3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Bicycle Repair Stand
Step 8Voila! Throw Your Bike Up There!
That's it. If you are certain all joints that have rotational stress on them are tight (this would include the lower tee and two elbows), throw your bike up in the clamp. Hopefully you are strong enough to lift the bike with one hand and open the clamp with the other. Shove some cross member into the clamp and step back to admire your handiwork.
NOTE: If your bike has cables that run along the top cross member, obviously putting that part in the clamp means you will have trouble adjusting your cables if you need to. I didn't have that problem because my brake and shifter cables don't run along the top. They're wireless. It's brand new technology. Very cool. I'm a liar. They run along the bottom. The solution to this problem is to rotate your clamp prior to tightening it up such that you can clamp onto the seat post instead.
This is where you will find out if your connections are tight. Be sure to stand by in case something decides to rotate a bit more when the weight of the bike is introduced. If it does, take the bike off and tighten all areas around the tee and two lower elbows some more.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:mr.bologna
