This is useful for a home stereo system when you want to send multiple music sources to a single set of speakers or for home recording to select between input sources.
Remove these ads by
Signing UpStep 1Go get stuff
A data switch
5 stereo jacks
10 nuts and bolts
A screwdriver
A soldering iron
A wire stripper
3" x 8" sheet of 1/8" acrylic
A laser cutter
Vinyl coated magnet sheeting
A fine tip black marker
(Note if you don't have a laser cutter, you may be able to get away with a jigsaw and power drill or quite simply 10 appropriate-sized washers (pictured)
this could be pretty sweet.
i wonder could you make one thats "TV" one thats "computer" and maybe one thats both?
As a bonus, since I modified the cables and not the switch, it could still be used for data if I ever needed it.
If you are creating a file to be cut via a laser, it is best to send the file as a vector format... Corel will import several file types. If you don't have software but wish to make a part to be cut I have found that CADstd http://www.cadstd.com works very well... and has a lite version you can download and use for FREE. (No time limits)
Save your work as a DXF and it can be imported directly to Corel and cut. Be sure to draw everything 1:1 and specify if it is mm or inch to the person doing the cutting.
Note: I have an Epilog 35W laser and use Corel 12 because it was specified by the manufacturer. I have also used Photoshop with some success, but sometimes the print driver needs some twiddling to get it right.
Jerry
G00 X5.0 Y4.0
The above would say, "(G00) Move rapidly along the X axis 5 inches, (X5.0) and along the Y axis 4 inches (Y4.0)"
In fact... if you look at the gerber files... you will see they are a collection of several files... one for drilling, one for plotting, etc. You can open some in Wordpad or "Notepad" and actually make out what each line of code does.
The laser is basically a printer... you select it from the list of printers and click "PRINT" to send the file to the machine. Then you walk over to the laser and press the START button to actually make the part.
Corel files are proprietary to Corel Software... I don't know of anything besides Corel that will open them. Adobe Photoshop may open them... CS4... but I haven't tried so I don't know. I like to use DXF format for making cutting patterns because there are hundreds of software packages that can open them.
