3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Bicycle Repair Stand
Step 6Ummm...Add the Other Thing!
We will now add the arm that will hold the clamp that will hold the bike.
You should have, in terms of pipes and pipe fittings, one (1) 10" length of pipe and one (1) 90 degree elbow. Thread the pipe into the elbow. You should now have a 10" pipe with an elbow on it.
Thread the free port in the elbow onto the top of the 60" length, which should still be sticking straight up in the air, unless your house is hot enough to melt galvanized steel or you didn't tighten the fittings at all.
Now that there is a cheater bar on the end of the 60" piece, it's pretty easy to tighten everything up without the use of a single tool. Just spin that little piece up top around clockwise until it stops turning. Then turn it a little more so that it's pointing in the same direction as the two 18" pieces making up the base.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:mr.bologna
