3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Audio Switch
DIY Audio Switch
A while back I got an old data switch off Freecycle and I've been eyeing it ever since and thinking "I should really convert that to a stereo audio switch." And so, after about a year of looking at it, I finally converted that old data switch into a cool-looking and extremely useful audio switch. I am now able to select between four audio inputs and route them to a single audio output (or one input to four outputs).
This is useful for a home stereo system when you want to send multiple music sources to a single set of speakers or for home recording to select between input sources.
Step 1Go get stuff
Go get stuff
You will need:
A data switch
5 stereo jacks
10 nuts and bolts
A screwdriver
A soldering iron
A wire stripper
3" x 8" sheet of 1/8" acrylic
A laser cutter
Vinyl coated magnet sheeting
A fine tip black marker
(Note if you don't have a laser cutter, you may be able to get away with a jigsaw and power drill or quite simply 10 appropriate-sized washers (pictured)
23 comments
Mar 3, 2012. 8:43 PMiApple guy says:
Where did you get that media switch?
Jul 16, 2009. 9:58 AMdannydutton says:
I have something that looks exactly like that, same color, same text style. Except mine is for parallel ports which will be a little harder to switch out.
Aug 4, 2011. 8:24 AMkool1zero says:
i have one with parallel ports too. i was thinking maybe get a piece of metal and cut it to the size of the back.i think mine actually has some extra poles on the switches inside so i might be able to shove the parallel ports down inside and just mount the jack inside the parallel port holes
this could be pretty sweet.
i wonder could you make one thats "TV" one thats "computer" and maybe one thats both?
Jul 26, 2011. 1:29 AMapseubert says:
Those old rotary switches are a HUGE pain in the butt to figure out =P
Jan 28, 2011. 6:48 AMjackboot dash says:
Awesome idea! I just finished making this, but modified just a bit. My switch was RJ45, so I left the RJ45 jacks in place and made custom cables so i can use 1/8" (3.5mm), 1/4", XLR, or whatever kind of jack I need. I just make a new cable. I decided to use OR, BL, GR, on my Cat 5 for Tip, Ring, Sleeve, but whatever makes you happy. I also made three different cables for the output, one female 1/8" mini stereo, one female 1/4' stereo (for my big broadcast headphones) and one male 1/8" plug to send audio to my sound card.
As a bonus, since I modified the cables and not the switch, it could still be used for data if I ever needed it.
Jun 22, 2009. 10:54 PMPunkguyta says:
First off, Props at doing such a clean job on modding the switch. The clean wirejob is much appreciated. Secondly, I passed one of these up at a yard sale thinking, what am I gonna use an old parallel port switch box for, it was only 2 way though :( Now I know lol
Jun 19, 2009. 1:21 AMa215 says:
My printer switch changed to VGA switch.
Jun 21, 2009. 3:51 AMagis68 says:
Very nice idea. I have a dozen I them and this project is very useful for recycling these items. Now because I've read other comments in their the central issue was the laser cutting or etching instead using these paper labels. Personaly I prefer these labels looks more handmade than any professional laser etching for labeling. When I build some I prefer the homemade look but this more personal opinion. 5/5 from me
Jun 20, 2009. 3:22 AMjames.mcglashan says:
simple y not just get a smail box and a spot switch and wire it up kidding only on a pcb board lol perect and you can evan amplyaphy it if u put a curcit also behind it lol...
Jun 18, 2009. 5:36 AMoppie says:
OK, I'm intrigued with your use of a laser cutter but... I'm unfamiliar with the file type you specified (CDR). Is this specific to a particular Laser cutter? If so, please reference which machine. Please try to give artwork files that will open in generic CAD (dwf, dxf...) or export as a GIF.
Jun 18, 2009. 12:04 PMaskjerry says:
The Corel file is a combination vector file (lines and shapes) and raster (image) components. In short... anything with a hairline width (0mm thickness) will be cut using vector, the laser head follows the path... anything wider than the minimum software settings will be treated like an image and the laser head will sweep back-and-forth to create the pattern on the material.
If you are creating a file to be cut via a laser, it is best to send the file as a vector format... Corel will import several file types. If you don't have software but wish to make a part to be cut I have found that CADstd http://www.cadstd.com works very well... and has a lite version you can download and use for FREE. (No time limits)
Save your work as a DXF and it can be imported directly to Corel and cut. Be sure to draw everything 1:1 and specify if it is mm or inch to the person doing the cutting.
Note: I have an Epilog 35W laser and use Corel 12 because it was specified by the manufacturer. I have also used Photoshop with some success, but sometimes the print driver needs some twiddling to get it right.
Jerry
Jun 18, 2009. 1:51 PMoppie says:
Nice information, thanks! I was wondering what program would open the files. Filext.com showed it as Corel but nothing I had in my toolbox would open it. More out of curiosity than need. I'm an engineer and mostly design PC boards with the Eagle 5 CAD software. Output for this is to a Gerber plotter which is to my understanding, very similar to the laser cutter. It just uses a low power laser to photoplot to film.
Jun 18, 2009. 5:05 PMaskjerry says:
Gerber files are more similar to CNC G-Code than a laser. A G-Code file is a text file that has commands like...
G00 X5.0 Y4.0
The above would say, "(G00) Move rapidly along the X axis 5 inches, (X5.0) and along the Y axis 4 inches (Y4.0)"
In fact... if you look at the gerber files... you will see they are a collection of several files... one for drilling, one for plotting, etc. You can open some in Wordpad or "Notepad" and actually make out what each line of code does.
The laser is basically a printer... you select it from the list of printers and click "PRINT" to send the file to the machine. Then you walk over to the laser and press the START button to actually make the part.
Corel files are proprietary to Corel Software... I don't know of anything besides Corel that will open them. Adobe Photoshop may open them... CS4... but I haven't tried so I don't know. I like to use DXF format for making cutting patterns because there are hundreds of software packages that can open them.
Jun 11, 2009. 9:31 AMSPGWhistler says:
If you have an amplified output and it is loud enough - when you change sources, you'll hear a loud pop. To mitigate this, I would suggest turning down the volume of your output before changing the source.
Jun 18, 2009. 6:14 AMsrilyk says:
You could also figure out a way to cut the ground out of the loop when you switch the hot, and then bring it back in. A surprisingly helpful guy at Radio Shack taught me this when I was buying some toggle switches to hook up my pickups on my guitar. I suppose if you just added a toggle switch on the "ground" side of the output, that should fix it. I think :P
Jun 16, 2009. 11:53 PMtsukdotcom says:
haha I have the exact same switch but for VGA switching. :D
Jun 17, 2009. 9:20 PMReCreate says:
Yeah those are utterly useful...
Jun 11, 2009. 7:34 AMbeddings says:
I did the very same thing but used it as a A-B MIDI switch, nice werk!
Jun 11, 2009. 10:39 AMBoss_Sauce says:
Ha, me too, but using an old A-B KVM switch-- VGA and PS2-- so (I think) 21 connections getting switched...:o I kept the original ports and just drilled and hot glued 3-conductor stereo mini jacks, connecting each jack to three of the VGA pins.
Jun 11, 2009. 9:31 AMSwishercutter says:
I have a couple of these in my "scrap electronics" box. I have been saving them for something like this to come along. Thanks.
Jun 11, 2009. 2:22 AMgmjhowe says:
I was thinking about building one of these also! I have an old 4way VGA switch, can i achieve a similar end result?
Jun 11, 2009. 4:48 AMDa_Fudge says:
In theory, yes. Your switch will just have a larger switch with more poles, but it should still work. Good Luck!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2349
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
