Introduction: DIY Bitcoin Lottery With Raspberry Pi
Picture of DIY Bitcoin Lottery With Raspberry Pi
There was a time when I was really into Bitcoin mining. I had a bunch of GPUs running and it was a fun hobby that surprisingly made me a little money as well. It was a fun experiment but I eventually ran out of time to play around with it, and it was a good time to sell everything, so that is what I did. I kept a few of the small ASIC block erupters. Fast forward 3-4 years, Bitcoin is in the news again $4000 US for 1BTC. Crazy! So I made this fun little device that will never actually make money(Unless you are lucky!) It is a conversation starter.
Step 1: Watch the Video!
Step 2: Get the Parts!
Picture of Get the Parts!
You don't need many parts for this, the Block Erupters could be hard to find.
  • Raspberry Pi 3 B
  • Block Erupter or other ASIC for Bitcoin Mining
  • 3D Printed Files
  • Small Fan(recommended not needed)
  • 8 Neopixel Strip(or more or less if you want, adjust python script accordingly)
  • Power Supply good enough for 6W at 5V
  • Plastic threading screws M2.26 for pi mounting
  • Zip Ties
  • White paint if using non white filament
  • Shrink tube(for fan)
Tools
  • 3D printer
  • Screw driver for mounting
  • Jumpers to cut
  • Soldering Iron(for fan)
Step 3: 3D Print the Body!
Picture of 3D Print the Body!
The files are up on Thingiverse here: https://www.thingiverse.com/thing:2494568
Pretty easy to print, any settings should work.
Step 4: Paint the Back White(if Its Not White)
Picture of Paint the Back White(if Its Not White)
I was using black filament, so I decided to paint the part that reflects the light, white.
Step 5: Assemble the Body With Pi.
Picture of Assemble the Body With Pi.
Pi Mounts to the back. I use Torx screws, M2.26, plastic threading.
Plug in the block erupter. Hook up the fan if you are using one.
Step 6: Connect the Wiring.
Picture of Connect the Wiring.
I am powering everything from a 5V power supply including the Pi. Some people do not recommend this because it bypasses a fuse. You can choose your method of powering.
The Neopixels also need 5V, and then connect the data line to GPIO18 of the Pi.
Step 7: Program the Pi to Mine.
You will need to get CGMiner working. Here is the method that worked for me, you may require more knowledge in cgminer, lots of documentation online. For this to work you need to solo mine, I use NiceHash. https://solo.nicehash.com/
This was found here and updated by me: https://www.raspberrypi.org/forums/viewtopic.php?t...
sudo apt-get update
sudo apt-get install libusb-1.0-0-dev libusb-1.0-0 libcurl4-openssl-dev libncurses5-dev libudev-dev wget http://ck.kolivas.org/apps/cgminer/cgminer-4.10.0.tar.bz2 tar xvf cgminer-4.10.0.tar.bz2 cd cgminer-4.10.0 ./configure –enable-icarus sudo make install sudo apt-get install screen screen -S miner cd cgminer-4.10.0 sudo cgminer
Step 8: Run the Programs.
Picture of Run the Programs.
To get the Neopixels working follow this tutorial: https://learn.adafruit.com/neopixels-on-raspberry-...
To get them working with a Pi 2 and 3 you need to disable the soundcard driver, follow this: https://www.instructables.com/id/Disable-the-Built-...
I wrote a python script to run along side cgminer to work the LEDs and see if you have won or not, you can download it here: https://github.com/IdleHandsProject/BTCLotto
You need to get CGminer working and running, then run the btclotto.py program. Instructions are inside the program. btclotto.py takes the information from CGMiner so they both need to be running to have the lights displaying anything.
Step 9: Get Lucky!
Picture of Get Lucky!
You could find a block, you never know!
Step 10: Support These Projects!
Picture of Support These Projects!
If you would like to support my projects, Consider subscribing to my YouTube, becoming a Patron, and following on Instagram.
You can also send me bitcoins, here - 19s7hAVkm54Ev7QZEsWAfoyECy1CwXSrhL
I won't be expecting to win the lottery any time soon...
YouTube SeanHodgins
Patreon Sean Hodgins
Instagram
Twitter.
Get notified the moment a new project comes out!
KunalM44 (author)2017-12-19
Nicehash is down. What else can we use?
Also post those instructions.
Thanks.
MinaN7 (author)2017-09-21
so I am sorry I don't understand what this but I think I will try to make one but need more details should I have money to buy tickets or what?
and wiring?
RobertL68 (author)2017-09-06
I guess I'm the only one struggling with this.. Where did you source the Neopixel 8 LED Strip specifically (can you supply link?). I think I have the pi mining, but I don't know where to get the right neopixel for the project..
Thank you in advance!
RobertL68 (author)2017-08-29
Curious which wallet would best to use to connect your solo.nicehash.com to? Blockchain seems to change your wallet address on each received transaction. Would that then require modification of the cgminer config? Not that winning the lottery more than once would likely happen..
seanhodgins (author)RobertL682017-08-30
Blockchain changes the wallet address each time you generate one, but the old ones still work to sending to your wallet.. This way you can assign different wallets for different things. E.g. 1 wallet for mining, 1 wallet for you store, 1 wallet for non-business transfers, etc. Just use the same one in your config. You can see past addresses in blockchain if you go to Settings->Addresses, all of the addresses listed there will still work.
About This Instructable
8,935views
47favorites
License:
Bio: M.a.Sc in Mechanical Engineering. Pretty much designing a new circuit board every day, and I have made a few inventions of my own ... More »
More by seanhodgins:Open Source CajonArduino Geocache LocatorYouTube Christmas Ornament
Add instructable to:
