DIY Arduino CNC Drawing Machine
52,252
353
86
Posted
Introduction: DIY Arduino CNC Drawing Machine
Epilog Challenge 9
Runner Up in the
Epilog Challenge 9
Hello Guys, In this instructable I'm going to show you how to make an Arduino CNC plotter from old DVD writers. This is an amazing machine. You can make this machine for your school, college science project. It can write and draw anything. This is also very easy to make. So let's get started.
If you like this project then please do vote for me guys. I really need your support :)
Here's the demonstration and tutorial video.
Step 1: Parts List
We need this following parts to make this CNC plotter.
Parts list:
  • Old DVD writer (2x)
  • Arduino Nano.
  • L293D Motor Driver IC (2x)
  • IC Base (2x)
  • Micro Servo Motor.
  • PCB Board
  • Male And Female Header Pin.
  • Barrel Socket.
  • Acrylic Sheet 3mm
Tools List:
  • Solder iron.
  • Super Glue.
  • Mini Handsaw.
  • Sandpaper.
  • Ruler.
  • Marker Pen.
Step 2: Making the Pieces for Frame
Here I'm using the acrylic sheet to make the frame for the CNC plotter. It is a very good choice for making the enclosure for every DIY Project. Personally, I frequently use this sheet to make the enclosure for my DIY Projects. It is easy to cut, bend and sand. It is also so affordable.You can use the following process to make pieces for the frame.
  1. Take the measurement of the acrylic sheet for the enclosure to your need and mark it with a marker pen.
  2. Then use your handsaw to cut the pieces.
  3. Use sandpaper to smooth the pieces.
Step 3: Making the Base
In this step, I'm going to make the base for my CNC plotter. So follow the step carefully.
  1. First, apply super glue on one piece of acrylic then attach this piece with another two pieces.
  2. Again use the super glue to attach the X-axis frame.
  3. Then attach another two pieces for better support.
Step 4: Removing the Stepper Motor
We need two old DVD writers for this project. You can find old and broken DVD writer on local computer hardware store. Usually, they do not use this DVD writer so they can give you it at the very low price. I got one for free and I had another one laying around. So I decided to use it for my CNC project.
  1. First, disassemble two DVD driver and take off the stepper motors.
  2. Then use your screwdriver to open the stepper motor and rails from the frame.
Step 5: Hacking the Slider for X and Y Axis
  1. First, take off the two sliders from their rails.
  2. Use your handsaw to cut the two little pieces from the slider
  3. Then attach the two pieces using super glue.
Step 6: Attaching the Sliding Rods
In this step, we'll attach the sliding rods to its frame. So follow the step below.
  1. First, take one sliding rod and insert it into the slider.
  2. Then apply super glue to attach the sliding rod with its frame and hold it still for some time.
  3. Use the above method to attach another rod.
  4. Repeat same procedure to attach sliding rods with X-axis frame
Step 7: Mounting the Stepper Motors
Now we'll mount the stepper motors. Use your screwdriver to mount the stepper motor to X and Y Axis.
Step 8: Attaching the X and Y Axis
In this step, we'll attach the Y-Axis on the top of X-Axis. Follow the above picture to attach both axes.
Step 9: Making the Z- Axis
I have seen many people got stuck on this part but I'm going to show you how to make a perfect Z-Axis. So follow steps below.
  1. Take the required parts for the Z axis like Sliding rod, pen spring, compass pencil holder, some acrylic pieces.etc
  2. first, take your sliding rod and insert it into its holder and insert pen spring after that use a small piece of the plastic holder to hold the pen spring.
  3. Then apply super glue on the sliding rod holder and attach it to the acrylic frame.
  4. After that attach a small piece of acrylic on the top of sliding rod, it also works to move the pen up and down.
  5. Then attach the pen holder at the end of sliding rod.
  6. Finally, mount the servo motor using the super glue.
Step 10: Attach the Z-Axis
Attach the Z-Axis to Y-axis using superglue as the above pictures showing.
Step 11: Solder Wire With Motors
First, cut the flexible PCB of the motors, then solder wire with motors. I'm using small pieces of a marker pen to hold my circuit board little higher.
Step 12: The Circuit Diagram
Here's the complete circuit diagram, connect everything according to the circuit diagram. If your steppers don't work properly then you have to find correct working combination by changing the pins of the L293D IC. You can also adjust the IC pins in code.
Step 13: Making the Circuit Board
In this step, I'm going to show you how I made my Circuit board. First, insert the IC bases and all the header pins, then solder its pins, after that make every connection according to its circuit diagram. You have to do it very carefully and precisely.
Step 14: Assembling the Circuit Board
First Mount the both IC, then the Arduino nano and at the end connect the wires. We're done :)
Step 15: Uploading the CNC Code
In this step, we'll upload the CNC code to Arduino.
  1. First, connect the Arduino board with PC through USB cable.
  2. Select correct port and board.
  3. Then upload the CNC code.
Programming Video Tutorial
Step 16: The GCTRL Program
Now we are ready to print our first image. We'll use the processing software to run the gctrl.pde program. This program sends the 'gcode' images to the CNC plotter.
  1. First, open the processing software and open the gctrl.pde program for the cnc machine.
  2. Then click the run button, one new window will open.
  3. Press p button to select the current port.
  4. Press g button to select the gcode.
Step 17: We're Done :)
I hope this tutorial helps you to build your own Arduino CNC Drawing machine. You have made your own CNC project then please send a photo in the comment section. I am very excited to see your own creation.
Later I'll keep updating this instructable.
Thanks for watching project, I hope you liked this project, if you did then please follow me I'll keep posting awesome new projects. Also, don't forget to SUBSCRIBE my YouTube channel.
  • Spotless Contest
    Spotless Contest
  • Science of Cooking
    Science of Cooking
  • Microcontroller Contest
2 Tips
HELLO FRIEND, CAN YOU SEND ME THE COMPLETE DESIGN OF THIS MACHINE? BECAUSE I DO NOT HAVE PREMIUM ACCESS TO THE SITE AND I CAN NOT ACCESS, BECAUSE I WOULD LIKE TO ASSEMBLE ONE OF THESE, PLEASE MAIL ME IN THIS EMAIL ADDRESS, dam.barros28@gmail.com, Thank you
i am building it. the carrier he used is plastic so he could cut and glue, i am using this which is aluminum. the space between the wires is 5.4 cm. i don't see a problem with that
27 Questions
what size
pcb board should we use
where did you get the plans for the frame, CAN I BUY THE FRAME PARTS FROM YOU, PLEASE
THANK YOU
DENNIS
DWA6070@GMAIL.COM
can I put any gcode that the program in the processing will understand and execute?
Can you please tell me how to make a gcode?? And can I make PDF a g code? Or only photo?? And how to adjust nib size ??
G-Code is a file type (commonly '.gcode' or '.gco') that consists of "g" commands. Here you can find all the commands in gcode. What the slicer program ( e.g. Cura, Slic3r, Simplify3D) does is it takes your 3D model ('.stl') and chops it up into XYZ coordinates to print. G code would look something like this:
G92 E0
G28
G1 F1500
G1 X2.0 Y2.0 F3000
G1 X3.0 Y3.0
Hope this helps!
Till what extent will it work?? Means how big article it can draw?? And I am confused about the stepper and servo motor wire for which to connect??
it can anything within 4cm square. Check the circuit diagram :)
Which type of acrylic sheet I have to use ??
And which aurdino nano I have to use .?can I use robocraze aurdino nano ?
you can 3 or 4mm acrylic sheet and any Arduino nano :)
does the code change if we use stepper motor shield instead of L293D Motor Driver IC
13 Comments
hello,ok the design looks nice ....however this drawing machine has been built many times,simply by setting up the dvd chasis in the correct orientation and most od us who built one used junk parts from our junkbox...Yes we purchased the arduino and my question is ...What have you done thats different????
We are also making Cnc drawing machine but we
have 28BYJ48Stepper motor with uln2003 driver and Arduino uno (atmega 328p)
So my question is ... Will that code given by you , will work for our project?
Brother We created 2d Plotter like this..only 1 problem in project is drawing is not fine means accuracy and clear so everything rest is fine and superb also you explained well but need and improvement for this drawing part only or you use good quality stepper motors like nema 17 and improve your project..thanks for sharing this tutorial
the issue here is not that the drawing is not fine or accurate. Remember these stepper motors are from a DVD player and to read and write a DVD the controller in the DVD player has to be very accurate. If you look at my picture in the I made it, the result is close to his, I am happy as his design is one of the more elegant ones using DVD steppers. You have to play with the code to get more precise.
We are also making Cnc drawing machine but we 28BYJ48Stepper motor and Arduino uno
ROFL , so they made you create templates. This is the cleanest and clearest instructable on the subject. P.S. i voted for you.
Yeah, a lot of people asking about the templates. Thanks for your vote man :)
can you make an acrylic parts template and send me? and how thick is this material?
