fold the aluminum foil over the top of the clothespin and secure it into place with the hot glue gun.
legs
Secure the wire onto the body of the clothespin with hot glue.
photo 2 copy 8
Step 12:
Repeat these steps with the other wire and fasten it to the other half of the clothespin.
phone20-225x300
Step 13:
Braid the two wires together by twirling the clothespin.
phone21-225x300
Fasten the clothespin to the back of the phone with hot glue.
phone22-225x300
And your tripwire is complete!
How to set up and activate your tripwire :
The clothespin holds the number 8 key down on the phone, and so you need to separate the two halves with a thin piece of paper. Receipts work great for this.
photo 5 copy 2
When the paper is removed, the contacts on the clothespin touch and the phone will speed dial your number.
phone23-300x225
phone24-300x225
You’re probably going to need to exit out of the door that you’re booby trapping—I mean trip wiring—and so you’ll need to set it up like this:
Tape your trip wire device to the wall and drape the string over the doorknob.
pizza
Run the string under the door and make sure to give yourself enough slack to get outside.
photo-41-600x800
Once you’re outside, it will look like this.
photo-2-225x300
Slowly close the door while pulling the string under the door toward you. Don’t pull it tight, but remove all the slack until you feel it tugging against the doorknob on the other side.
photo-3-225x300
Just before you shut the door, tape the string to the threshold.
photo-1-1-300x225
Now cut it and shut the door.
photo-2-1-300x225You won’t be able to see it because you’ll be outside, but this is what your beautiful craftsmanship will look like from the inside.
photo-3-12-600x800
Gadget Hacking and Accessories Contest
