DIY Arduino LED Matrix Display - 80x8 Px
Introduction: DIY Arduino LED Matrix Display - 80x8 Px
In this instructables guide I will show you how to make your own Arduino LED Matrix display!
Main Features:
  • Time
  • Day of the week
  • Date
  • Temperature and Humidity
  • Ticker Text
  • Adjustable brightness level
  • Bluetooth communication
Can be controlled from your Android phone or Windows computer!
Watch it in action:
Official project page and future updates can be found here:
Let's get started!!!
Step 1: What You Will Need - Hardware
For this project you will need:
For the case-box you will need:
Use black - transparent plexiglass, 3mm thickness:
  • 2pcs 33x4 cm
  • 2pcs 33x6 cm
  • 2pcs 6.6x4.6 cm (left and right)
Optional, if you have a 3d printer you can print the left and right side (attached .stl files).
Step 2: The Circuit
8x8 MAX7219 LED Matrix Display module:
  • Vcc - 5VGND - GND
  • DIN -From the last one to Arduino pin 10
  • CLK - Arduino Pin 13
  • CS - Arduino Pin 11
  • DOUT - to previous DIN as the schematic
  • Vcc - 5V
  • Data - Arduino pin 9
  • GND - GND
  • Vcc - 5V
  • GND - GND
  • RX - Arduino Pin 3
  • TX - Arduino Pin 4
RTC DS1307 Module
  • Vcc - 5V
  • SDA - Arduino pin A4
  • SCL - Arduino pin A5
  • As the schematic, to Arduino pin A0
Step 3: The Code
Download the code from here and open it with Arduino IDE. Inside you will also find all necessary libraries.
Step 4: Software and Configuration Protocol
From here you can download the software for windows os.
The application for Android devices will be soon available.
If you want you can make your own application, or make an app for a different operation system.
Bellow you will find the protocol that we are using.
Configuration protocol:
For time and date send: HH:MM:SS dd/mm/yyyy>
For ticker text send: Your Text Here>
For brightness level send: Auto> or value> (value from 1 to 16)
Step 5: Android Application
Download it from Android PlayStore
Features of current version:
-Update time and date with your device clock
-Update brightness level
-16 available levels (set to 0 for automatic adjustment)
-Change the ticker (scrolling) text (set to blank to deactivate it)
How to use it:
Turn on Bluetooth and pair your display. The default name of the Bluetooth module is "HC-06" or "HC-05" and usually the password is "1234". Now open the application, press the "Load Paired Devices" button and select your BT module. (see also the video)
Note: If you can't establish a connection with your LED Matrix Display, just restart it.
If you have any problem with this application just send me an email.
For android ver. >4.4, screen size >4.5"
Step 6: Well Done!
That's it!
I hope you liked this, let me know in the comments!
I would also like to see some photos with your new Arduino LED Matrix display!
4 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Pocket-Sized Contest
  • Pro Tips Challenge
    Pro Tips Challenge
Super le projet avec Bluetooth ! a distance pour changer le Texte Etc. Pour moi je serais intéresser de l’amélioré
Es possible d'avoir ? Le Fichier aia pour modification à mon goue le APK sur Mit Inventor 2
Merci d'avance !
Bien Cordialement
if i choose to make use of 7 x max7219 led modules instead of 10 does anything changes electrical wise (power source should be of less Amperage? and does it effect the coding too ?)
Good morning I have placed 3 amp source, I have soldered directly to wires to interconnecting pins of matrixes and the failure continues to me some matrices is as if they were left without communication, what can be?
Good afternoon I do the project But I had a problem is that when I sent the program IN SOME occasions I'm turned off Some of the matrices is as if I stopped communicating between them and I have to resend the program, sometimes they leave How to unconfigure the letters in the arrays What could be what causes this thank you.
Hi! I just upload an updated code, also check your power supply, I am using 5V-3A.
Hello how are you where can i find the code updated thanks?
I want to help but I can't understand you. Could you please send me your message in English? Thank you.
Good afternoon, the project but I have presented a problem is that when I sent the program to the Arduino card occasionally I turned off some of the matrices is as if I stopped communicating between them and I have to resend the program sometimes The letters in the arrays appear as unconfigured that could be what causes this thanks.
Hola , a mi me ha pasado en ocasiones y suele ser una mala conexion entre los modulos , revisa bien las conexiones o las puedes soldar (vcc gnd data cs clk )
