loading
loading
Picture of DIY Archery Target - Puzzle Mats
i'm new to archery and i just got my own bow. i'd like to shoot at home but unfortunately the straw targets offered from the range won't fit in a car or cab, so i have to DIY.
i built this thing for about 2 days. 1 day is enough, but i ran out of materials and the store's closed.
Step 1: Materials
Picture of Materials
forgive me... i have a bad habit of crafting things without planning. this instructable would just serve as an idea for you in case you wanna make one. you can make use of your own specifications if you wish.
[1.] 1" x 1" x 10" wood (i used about 4 pieces of these)
[2.] 1" nails
[3.] 2" nails
[4.] wood glue
[5.] wood putty
[6.] sand paper or electric sander
[7.] 3" x 3" x 10" wood (i used about 2 pieces)
[8.] 4 pieces of casters/wheels
[9.] plastic mesh or chicken wire
[10.] puzzle mats
[11.] metal angle braces
[12.] carpet (1m x 1m) - the ones used for car trunks
[13.] varnish or wood paint (optional)
Step 2: Preparing Puzzle Mats
Picture of Preparing Puzzle Mats
puzzle mats comes in a pack of 10s with 1ft x 1ft dimension. i laid down and connected 9 pieces all together to create a wall of 3ft x 3ft in dimension. stacked them together until they're about 1 foot thick.
i was hoping to have plain puzzle mats but the store have mixed some with alphabets and animal designs. i just placed them in the center of the pile so pieces won't scatter.
1-40 of 62Next »
alex201920 days ago
Will this stop a broadhead or not?
Great idea have all rhe stuff at home but want to use my broad head for practice Too
tukmol (author)  alex201920 days ago
oh, no... i believe it can't. sorry.
zacker2 months ago
very cool idea... another thing that makes a good target is a huge cardboard box filled with news paper... when I was little my older brother bought an old crossbow and he took a big box, stacked news papers inside it unlit the box would hardly close, then he flipped the box onto its side so when he shot it, the arrows were going into the bottom of the box because the news papers were stacked flat the arrow couldn't penetrate them. if he had shot the side of the box, the arrow may have been able to sort of wedge itself between the pages and penetrate the target. It worked rather well.
tukmol (author)  zacker2 months ago
yup, i believe it should, that's a good idea too. and very economical. thanks for the input.
i used to collect all the used A4 paper from the office, before they shred them. stacked and taped them all up really tight. it stopped the arrows with a really heavy thud. a little hard to pull them out though.
zacker tukmol2 months ago
didn't think of using the "waste" office paper...good idea! I heard some people say that some of the gun smiths will use layered Phone books as a back stop for testing guns. A 4 or 5 phone book thick back stop would probably stop a 55MM mortar shell....lol
hahaha.
did the phone book target too... epic! :D
http://www.instructables.com/id/DIY-Archery-Target...
cool.... Looks like it worked great. now if you flipped it over so you were shooting at the top of it, you could use a gun and as long as you hit the target, those bullets aren't going anywhere. lol
ggriffith14 months ago
I use a wall section from an old coolroom (from the tip) I removed one of the metal sides leaving 6 inches of polystyrene foam and a metal back. Some of my shots penetrated the metal back. Adding a layer of old carpet or two prevents this. I needed a large target because there's no safe backstop in my backyard. With a coolroom wall of about 4 by 7 feet I can keep even the really bad shots in the yard from my longest range of 35 yards.
A layer or two of old carpet will capture the arrow, and a couple of loosely hung layers of shade cloth a few inches behind the carpet will stop full penetration.
I use a 50lb recurve bow, but this works with a 65lb compound as well.
tukmol (author)  ggriffith14 months ago
hi, thanks for your input. good work on that ggriffith1. i think i'll consider modifying my backstop when i get home.
pavulurirao4 months ago
I know this is a DIY site. However, I tried many things including using 2'X2' tiles. But finally ended up buying the target from Lancaster Archery in PA. The 2' diameter targets are less than 100 + shipping (Shipping is a lot). The 4' diameter targets are about $300. If you really want to use the targets properly, I would suggest to use those targets. I ended up paying a lot more and these did not lot long. My son shredded the targets within a week. The other targets are going about 1.5 years so far. The center cores of the bigger targets can be replaced with smaller target...The other problem is the arrows may pass through depending on your weight of the bow. Nice try through...
tukmol (author)  pavulurirao4 months ago
hi pavulurirao. thank you for the suggestion. i live in the Philippines where archery is really not that mainstream, therefore not much local dealers for proper targets and stuffs. i do have one range that i shoot at, but of course given the situation, targets are expensive, or had to be ordered form the US, etc. which would cost more.
Got it. One other suggestion is to get a very dense self healing foam similar to the one you got and may be denser, and stack them up on top of the other and use the SIDE of the stack as your target. Not the face. You will get much better longevity for the target. .
Other best and cheapest is to get the hay block that is tightly packed and use it as non movable target. I know it is heavy and all. But the hay stack might last much longer. Just IMHO. Good luck with your shooting.
ShallNOTBeI6 months ago
Great idea, Tukmol! One suggestion, though; If you happen to hit one of the puzzle seams your may get a pass-through.
The fix is to offset every two or three layers. Just slice a row of the puzzle pieces in half and assemble like a brick wall. I encountered this particular problem while sighting in a crossbow.
These are great because when the target starts to wear out you can restack and move around the beat up pieces a few times before needing to replace any. This also works well on a smaller scale as a bb and pellet trap. They always seem to penetrate to the same depth so mining the trap for lead pellets to recast is a snap!
tukmol (author)  ShallNOTBeI5 months ago
hey, great idea. thanks!
awaite1 year ago
Fuuuuuuu I just threw out a whole heap of these last week, why didn't I see this earlier.
What model Who makes them ?
tukmol (author)  megabeastmode5551 year ago
it's from Mathews. Model is a Conquest 4.
What type of bow is it?
it's a compound bow.
TruFord1 year ago
First off this is an amazing idea. I started looking to buy the supplies to make this and I stumbled upon these and wanted your opinion.
http://www.ebay.com/itm/Tadpoles-16-Sq-Ft-Playmat-Set-New-Other-Free-Shipping-/231061641827?pt=LH_DefaultDomain_0&hash=item35cc58da63
Do you think these would make a better center/core? This way you could the replace the core once its worn down. Thought id kick the idea around a bit before I try it.
tukmol (author)  TruFord1 year ago
hi! sorry for the late reply. that actually is a good idea...though, are there any "cores only" being sold? Or you still have to buy the whole square as replacement?
either way...as a visual aid, it would also be beneficial to improve groupings!
TruFord tukmol1 year ago
To my knowledge they don't sell the circles separately but you could easily stuff the score with another material (cardboard, another type of foam, ect) It would just need to be cut or rolled into the same size circle. This way you can easily replace the major wear area on your target.
i'm thinking of a rolled up rubber mat / sheet as a replacement. there you would have a spiral center that would stop arrows.
I think that would make a pretty awesome core/replacement. Perhaps something like a yoga mat (or two/three) rolled tightly together to fill the space. Its a pretty good idea.
yeah... a cheap yoga mat would do just fine, i believe!
john32 years ago
great project this one is a must try for me, thnx
tukmol (author)  john32 years ago
hey, thanks john!
john32 years ago
joebro19952 years ago
Hey! This DIY target sounds fascinating however I don't know if it's suitable for me. I have just started archery a few months ago and I'm still shooting with my 22 pound PSE snake bow. Will my target arrows even penetrate compacted and layered puzzle mats?
tukmol (author)  joebro19952 years ago
thank you! yes... it will penetrate. puzzle mats are soft but will stop even a 90 pounder when stacked.
tjlavelle3 years ago
I used this idea with a slight mod: use 4 colors of mat for the target cut circles out of them and glue them together for a nice target
tukmol (author)  tjlavelle3 years ago
hey, that's great. a good idea indeed.
thanks, it works really well, attach 2 fence posts to the back and prop it up with a third one and it will stand with the front facing slightly upwards. I am in the process of making an instructable
and i'm waiting to see that. :)
a good target face is spray painting a stencile on shade cloth, i've got a couple of bucks like this with a red bull.
tukmol (author)  it_dont_work3 years ago
sounds like a good deal, thanks for this idea!
G'Day Mate
Great idea
You may have said but I can’t seem to find it.
What poundage are you shooting at this target and how close were you when you fired.
I’m shooting 62poinds, well I use to, and my arrows are mighty thin.
I’d hate to see them go shooting out the other side and pin a little lam to the tree stump.
Although I am mighty hungry atm.
Cheers
tukmol (author)  broken board3 years ago
good day!
was shooting at 60 pounds from 10 meters.
neroweed3 years ago
awesome idea i'll surely use it with your kind permission!!
to avoid arrows passing trough target , maybe u should think about creating shock dissipation zones alterning your foam mats with : corrugated cardboard box (adequate size ) stuffed loosely with surmentioned heavy duty wrapping film , old t shirts blankets or any (gonna trash it ) fabric , plastic bags bubble wraps and anything (clean) plastic hanging round the trashbin (recycle!!) . excellent alternative to cardboard box is woven plastic sacks ( the kind used for animal dry foods or army sandbags , woven plastic let the arrow penetrate with minimal to no ripping using field points not broad heads :) and is tough enough to endure a lot of target practice!!) , on the fita training field we also used them filled with nylon foil ( kinda cheap tarp material) folded several times to a half inch tick plate , hanged loose on the back of half rotten straw targets they saved my (70 lbs propelled , point blank range) precious arrows!!
tukmol (author)  neroweed3 years ago
sure, no problem go ahed. ;)
yes, good i dea. i agree with you. i think i'll do with the corrugated cardboard boxes. precious arrows indeed. thank you!
1-40 of 62Next »
