DIY Audio Jack Key Holder
50,667
601
59
Posted
Introduction: DIY Audio Jack Key Holder
The first thing I say in the morning after "Coffee's ready!" is "Where'd my keys go?" - it's almost a ritual at this point, but at my expense! Key dishes are fine but my foyer isn't really set up for a table, so an on-the-wall key holder is the way to go!
Many of our projects are audio-based, so it seemed fitting to create a key holder out of audio jacks, and it looks good too!
Items needed:
  • Project chassis - I had a bunch I could choose from and decided to go with one that would look good mounted on the wall. Also make sure the chassis is deep enough to account for the jacks. If you don't, you may need to adjust the jacks.
  • 3 female 1/4" audio jacks
  • 3 male 1/4" audio jacks
  • 2-4 Screws/Screwdriver (for mounting to wall)
  • Drill press w/appropriate drill bits
  • Cutting oil (or really, any other kind of oil)
For adjustments/best practice, you may also need:
  • Hammer + nail/screw
  • Nibbers
  • Angle Grinder
Step 1: Mark the Locations for Your Audio Jacks
  • Figure out which chassis face you want to see and which one you want to the wall
  • Measure out where the center is and make a small mark.
  • Decide on how far apart you want the audio jacks to be. Halve that distance, and put a mark to the left and right of the center hole.
  • Measure out where the remaining 2 jacks go and mark those as well!
Step 2: Drill the Holes for Your Audio Jacks
  • Using a hammer and nail/screw, a good practice is to tap a small divot in so that your drill bits have a place to start at. This also lowers the risk of a scratch from a drill bit sliding around.
  • Since this box is metal, when using a drill press, you want to go from a smaller drill bit and work up to the drill bit size that will allow the jack to go through (the mounting screw portion)
  • You may want to use cutting oil to help prevent your drill bit from overheating. Just put a dab where you want to start drilling and clean after use.
    • I don't have cutting oil at home but I did have some wood wax w/oil, so I used that!
  • Be sure to clean the box after you've drilled the holes!
Step 3: Adjust Your Audio Jacks If Necessary
In the first step, I suggested finding a chassis that was deep enough to accomodate the audio jacks. I didn't take my own advice! Fortunately, I was able to modify the jacks enough so that they fit. If you need to as well, these are the easiest areas to adjust:
  • Using nibbers, get rid of the audio jack solder leads
  • Using a grinder, get rid of some of the mounting screw threads. Please be careful to not take too much off! You still need the mounting thread to be able to go through the chassis!
Step 4: Mount the Audio Jacks In!
Mount the 3 female audio jacks in! Fortunately, since this is a key holder, you don't need to know which lead on the back goes to tip, ring or shield!
Step 5: Attach a Keychain to a Male Audio Jack
Using your drill press, drill a small hole through the audio jack large enough for the keyring you have to fit through.
Thread a keyring through the holes and attach the keyring to your keychain! This may require some searching around the house for old keychains.
Step 6: Install the Keyholder to the Wall!
Using a screwdriver and screws, install this on your wall! This may require making a couple of pilot holes if you're going through metal.
Step 7: Voila!
And now, you won't ever lose your keys again! (Just make sure to use it!)
  • Thank you for the in...-RikardK
    RikardK made it!
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
56 Comments
This is an awesome idea. What did you use for your chassis, it looks very familiar. Otherwise what would recommend to use or where to find something that size. I have looked online, but yours looks way nicer than anything I could find
I think it was some sort of network router actually lol. I just took out the insides and took off the sticker label :p Or maybe some sort of audio passthrough of some sort.
This is nice. We came up with a different flavored way to manage our keys.
Dry erase white-boards are metallic and like magnets.
Magnets from old hard-drives or rare earth magents are very magnetic
The ring in keyrings are iron based and love to hang on the dry erase board on the wall by door :-)
I put 10 of the really thin hard-drive magnets on ours. It works great. Hold things like flyswatters, too.
The only thing I have thought from time to time is that it would look a tad better if I would take the time to paint the magnets white to match the board.
Thanks! It's true, if I had a white board by my front door (a good organization idea), I would probably do something like that too :)
True. It might not look nice in a public area. We have it in the back hall by the garage door. Right on the way in and out.
Very clever! As a musician, I really dig this idea! Thanks so much for sharing!
You're welcome! Glad you like it :)
my bf is a DJ, I bet he's gonna love this!
Awesome :D It's super easy to make too!
