Step 5Up We Go! - Install the Vertical Pole
That's for the big 60" length of pipe. This guy is responsible for bringing your bike to eye level, provided you are somewhere between five and seven feet tall. But hey, if you're not, they make different lengths of pipe, so get the length that best suits your hight. Go for ten feet if you've got some weird ladder fetish...
Thread the 60" length into the unused port on the tee. This piece, when installed, should be oriented so that it is perpendicular to the plane of the base. That is, if you put the base on the floor, the 60" pipe should be sticking straight up towards the ceiling.
Bear in mind that when you were tightening up everything in the last step, chances are that you've rotated the tee such that its free port is not pointing perpendicular to the rest of the component. If that's the case, it's broken. Throw it away; it's ruined.
It's not ruined. It's perfectly fine. Just screw in the 60" piece and use the leverage you get from it to rotate the tee into the right position. Make sure to rotate it in a direction that tightens the connections. That'd be dumb to get the thing oriented correctly only to have it fall apart.
I know the picture makes it look crooked. It's the wall that is crooked. Or one of my legs. But that pipe is sticking straight up, for sure.
Add Comment
