Bioprinting is printing with biological materials. Think of it as 3D printing, but with squishier ingredients! There's a lot of work being done at research labs and big companies like Organovo on print human tissues and human organs, with an eye towards drug testing, and transplantation into humans. Check out these amazing TED talks by Anthony Atala, for example:
Anthony Atala: Growing new organs
Anthony Atala: Printing a human kidney
All this sounds incredible complex, but the fact is that the basic technologies are very accessible - it's all based on inkjet and/or 3D printing! So a bunch of us at BioCurious decided we wanted to play around with this technology ourselves - and the BioPrinter Community Project was born! (Come join us, every Thursday evening at BioCurious!)
We wrote this instructable in part to document our project for our fellow Citizen Scientists in the DIYbio community, so it's getting a little long. For those who want a quick 1-minute intro, you may want to check this little video:
Step 1: Hacking an old inkjet printer to print biomaterials
We started out by messing around with an old inkjet printer that we literally saved from a sidewalk somewhere. There's already plenty of interesting things you can do with an low-end off-the-shelf inkjet printer, but they do have some limitations, which we'll get into in the next Step (or skip straight to Step 3 for how we built our own bioprinter from scratch, that you can see in the first picture above).
Undressing the Printer
We disassembled an abandoned HP 5150 inkjet printer for use as a bioprinter. Just rip off all the plastic covers you can find, but make sure you can still operate the reset buttons etc. on the front panel.
There's a little momentary switch that senses whether the cover is open. After you've ripped off the cover, you will need to close that switch to be able to print anything. You can just press it down by hand or with a toothpick, glue a little piece of plastic or a screw onto it to make it easier to depress, solder on an on/off switch, or even just bridge it with a piece of wire (so it thinks the cover is always closed).
There's also a momentary switch inside the paper handling mechanism that senses whether paper has been loaded. You may need to rewire that one as well is you plan to mess with the paper handling.
Once you've got your printer all undressed, and figured out how to activate the cover-closed switch - print something! It'll be a good test to see if you've knocked something loose and whether you can still operate all the buttons. Plus, it's just darn cool to see an inkjet printer do its job up-close. Keep your fingers out of the way though - those cartridges move fast!
Cartridges Prep
Next task is prying open an ink cartridges, so you can fill them with something more interesting. We will be using brand new cartridges for the printer, because old cartridges tend to have residual ink clogging their nozzles. However, you might want to practice opening expired cartridges first. Wouldn't hurt to do a test print, and flush the print head, if your printer software provides that option.
After taking off any labels, you'll see that most cartridges have a lid that's glued into place, usually with some small vent holes to let air in as ink flows out. If you run an Exacto knife or box cutter along the seam long enough, you should be able to cut through some of the glue, and pop the lid off fairly quickly. WARNING – boxcutters are SHARP! If you're a kid, get some responsible adult to help you with this! If you're an adult - consider protecting your hand with a knife-proof glove, and/or clamping down the cartridge in a vise while you're doing this.
Alternatively, you can cut off the lid using your favorite power tool. *Much* easier, but not quite as clean. Keep in mind that you may need to be able to put the cartridge back together again, to get it to fit into the cartridge holder. If anyone knows of an easier way to open inkjet cartridges, post something in the comments! Maybe there's some solvent that will loosen up the glue without dissolving the cartridge itself?
Once the cartridge is open, you'll see that the entire ink reservoir is taken up by a little sponge that holds the ink in place. Color cartridges have separate ink compartments with their own sponges (typically Cyan-Magenta-Yellow, not Red-Green-Blue, since printing colors on white paper is a subtractive color process). You can squeeze out any remaining ink and keep it for later experiments (e.g. for some paper chromatography). Next, rinse, rinse, and rinse some more with distilled or deionized water-we don’t want to clog the print head with mineral residue.  We want to get all that ink out of there, so it doesn't interfere with our experiments.
Once the ink reservoir is completely clean, fill it partway with distilled or deionized water, put the lid back on, pop it back into the cartridge holder, and print something. Chances are, no matter how well you rinsed, you'll still see some residual ink coming out. Just keep printing until it's printing clear, and then print some more.
We discovered that our cartridge actually slowly leaks through the print head when you fill it completely with water, but it does not leak when you only put in a small amount. That actually provides a very convenient way to flush out the print head, without having to print.
Filling the Cartridges
At this point, what you want to put in the ink cartridge is entirely up to your imagination! We started out by putting some green food coloring in the formerly black ink cartridge, and printed out a test page to show that it worked. You could also try filling up the color cartridge with fluorescent dyes of your choice, and print out you own blacklight posters. Or, put some invisible ink in the black cartridge, and print invisible messages to your friends.
As our first real "bioprinting" experiment, we wanted to start with something simple, instead of jumping straight into printing with live cells. We decided to print with a solution of arabinose onto filter paper. Then we cut out the filter paper, and put it onto an agarose plate on which we had grown a lawn of E. coli that we had engineered to carry the pGLO plasmid. This plasmid carries the Green Fluorescent Protein (GFP), under control of an arabinose-sensitive promoter. (Stay tuned for an instructable on how to make your own GFP-expressing E. coli).
As a result, wherever we had printed arabinose on the filter paper, we now saw the E. coli light up green under UV light! Note that the beauty of this experiment lies in its simplicity: we only had to print with a simple sugar solution, rather than with bulky live cells; and we were printing on paper, so we didn't even have to change the paper handling machinery. You could also try printing with antibiotics, or even proteins, such as enzymes or growth factors.
The second-to-last image above shows our first test print, where we has printed arabinose over half of the filter paper - and half of the plate lights up under UV light. In the second image, we had printed the BioCurious "eyeball" logo. Success! Unfortunately the sharpness of the image definitely leaves much to be desired. Presumably, the arabinose tends to diffuse through the filter paper, which smears out the printed pattern. We should be able to do much better by printing directly on the agarose.
Step 2: Problem: current inkjet printers are too high resolution!
We've spent a good amount of time looking at inkjet print heads under the microscope. The silver strip you see at the bottom of an ink cartridge is called the nozzle plate. It's just a sliver of stainless steel that has precision nozzles pierced through it. In this black ink cartridge, the nozzles are arranged in four rows, of which you can see two in the first image above. The nozzles are actually numbered, from 1 to 416. 416 nozzles in a print head that's about 1/3 of an inch comes out to 1200 dots per inch.
Now, 1/1200th of an inch means a spacing of 21 microns. Also, the nozzles themselves are actually around 23 microns in diameter. That's on the order of the size of a eukaryotic cell - uh-oh! We should still be able to print much smaller E. coli cells (~1 µm diameter) with this print head, and possible yeast cells (~10 µm diameter).
But wait - there's more!
When you peel away the metal nozzle plate, you get to the actual print head, a marvel of silicon engineering that incorporates both the liquid handling, the microscopic heaters that vaporize part of the ink in a thermal inkjet printer, and a bunch of integrated electronics. Excellent targets for an amateur microscopist!
The last image above has us a bit worried, though. There seems to be a filter integrated into the silicon, sitting between the ink reservoir and the print head itself! From the microscope picture, we estimate the holes in the filter to be about 3 micron, which may be getting too small even for E. coli cells. Doh!
In addition, if you use a commercial inkjet printer, you'd have to take out the paper path to be able to print on anything else (like an agar plate!). Plus, if you stick with the existing printer drivers you have very little control over exactly what the print head does. You could try adapting Linux drivers to do what you want, but that turns into a project in itself.
So perhaps a clean break is better - let's just build our own printing platform that we will have full control over!
Step 3: Use an InkShield as print head
Solution!
So, it looks like we may not be able to use the latest 1200dpi generation of inkjet printers to print anything larger than yeast cells. And we may not even be able to print yeast or even E. coli cells with the inkjet cartridge on this particular printer!
Other groups using inkjet printers typically use ancient HP printers that only do 300dpi, with nozzle sizes presumably around 80 micron or so, which should be plenty large to print human cells. For example, this group is using an HP DeskJet 500, a model that dates all the way back to 1990 - good luck still finding one of those!
Now, Parallax used to have an inkjet printer development kit available to drive a 96dpi HP 51604A cartridge, but both the cartridge and Parallax kit went out of production a few year back.
Luckily for us, Nicholas Lewis recognized the need for a DIYable inkjet platform, and started a kickstarter campaign to build Inkshield: An Open Source Inkjet Shield for Arduino. (Back in stock by March - see the comments below!) InkShield is designed around the HP C6602 inkjet cartridge, a specialty cartridge with only 12 nozzles at 96 dpi, designed to print labels on things like cabling (or... inkjet cartridges!). 96 dpi equals a dot pitch of 265 micron. As you can see in the last image above, the actual nozzles are only about 1/3 of the distance between dots, or about 85 micron - just perfect for our purposes!
The InkShield is designed to be driven from an Arduino, but does need a higher voltage than the 5V the Arduino gets when it is powered from USB. So you'll need to supply a 9-12V input via an optional power connector on the InkShield, or via the power connector on the Arduino.
Step 4: Version 2: Hackteriabot!
The Platform
For our second BioPrinter platform, we built a custom XY platform from a couple of old CD drives, inspired by this beautiful DIY laser cutter / microfluidics platform from our friends at Hackteria:
http://hackteria.org/wiki/index.php/HackteriaLab_2011_Commons#Micro_Manipulator
http://hackteria.org/wiki/index.php/DIY_Micro_Dispensing_and_Bio_Printing
http://hackteria.org/wiki/index.php/DIY_Micro_Laser_Cutter
http://hackteria.org/wiki/index.php/DIY_Microfluidics#Advanced_DIY_Microfluidics
http://hackteria.org/?p=1186
http://diybio.org/2012/06/12/gaudilabalgaepicker/
TL;DR: You pull the mechanisms that move the laser head out of a CD/DVD drive, put two of these at a 90 degrees angle, and voila: XY-platform with a very small build area, but high positional accuracy!
Using the laser head positioning mechanism from a CD drive to build a highly accurate XY platform is not a new idea, of course. Urs at Hackteria credits Peter Jansen on the RepRap Builders list, who got it from his friend Trevyn, who for all whe know may have gotten it from somewhere else:
http://builders.reprap.org/2010/08/selective-laser-sintering-part-8.html
Here's some other versions, via Hackaday:
CNC machine from PC parts
Build a mini cnc machine for $45
Blu-ray CNC looks great for branding and engraving
Laser CNC from Bluray parts
Bluray Laser CNC – version 0.2
Step 5: Build an X-Y platform from scavenged CD drives
Salvaging Parts from CD/DVD Drives
Let's upcycle some crappy old CD/DVD drives that nobody else wants anyway. I was able to find a stack of chunky old drives for only a dollar or two each at Urban Ore in Berkeley. Check your local electronics recycling place.
Disassembling the CD/DVD drives is fairly straightforward. You can use the old paperclip trick to open the tray mechanism.
You may have to disassemble a number of drives to find ones with a stepper motor. At least half of the ones we opened seemed to have a DC motor driving the slide that moves the laser head. If someone knows how to tell the drives with stepper motors from those with DC motors from the outside, let us know! They're easy enough to recognize once you opened up the drive though: DC motor only have two wires, while the stepper motors usually have four, typically on a little flex cable (see pictures above).
As opposed to DC motors, stepper motors can be made to move a discrete number of steps, where each step is a fraction of a full revolution. This makes it very easy to do highly accurate positioning, without needing fancy feedback systems to check what position you're at. 3D printers typically use stepper motors to position the print head, for example.
Using the Stepper Motor
After checking some serial numbers online, we stumbled across one stepper motor labeled PL15S-020, which turns out to be a common and very well documented bipolar stepper motor. Many of the other stepper motors we found look very similar to this one, so we'll just assume they have the same parameters (annotation transfer by homology).
Data sheet: http://robocup.idi.ntnu.no/wiki/images/c/c6/PL15S020.pdf
This particular stepper motor does 20 steps per revolution (not great, but good enough), and the lead screw has a pitch of 3mm per revolution. Therefore, each step of the stepper equals a 150 micron displacement of the laser head - not bad! We could potentially drive up the resolution significantly by doing microstepping. For example, a simple 8x microstepping could theoretically bring the resolution down to less than 20 micron, which seems overkill given the amount of mechanical slack in the system, and the resolution of our print head.
Since we were all teaching ourselves Stepper Motors 101 anyway, we decided to keep it simple and go with full steps. The Arduino.cc website has some Circuits for Bipolar Stepper Motors as well as sample code to drive them. We ordered some SN754410NE H-Bridges to implement the circuit shown in the last picture.
Reduce, Reuse, Upcycle!
Old CD/DVD drives have lots of other cool bits too! There's the tray open/close mechanism containing a DC motor with some low-speed gearing, that can be used for a variety of other fun tricks. The spindle motor that spins the CD is typically a high performance brushless DC motor, which have been used for very low weight RC planes and helicopters. Plus, a bunch of switches, potentiometers, friggin' LASERS, and the occasional solenoid! Make sure to drop off the leftovers at your local electronics recycling place.
Step 6: Putting it all together
Materials:
- Two laser head slider mechanism with stepper motors (preferably matching), scavenged from old CD drives. Cost: a few bucks a piece.
- One InkShield kit, with ink cartridge and cartridge holder. Cost: $57
- Optional: additional HP C6602 inkjet cartridges. Cost: as low at $17
- Arduino Uno. Cost: $30
- Two SN754410NE H-Bridge motor drivers. Cost: $5
- Arduino prototyping shield and/or tiny breadboard. Cost: $4-21
- Wires, machine screws, standoffs, enclosure. Cost: Free to $$$, depending on how fancy you want to be.
Total cost for our version: about $150, shipping/handling for parts included. The pictures above show two different versions we made. The second one has a nice acrylic top plate, and a lot more space to put things in between.
The bottom CD drive mechanism moves the blue plate holding whatever you're printing on (such as an agarose plate). The top CD drive mechanism is set at a 90 degree angle compared to the bottom one, and moves the inkjet print head. We used Shapelock and some screws to attach the bottom platform to the laser head, and to attach the inkjet cartridge holder to the top laser head. The electronics consist of an Arduino Uno at the bottom, then the white InkShield (connected to the inkjet cartridge holder with a nice white ribbon cable), and then a protoshield with the stepper drivers on top.
The gridded paper strips on the bottom and top platforms allow us to track the position of the X and Y stages. Total print area is about 1.5 inch in both directions, with a resolution of 150 micron per step. Note that the resolution of the stepper motors is similar to the resolution of the print head: 96 dpi is a 265 micron pitch, but the dots printed by the print head are clearly separated - more like 150-200 micron.
Step 7: Success!
So here's our first honest-to-god BioPrint... We loaded a liquid culture of E. coli +pGLO into the inkjet cartridge, modified the little "I <3 InkShield" demo Arduino program that came with the InkShield, and printed a couple of lines of "I <3 BioCurious" over and over on an agar plate. (I'll attach some code as soon as I figure out how to do that.) The agar plate was filled almost to the top, to minimize the printing distance.
As you can see, printing with live E. coli cells worked perfectly! We probably let the colonies develop a little too long, so the letters are a bit fuzzy. We get a spray of small colonies from stray cells - probably due to some sputtering from the inkjet head. We may be able to improve on that by adjusting the viscosity or cell density of the culture we load into the cartridge.
But overall, not bad for a first try!
After printing, we disinfected surfaces with bleach, rinsed out the ink reservoir with bleach, and then let some bleach drip-flush through the print head, followed with a lot of deionized water, to make sure no bleach would dry up inside the print head.
It would probably be a good idea to invest in a second hand ultrasonic jewelry cleaner, so you can sonicate the heck out of any dead cells or other deposits that may form inside the print head.
Step 8: Lessons learned and future work
We dug into this project with essentially zero hands-on expertise with bioprinting, driving stepper motors, driving inkjet cartridges, or even programming Arduino! So naturally, not everything we did was as optimal as it might be. Here's some things we might do different next time:
- Learning how stepper motors work and how to drive them was a really valuable learning experience, but we could have saved ourselves a lot of time and effort by adapting some of the RAMPS (RepRap Arduino MEGA Pololu Shield) technology that has already been well developed for precisely this purpose by the 3D printing community. In particular, the Pololu stepper drivers already have microstepping capability built-in.
- Building your own XY stage for essentially free is great! But we are using these stepper motors for something they were never designed for, and it's starting to show. We are already getting some trouble with the bottom stage skipping occasionally, presumably because we've been resetting the sage by hand too often, which puts a lot of wear on the plastic bits that track the worm gear. It would be easy enough to buy some stepper motors brand-new, lasercut a frame to hold them, add some micro switches for end stops, and code a position reset function in software.
- Once you start sourcing brand new stepper motors, laser cutting a frame, and wiring up RAMPS electronics, why not just start with a 3D printer instead? If we get tired with our current BioPrinter version, that's probably the direction we'll go. Cost would likely go up by an order of magnitude or so though...
- Having a single print head has its own limitations. If we really wanted to do some sort of tissue engineering, we'd love to be able to print multiple cell types, and put some scaffolding material in between. We could potentially put two inkjet cartridges back-to-back. The solution the Big Boys in this field use is syringe pumps. Imagine having several syringe pumps sitting next to the printer, each feeding a different printing material via a thin tube to a needle mounted on the print head. Stay tuned...
Now the elephant in the room... What the heck do you do with your own BioPrinter? I don't think a place like BioCurious will ever compete head-to-head with companies like Organovo in terms of printing human tissues or organs. For one, animal cells take a lot of effort to maintain. Plant cells are much easier to work with though! Don't want to give everything away, but stay tuned for some of our next Instructables!
Meanwhile, here are some ideas:
- Print gradients of nutrients and/or antibiotics on a layer of cells to study combinatorial interactions - or even to select different isolates from an environmental sample.
- Print patterns of growth factors on a layer of eukaryotic cells to study cell differentiation.
- Print two or more microbial species at different distances from each other, to study metabolic interactions.
- Set up a computational problem as a 2D pattern of engineered microbes on an agar plate.
- Study Reaction-Diffusion systems
- Print 3D structures by over-printing layers using the inkjet head. Now you can consider doing all the above in 3D!
- Print cell in a sodium alginate solution, onto a surface soaked in calcium chloride, to build up 3D gel structures (similar to spherification process in Molecular Gastronomy)
- More ideas? Post them in the comments!
Step 9: Addendum: so you want to do Real Science?
The BioPrinter shown here is obviously just a prototype. But since we've had a very serious inquiries about using this in academic labs, here are some guidelines:
- Delphine Dean's group at Clemson University has been working on bioprinting using a modified HP DeskJet 500. Definitely check out their video on JoVE on Creating Transient Cell Membrane Pores Using a Standard Inkjet Printer! Tons of great information how to deal with an inkjet printer as a piece of lab equipment, how to clean ink cartridges, make suitable cell suspensions, and some intriguing non 3D printing applications.
- We have not yet proven to our own satisfaction that the HP C6602 cartridges can print eukaryotic cells. We likely just have a clogged print head because we weren't sonicating to clean out cellular debris after printing. We'll keep you informed...
- The printing may take a couple of minutes, so keep the printer in the hood to avoid contamination (duh).
- Wrap the electronics in plastic wrap or build an enclosure to keep it dry and clean. Everything else can be wiped down with bleach after using.
- It may even be possible to autoclave the CD drive mechanisms and the print head - only one way to find out! The plastic of the cartridge should survive autoclave temperatures, but might warp. No idea bout any glues used to attach the silicon print head to the plastic cartridge though.
- Any suggestions for how to best reference an Instructable? I'd recommend something like this (in APA Style):
D'haeseleer, P. (2013, January 22). DIY BioPrinter. In Instructables. Retrieved [your time] from http://www.instructables.com/id/DIY-BioPrinter/
Jazzswagga says: Apr 30, 2013. 5:03 PM
Cool! But how much does this cost because I would like to build one.
Also would it be possible to convert this in to a 3d printer? Just wondering.
Thank you for your time.
Li Sashay says: Feb 18, 2013. 8:56 AM
Nice!
fraenzaen says: Feb 3, 2013. 10:09 AM
Hi,
thanks for sharing your work!
Do you know about something like this with Epson printers?
I think they are based on Piezo not thermal technology, could they be used for a wider range of materials?
_bio says: Jan 29, 2013. 4:37 AM
If I'm right all HP printer working with bubblejet technology, this means the printing liquid is heated to press out of the jet. I do not know much about the heating details but it sound not too good for cells and other temperature sensitive material. Wouldn't it be better to use a piezo printer for this use case?
Patrik (author) in reply to _bioJan 29, 2013. 4:08 PM
Apparently not:
"In our study, we comprehensively studied changes in heat shock protein expression and cell membrane morphogenesis in printed mammalian cells with thermal inkjet printers. The heat shock protein expression of the printed cells has minor difference between the untreated cells and lower than manually heated cells."
http://etd.lib.clemson.edu/documents/1239894674/Cui_clemson_0050D_10011.pdf
http://onlinelibrary.wiley.com/doi/10.1002/bit.22762/abstract
DIY-Guy says: Jan 27, 2013. 11:02 AM
Patrik: Very nice project concepts indeed! The mechanical tricks are really neato!
As for printing patterns with yeast cells, where do I start looking for information on the size of something like brewers yeast cells?
And, what size or type of filter will contain yeast cells while allowing a nutrient fluid to pass back and forth?
Thanks for any help you can give this newbie.
DIY-Guy
Patrik (author) in reply to DIY-GuyJan 27, 2013. 10:48 PM
Here's a nice table on the typical size of a yeast cell. The consensus seems to be around 10 µm (with a range of 2-15 µm), or about 1/10th of the diameter of a human hair.
Human cells can vary a lot in size, depending on the type of cell. Human egg cells are >100 µm, while sperm has a diameter of only around 5 µm. Typical animal cells are quite a bit bigger than yeast cells though - let's say 20-50 µm.
Here's the corresponding table for "a bacterium". Consensus: ~1 µm, with a range of 0.2-5 µm.
Lastly, here's a really good animation of relevant sizes in biology.
Filter sterilization is typically done with a 0.2 - 0.45 µm filter, but keep in mind that viruses and phages will pass through such a filter. If you want to separate yeast cells from the supernatant, you should be able to get away with a 1 µm or even coarser filter, but 0.2 or 0.45 µm may be easier to find.
NicholasCLewis says: Jan 26, 2013. 8:18 PM
Patrik, this is a very cool project. I am always glad to see people do neat things with my InkShield.
For everyone who is interested in buying an InkShield kit, I plan to have them available in my store again mid March.
Patrik (author) says: Jan 26, 2013. 5:57 PM
For an interesting BioArt version, automatically screen twitter messages for paranoid fear mongering tweets about biology, and print in glowing green E. coli on a Petri dish...
r_l_f says: Jan 26, 2013. 1:58 PM
This is the greatest thing I have ever come across on Instructables. One could imagine printing a liver lattice and the liver cell in one pass then grow it for a new liver after undergrad school.
The Cartographer says: Jan 25, 2013. 9:10 AM
Can you print cake?
Or bubblegum?
ZacWolf says: Jan 25, 2013. 6:50 AM
Reading this Instructable gives me chills! It seems that the Critical Path for most bio-discovery/experimentation is the cost of the equipment. Especially in genetics, where the cost of sequencing machinery has dropped by orders of magnitude, but custom creation of DNA for experimentation (such as using it for data storage) is still cost prohibitive. This sort of tinkering really gives me hope that "printing" DNA may not be as far off as first imagined! Excellent job!!!
ManifoldSky says: Jan 24, 2013. 3:00 PM
As mentioned tangentially by one poster, you might do well to consider a CISS. In fact, I checked, and you ARE able to order them empty from various Chinese suppliers, so that eliminates all the word removing the ink. There are even a number of CISS kits available for older printers.
Patrik (author) in reply to ManifoldSkyJan 24, 2013. 4:40 PM
Yes, we've definitely looked at a continuous system, and if we had a production bioprinter that we printed large volumes, that would totally be the way to go.
However, I doubt we'd be able to find a CIS kit for this particular special-purpose HP cartridge that we can drive with the InkShield. We could easily adapt one to our purposes, but that would involve opening the cartridge anyway.
Typically, we're only be printing very small volumes that need to be prepared fresh every time. So until we come up with some applications where we're printing relatively large volume (i.e. >5 mL or so) 3D structures, a continuous ink kit would be overkill.
ManifoldSky in reply to PatrikJan 24, 2013. 5:16 PM
The advantage, however, is that you would start with an empty system, eliminating the time consuming, not to mention very messy process of cleaning the old ink out of the cartridges!
Jayve Montgomery says: Jan 24, 2013. 11:16 AM
this! plus DNA data storage...so lovely.
Patrik (author) in reply to Jayve MontgomeryJan 24, 2013. 12:41 PM
Meh - DNA data storage is fundamentally straightforward. The main bottleneck is that you need enough money to do that much DNA synthesis. That part is not yet accessible for amateurs on a shoestring budget, but it's getting exponentially cheaper!
rkaski says: Jan 24, 2013. 7:04 AM
The concept of "remove the plastic so you can see it work" by itself is great. I think I will do that for my grand-kids. I like your project!!
Patrik (author) in reply to rkaskiJan 24, 2013. 12:37 PM
Refilling the cartridge with something else is pretty easy too, although it may be hard to get all the existing ink out, unless you take the lid of the cartridge off (that's the dangerous part) and take out the sponge.
Most ink refill kits just inject ink through one of the vent holes in the cartridge with a big blunt-needled syringe, or even include a tiny hand drill to make your own hole in the lid. You may be able to flush enough water in and out through that hole with a syringe, to then put different colors in the color cartridge. Get some cyan, magenta and yellow highlighters, squeeze the ink into the inkjet cartridge, and print your own black light posters!
james.m.k says: Jan 24, 2013. 7:06 AM
This is so cool!
I see with your 3rd pic that you've (*joking*) managed to print a human heart!
Makes me wonder if you are working on you're own replacement parts, or someone to help around the house.
Let me know when he/she is finished! Do you plan to licence him/her under the GNU GPL or BDS licences? Or is this to be a closed-source person? *grin*
Seriously, I saw a project like this on PBS several years ago, talking about printing scaffolding upon which human cells could grow, and lamented that they had copyrighted the modifications they'd made to the print-cartridge. Though I figured that this sort of stuff was probably out of the realm of possibilities for the hobbyist.
Glad to see you've proven me wrong!
Patrik (author) in reply to james.m.kJan 24, 2013. 12:29 PM
Hehe - yes, that 3rd image is obviously someone's wet dream of a bioprinter. ;-) I've seen another CGI image that someone made up, where the printer actually had an HP logo on the side.
Speaking of human hearts - as I mentioned we don't have any plans to use human or animal cells in the foreseeable future, but we did have have serious plans to make a decellularized "ghost heart" for Halloween last year! We actually did some test runs trying out different protocols to decellularize some chicken hearts using various methods. Haven't gotten around to scaling it up yet, but one of our members does now have two pig hearts in his freezer :-D
Maybe we'll get around to that project again for next Halloween - we'll post an instructable if we do!
nerys says: Jan 24, 2013. 8:14 AM
for inkjets I would go with Canon or epson multi tank printers. the reason is you can get "empty" ink tanks pretty cheap for them that are designed to be refilled and they are cheap. since they come empty there is no ink residue to clean out and nothing to cut slice break or saw open as they are designed to be easily filled.
remember the OLDER the inkjet the better. new and or higher end inkjets have 2 and even 1 picoliter nozzles meaning whatever bio matter you put in their will probably just clog the nozzles up. so think OLDER.
Here is an ebay example. 110773910917 those come empty and are designed to be refilled so very friendly to this kind of project.
also CIS or Continuous Inkflow Systems. although they usually come "full"
nerys in reply to nerysJan 24, 2013. 8:16 AM
NOW single tank systems DO have a distinct advantage. the print head is built into the cartridge on many of them (like the HP and Lexmark printers) this means when you wear out or irrevocably clog the heads you can just get a new cartridge and you now have new head with new nozzles. SO that might actually be better.
Patrik (author) in reply to nerysJan 24, 2013. 12:14 PM
Exactly - all good points!
Of course, sufficiently old inkjets are getting harder and harder to get, and the cartridges will probably go our of production as well. The other issue is finding drivers for them, and especially trying to modify drivers (or even write your own!) to get more control over what the printer does.
Using an older 300dpi inkjet is definitely a viable option for bioprinting, especially if you manage to get your hands on an a printer like the HP 500, where people have already figure out a lot of the details.
We just felt it was easier, and had more growth potential, to start with a clean slate...
schmitta says: Jan 24, 2013. 12:01 PM
Incredible instructable. Great work guys -- keep it coming !
ldtc+labs says: Jan 24, 2013. 9:57 AM
Excellent work guys. We want to build one soon! Sadly the InkShield seems to be out of stock.
Jose
Little Devices @ MIT
xenobiologista says: Jan 24, 2013. 7:56 AM
I remember seeing some paper about engineering little spheres containing one type of bacteria covered in another for cleaning up toxic waste sites...it had something to do with the inside one being able to digest a type of waste that the outside one couldn't, but needing protection from some other type of waste that the outside one could digest. You could try that. Sorry can't find the reference.
Matz says: Jan 24, 2013. 7:49 AM
Great Instructable! For your next version, when you replace your slides, you might want to check out OpenRail, OpenBeam, and MakerSlide as possible alternatives, especially if you want to increase your printing area.
Patrik (author) says: Jan 23, 2013. 7:43 PM
Hehe - just noticed Cassandra Khaw @casskhaw over on TechHive posted a nice little summary of the BioPrinter project. But then she followed it up with "This is one DIY project you might want to avoid. Printing with potentially harmful bacteria isn't something we'd recommend (for what we think are obvious reasons), so print at your own risk." Heh...
I don't seem to be able to log in to TechHive, so I'll just post my response here:
Obviously, we are *not* using any kind of harmful bacteria. And yes, DO try this at home! Whip up a yeast culture from a packet of dry baker's yeast, and see if you can print with that. Or get one of the genetic engineering kits from Carolina, make your own mutant glowing bacteria, and print with those.
Have fun! Build something! Learn science by doing!
canida says: Jan 23, 2013. 4:06 PM
You guys are doing some amazing work! I can't wait to see what people do with this.
randofo says: Jan 22, 2013. 11:34 AM
This is fantastic. Very interested to see where this project takes you. One of these days I have to make the trek and visit your hackerspace to check all of this out.
GorillazMiko says: Jan 22, 2013. 9:29 AM
Very cool Patrik without a C!
GM
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
