Introduction: DIY Bottle Cutter
Picture of DIY Bottle Cutter
I've always wanted to make my own glasses with cool bottles that I've collected. I came up with this very simple design to cut bottles into your very own glasses! Cheap and simple build. I was able to make mine out of scrap walnut that I had lying around the shop. Make sure to watch the video as it shows you every step required! Have fun!
Step 1: Cut & Drill First Piece
Picture of Cut & Drill First Piece
As you can see I made a prototype prior to making the walnut bottle cutter. My prototype actually worked just as good as the walnut one! Alright, so the bottle cutter is made of three different pieces of wood. Let's get the first piece ready.
  1. Cut a piece of wood to 5" x 9". 1" to 1.5" thickness is fine
  2. Mark a grid in order to get drill spots
  3. Add half the measurement of your board thickness to your first riser line measurement
  4. 1" riser lines all the way up the board length (this will be the adjustable portion to make glasses taller/shorter)
  5. On the 1" riser lines that run widthwise, mark two holes 1" 1/4 from either edge
  6. Drill holes
Step 2: Cut & Drill Second Piece
Picture of Cut & Drill Second Piece
This next piece will be your base. The portion your bottle sits flat on.
  1. Cut another piece of wood at 5" x 9"
  2. Mark riser hole width on end of your second piece with a nail as shown
  3. Drill holes
  4. Your riser can now be moved up/down by simply un-screwing from base plate
Step 3: Cut & Drill Third Piece
Picture of Cut & Drill Third Piece
This is the side support that keeps your bottle in a corner and gives the cutter some rigidity. It needs to be drilled and screwed into the riser piece and base piece. Use screws so you can easily adjust the height of your cuts.
  1. Cut another piece of wood at 5" x 3.5"
  2. The 5" portion should run along the length of the base piece
  3. Mark centered holes along bottom and side along riser piece as shown
  4. Drill holes
  5. Use the piece you just drilled to mark the holes on the riser/base piece so it matches up
  6. Drill the new holes on the side of riser & base pieces
  7. Mount it together using screws
Step 4: Rocks Glass Setup
Picture of Rocks Glass Setup
This bottle cutter is supposed to be able to adjust depending on how tall you want your glasses. So lets set it up for rocks glasses to start.
  1. You will basically repeat a step and now measure out your bottle cutter so it will cut a 4" rocks glass
  2. Mark new riser holes set at 4"
  3. Drill holes
  4. Screw together
  5. Use a bottle to see the riser height is where you want it
Step 5: Mount Glass Cutter
Picture of Mount Glass Cutter
This is a pretty important part as this is what's going to cut your bottle. It needs to be strong and stable in order to do its job as straight as possible. So take your time.
  1. Buy a glass cutter - https://www.amazon.com/gp/product/B01MUHLIVO/ref=...
  2. Drill a hole in the middle of the glass cutter (metal portion)
  3. Remove wood handle from glass cutter
  4. Mark center of bottle on top of bottle cutter riser as shown
  5. Mark your drilled hole on your riser and an additional hole in one of the notches in the cutter as shown
  6. Make sure the glass cutter sticks out enough from your riser! This needs to touch the glass to cut it!
  7. Drill the two holes
  8. Mount the glass cutter using screws
Step 6: Setup 5" Glass
Picture of Setup 5" Glass
Alright, so the bottle cutter should be all set up at this point to cut yourself some 4" rocks glasses. You can go ahead and skip this step if you'd like. I'm going to show you how to add an additional glass setup to your bottle cutter. You don't have to do 5" you could do 6" or anything really.
  1. Repeat the same steps you took to mark your riser for the 4" rocks glass
  2. Measure out 5" glass to make sure your cutter will cut at 5"
  3. Mark new holes through riser support on the riser
  4. Drill holes
  5. Mount together to make sure it's all good
Step 7: Sand & Finishing
Picture of Sand & Finishing
Now we need to disassemble in order to sand and oil our bottle cutter!
  1. Remove all your screws
  2. Sand all three pieces until it's nice and smooth
  3. Apply danish oil or a finish of your choice
  4. Let dry
  5. Reassemble
Step 8: Make Glasses!
Picture of Make Glasses!
Now we can use our new bottle cutter! Follow the steps to easily make your own glasses. When scoring the glass, make sure to apply a steady amount of pressure. It doesn't need a tonne of force so be patient and just apply enough pressure until you hear it scoring the glass. Gently spin the bottle while applying pressure to get a complete cut.
  1. Clamp cutter to table using the end of the base piece
  2. Cut the bottles pressing against the edge of bottle cutter and riser support
  3. Adjust your cutter as desired (for glass height)
  4. Get a large container that can fit the bottles with ice water
  5. Get a big pot of water on the stove nearly boiling
  6. Place your bottle in the hot water for 30 seconds while spinning it slowly (your score line needs to be in the water!)
  7. Remove from hot water and immediately place in ice water for 30 seconds while spinning it slowly
  8. Glass should separate
  9. If glass doesn't separate on its own try applying a little bit of pulling pressure
  10. If that doesn't work repeat hot water/cold water
  11. Wet sand the edges to remove any sharp surface
Step 9: Enjoy!
Picture of Enjoy!
Enjoy your new glasses! Make sure the edges/rims are smooth and won't cut any lips! If they are still sharp use some more wet sanding paper with a little water until smooth. These make great gifts, so make some for Christmas this year! Thanks!
the modder (author)2017-12-25
yeah thats a good idea cool mate
the modder (author)2017-12-14
so what happens if u cut ur lip when ur drinking or if someone bumps u while drinking
Use some carbide sand paper to wet sand it and it should become nice and smooth!
agis68 (author)2017-12-15
Good DIY project but its little trouble to screw and unscrew depending the bottle's height, what about if you put adjusting drawer slides and just locking the height by a metal axle. Also an improvement (maybe) is to make a hollow of the common diameter of the bottles usually you cut for more stability. Voted
Woodness Goodness (author)agis682017-12-22
Great point. I think you have a good idea there! Next one I make will have a modification like that!
CassidyM8 made it! (author)2017-12-22
My dad and I built this last night and it works great! It took maybe 2 or so hours and we also made a modification to it. We placed 2 nuts inside the base board so we could use bolts to attach the riser. Using wood screws would eventually strip out the base board screwing/unscrewing to move the riser up and down. We used a bottle cutter we already had but was able to screw it on just the same as the instructions said to. Thank you for sharing such a great idea!
Awesome! Great modification. Wood screws will eventually strip the wood (depending on usage). So glad you made one! Good luck!
Lauriebitz (author)2017-12-14
So excited about this!
I have tried using the other bottle cutters. (They don't work well at all). This looks to be a great build with proven results.
kzqalexander (author)2017-12-14
Hi, I was wondering if it can be used for square bottles...
Many thanks!
Nyxius (author)kzqalexander2017-12-14
In theory you can use this to also cut square bottles, but due to the uneven thickness it is vulnerable to spidering and cracking. It is possible, but also takes skill.
jtackkett (author)2017-12-14
Very nicely done and explained. I think this is one project I will give a try.
About This Instructable
13,439views
161favorites
License:
Bio: I love coming up with cool ways of using wood! Furniture is my specialty. Getting ideas from all my fellow wood lovers out there. Wood ... More »
More by Woodness Goodness:DIY Video Editing DeskDIY Chest of Tools (Drawers)DIY Bottle Cutter
Add instructable to:
