DIY Arduino Nebulophone Synth by blinkyblinky
Featured
I originally wanted to purchase a Nebulophone but, my El-Cheapo price range didn't like the tag. I realized that I could program my own AtMega 328 by using ArduinoISP Then I found out that if the code was Arduino compatible, why not just use the Arduino as a Nebulophone? Well it was kind of a waste of Arduino but at least I could simplify circuitry. I recently built my DoAnything Shield and could now have access to any pin I wanted.
I looked at the schematic and realized that Dr. Bleep had left plenty of things missing such as where did the stylus go and, where were the keypads and so I emailed him and after a long string of emails everything was cleared up.
I don't have that many photos but the photos I did take explain a lot.
Here is a video of the original updated one:
Here is my video:
Step 1: The Bits and Pieces Needed
You Will Need:
3 Potentiometers (I used these but they aren't neccessarily the best pots I've used so I am switching them out with these.)
10cm of copper tape (You should get 11cm in case of any trouble...Really any measurement will work; you just need to make it fit your board)
1 alligator clip
1 SPST/SPDT slide switch (Any type of switch that can move from one position to another until pused again work (Toggle, Rocker, etc.) It doesn't matter whether it is SPST or SPDT the second connection is nothing.)
2 Pushbuttons (Tactile works nicely.)
1 5mm LED (Really any size will work. This is the Arpeggio LED)
1 LED and Photocell assembly (I got mine from here but I didn't realize that the same website had this which is much cheaper although untested. You could also make your own by bending an LED over to a photocell that can range from 10k to 200k. and then covering it with some black tubing. I'm not sure the one I had is exactly 10k to 200k but it worked.)
1 speaker and amplifier
1 Rail to Rail Op-Amp (the article said tlc2262 but I improvised with tlc2272 and it works fine. IT MUST BE A RAIL TO RAIL OP-AMP)
1 row of male headers
1 DoAnything Shield (Really it is only an adapter...you don't have to use one.)
1 Piece of Large PerfBoard (This or this SHOULD work.)
3 0.1uF Capacitors
1 220uF Capacitor
1 8 pin IC Socket
1 Audio Jack (For output. You should use the size that fits your speaker and amplifier)
1 Power Supply (For the Arduino, of course. (9v battery, USB Cable, Wall Wart, etc.))
1 IR LED (Use the clear side-firing type) (I didn't add this; I don't own any other Andromeda Space Rockers or Gieskes )
1 IR PhotoTransistor (See IR LED)
1 HUGE BUNDLE OF WIRE (You will need both solid and stranded wire.)
1 Arduino
NeoRecasata says: Apr 6, 2013. 9:13 PM
can you put a board layout for eagle cad
redd.the.cat says: Mar 4, 2012. 10:37 PM
could i swap out the tlc2262 with a lm324? and what exactly is rail-to-rail i cant find a search term that covers that
fueler335 says: Jan 20, 2013. 7:55 PM
I am not entirely certain on this,but my instructor(I am a senior E.E.T. major,and he said a rail to rail means that it will respond to negative 5 volts to positive 5 volts,as opposed to just 0 volts to positive 5 volts.
fueler335 says: Jan 20, 2013. 7:56 PM
Agh,please excuse my grammatical errors... :)
blinkyblinky (author) says: Mar 5, 2012. 1:59 AM
Ahhh...you ran into the same thing I did. I had pondered whether or not I should use a rail-to-rail op amp. After some classified research...aka asking Dr. Bleep himself, I came to the conclusion that a rail to rail op amp basically has an output gain very similar to the input voltage...
No, an LM324 would not work in this place. It doesn't have enough power output at 5 volts. The PICO PASO maybe but not this...sorry...
I gave a link on where to purchase a TLC2272 and it is very similar to the TLC2262...it worked for me.
Dr Bleep says: Oct 17, 2012. 1:42 PM
We started using the tl972 a few months ago in it but it sounds just the same.
http://www.mouser.com/ProductDetail/Texas-Instruments/TL972IP/?qs=sGAEpiMZZMtCHixnSjNA6FPlkgXGBdA%252bF1aIpL4MXC0%3d
Build_it_Bob says: Nov 27, 2012. 7:04 PM
A friend is building this and he is new to Arduino . I offered to help , but I am trying to find the main sketch as all the files appear to be separate ? Do I have to add all the files in individually before I compile the sketch?
Thanks for your help,
Build_it_Bob
blinkyblinky (author) says: Nov 27, 2012. 7:16 PM
The main sketch is named Nebulophone_D01.pde. Open that sketchin the Arduino IDE and the others will open along. Be sure to share his build when your friend is done.
Build_it_Bob says: Nov 29, 2012. 7:16 PM
I also wanted to mention that I seen your Nebulophone in the December issue of Nuts and Volts magazine ... very nice !
Build_it_Bob
blinkyblinky (author) says: Nov 29, 2012. 7:21 PM
I didn't make the Nebulophone...Dr.Bleep just made it Open Hardware so I decided to build it. On my budget.
Build_it_Bob says: Dec 1, 2012. 11:09 AM
Open source is the best teaching tool now available . I have learned more in the past few years because of the concept and all the people like yourself who take time to share using Instructables.
Many Thanks!!
Build_it_Bob
Higgs Boson says: May 27, 2012. 8:22 PM
Just to make sure, the LED with the photocell assembly is connected to pin 11 on the arduino right? Also, I am assuming that c1,c2 and c4 are 0.1 uf. Is that right? And one last question, when I downloaded the file containing the code, there were several files within. I basically just copied all of them onto the IDE and compiled. There was no problem compiling, but did I do it Right?
Dr Bleep says: Oct 21, 2012. 3:55 PM
Just open "Nebulophone_D01.pde" in the Arduino IDE and all the necessary files will open with it.
blinkyblinky (author) says: Jun 18, 2012. 9:25 AM
Yes. Yes. Yes. And yes.
umfan110 says: Aug 1, 2012. 8:47 AM
now lets say you didnt want copper strips and wanted just push buttons would you just connet them all in a seris and send a third wire to the designated pins.
Dr Bleep says: Oct 21, 2012. 3:52 PM
Just connect each "key" pin on the schematic to a button. The other side of each button would go to ground.
spystealth1 says: Feb 29, 2012. 7:07 PM
I'm slightly confused. Do I need to do anything special with my arduino before I can use the shield, or can I just load the program and plug in the shield? I think you mentioned something about an ISP. Maybe you should provide an explanation as to what that is and how to use it. Thanks.
blinkyblinky (author) says: Feb 29, 2012. 7:20 PM
You take your Arduino, program it, attach the shield with all your components. Then, you play it. The guide should help.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
