Introduction: DIY Atmospheric Drinking Water Generator
Atmospheric Water Generator
Introduction
I can't drink the water supplied from our city, and the atmospheric Water generators out there cost more than many can afford. So I made one for a little over $300. That is one sixth the price of a lowest costing unit sold online.
Parts
1 - New Dehumidifier (this brand is Kolin) $225
1 - New Extreme Water Filter system (hardware or Home shops) $125 in the US.
1 - 32" piece of clear vinyl tubing (found at Aquarium shops) $3
1 - Servo Voltage Regulator (in case of power fluctuations) $75
2 - 4"X9" 3M scrubber pads $2
1 - Zip tie 10cents
Tools
3/4 inch drill with a 1/2 inch drill bit
Philip Screwdriver
Scissors
Instructions
1) Remove all covers to your new dehumidifier. Rinse inside out thoroughly with garden hose don't use high pressure it will damage condenser flanges. dry completely before using.
2) Remove knock out for hose on back cover
3) Run clear vinyl tube through knock out and attach to hose connector inside the Dehumidifier (this will by pass the
internal one gallon reservoir )
4) Cut the 3M scrubber pads to fit air filter holder on front of machine for air filter (original filter does not trap a lot
of dust) attach filter holder to front panel.
5) Wash water filter Unit and filter before use. This unit has a 1 micron ceramic filter in top and a five stage filter in
the bottom.
6) Drill hole in top of filter unit and run vinyl tubing into the filter. Be sure not to crimp hose. Place top on filter
unit.
7) Plug unit into servo regulator and you are ready to make water from the air.
Turn on machine run for 6-8 hours depending on humidity levels to fill upper filter area.
Allow water to filter into the lower storage area.
Water comes out Neutral at 6.0 pH after filters it will be around 7.4-8.0 depending on what type of mineralization filters you used
Introduction
Parts
1 - Zip tie 10cents
Tools
Philip Screwdriver
Scissors
Instructions
the bottom.
unit.
