DIY Bench Power Supply (Dual-Channel)
27,020
413
17
Published
Introduction: DIY Bench Power Supply (Dual-Channel)
Every electronic hobbyist needs a variable power supply for prototyping and testing, but they can be very expensive. I will show you how to build a cheap yet reliable power supply.
Step 1: ​The Parts List:
The Parts List:
To build this specific power supply, you will need the following:
> 1x Switching Power Supply ( Max 32 Volts )
> 2x LM2596 DC-DC Buck Converter
> 2x 10k potentiometers + Knobs
> 4x Female Banana connectors
> 2x Toggle Switches
> 1x Car Amplifier Enclosure Box
> 1x 16*2 Dual LCD Multimeter
> USB Port (Optional)
Tools Required:
>Dremel and cutting disk
>Silicone glue
>Soldering iron
Step 2: The Beginning
>I started by fixing SMPS onto the PCB, which was then screwed onto the Enclosure Box.
>Applied Thermal Paste b/w Heatsink & Aluminum Enclosure Box.
>Multimeter Circuit Diagram + PCB layout + Hex Code attached.
Step 3: Modifying Front & Back Panels
>Using Dremel I was able to cutout space for LCD & Silicon glue was used to stick LCD with front panel.
>Using Drill Machine I made holes for Potentiometer & Toggle switches.
>Next wires from external potentiometers were soldered on to the boost converters.
>Voltmeter & Ammeter are connected to the outputs of boost converter.
>Heatsinks are installed onto the boost converter, also don't forget to apply thermal paste.
Step 4: Testing
>I have tested the bench power supply on variety of loads & so far there has been no problem.
>Final cost of this project was about 2000Rs which approximately equals to 18$.
>I hope this guide was helpful, let me know if you have any questions.
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    17 Comments
    YOU DON'T SHOWED NOTHING SPECIFIC MY FRIEND, EVEN NO ELECTRONIC DIAGRAM FOR THE BEGINNERS NOR THE CIRCUIT POWER SOURCE. BE MORE SPECIFIC....
    This instructable is very lacking in detail.
    Can you include some specs? Since you are using a specific switching mode power supply, the max current handling should be published. But if your power supply sources current through the buck converters, maybe it is limited?
    I like your project though. Good job.
    >Output of the boost converter depends upon the input provided by SMPS.
    >The maximum output ratings of LM2596 is 1.1-30 Volts 3 Amps.
    >If your SMPS is rated at 32 Volts 6 Amps - then each buck converter can provide 1.1-30 Volts 3 Amps as output.
    Looks good, but what kind of specs (voltage/current) does it have?
    Link is working for me, but in any case I have also attached (Circuit Diagram + PCB layout + Hex Code) for the dual multimeter.
    Anyone wondering what that .Lay file is, it's a PCB fabrication file. I downloaded a free reader by Abacom for their Sprint-Layout software so I could view it. Found here: http://www.abacom-online.de/uk/html/sprint-layout.html all the way at the bottom. You can print from it so making the PCB shouldn't be a problem. I'm not sure if there are other PCB Design software packages that read .lay files...
    We need a schematic. Thank you.
    Pls. schematics, almost circuit wiring!!!
    How about a circuit diagramme?
    Thankyou in advance
    Nice job! I'd like to build one of these, but the links to the other projects don't seem to be working?
    Thanks, Very awesome BPS
    thanks for sharing I may build it but not now I have final exams to study for :\
    Thanks for sharing this!
