loading
Step 7: Adding the T-Slot
I just made a 1/2 mdf part to protect the table and I grooved 2  3/4 slot with the router bench.
I got each t-slot for 11$ ea.
After that, you just have to put a 1/4" hex bolt upside down and make some support for your pieces. I'll add more pics later
<p>Thanks for the help Spiky. I'm having a hard time getting all of the cross cut dowels perfectly lined up. If you have any tips, please feel free to share.</p><p>In regard to your 'upgrade', would you mind taking a picture of yours installed? It was a tough piece to get perfectly cut, and I'm not sure where / how it is installed.</p><p>Servo motors are way to expensive for me, so, I'm sticking with the NEMA 23 stepper motors! </p>
I don't remember if I had any trick. I had the plans and I drew on the wood all my measurements. I was in metrics I think ( maybe more precise ? )<br>The fit won't be 100% perfect since there's human manipulation. You will have to use your skills to tweak the parts a bit.<br><br>For the upgrade, there's no plan. I just drilled holes in the side of the machine and fixed the ribs with floor screw. I needed something quick and strong. It really help the stability of the machine.
Hi again Spiky. <br><br>Do you still physically posses this CNC? If so, can you please take additional pictures? It would be very helpful!
<p>Hi Spiky!</p><p><br>I've got all of my MDF cutouts completed! I hope to have the whole thing assembled and tested within 2/3 weeks. I too have ordered the NEMA 23 motors. Do you have any information you can share about how you wired this? I'm comfortable building, but, am concerned about my lack of experience when it comes to wiring everything together? Is there a less expensive option of the GECKO controller? If you had to do everything all over, are there any changes that you would make knowing what you know now? I'm taking lots of pictures as I go!</p>
If I had to do it again I would probably use servo motors, as they are in closed loop so they wont miss any step. With open loop motors like steppers, you have to watch your print and be ready to press the e-stop in case something bad happen ... or maybe I was just trying to cut too deep for each layer ... anyway .. The servo alternative is quite more expensive, I would say around 1200$ for the electronics. At that price you better buy a DIY already made CNC<br><br>The gecko driver are well engineered drives and they will allow the current the motor needs. It's been a while since I havent shopped for stepper drive for nema 23 ... I use smaller motors with my 3d printers.<br>You need a drive that can handle 3 - 4 amps per axis if my memory is good.<br><br>Unfortunatly I don't have time to make a complete schematic right now, you can take a look at http://www.geckodrive.com/images/cms_files/images/G540%20REV8%20Manual.pdf<br><br>Even 3d printers schematics can help you. To drive a stepper you need 2 signals, 1 for the steps and 1 for the direction<br><br>The drive needs +Vcc ( 24 volts - 50 volts ) and a Ground<br><br>Motors have 2 phases ( 4 wires ) and it's quite easy to get the info on their wiring.<br><br>With the gecko drive, you need to supply a resistor to the drive, so the drive can &quot;know&quot; what's the maximum current your motor need.<br><br>Good luck with your project. Let me know if you have any other questions, i'll do my best to give you an answer !
<p>In regards to the holes shown on the top of the bed, are ALL of those holes for cross-cut dowels? I believe so, but, just want some verification before drilling them out.</p>
Yes, there are 2 long rib underneath the bed and you need to fasten the bed to those parts.
<p>What all would I have to expand to make a working envelope of 24*36 inches?</p>
<p>Can anyone please verify the diameter of the lead screws called for in 36&quot; , 24&quot; , 9&quot;?</p>
1/2 if I remember well
I would like to try this based on an old ping pong table. That way I could cut/engrave large items like full sheets of plywood/mdf, doors, sliding glass doors...
<p>I don't know if you will get this or not. But I have to make two remarks.</p><p>1. Thanks for all of your effort. </p><p>2. Tell the others to use the gray stuff between their ears and a bit of common logic and figure out the details themselves.</p>
Yes I know, that's what I always say to myself. If you want to build a complex project like that you need some skills. Then you need to know how cnc works, how not to crash the machine.<br>Some ppl may be able to run it but they've never built something like it. Personnaly, I only ask question on forums when I'm having a HAARRRDDD time figuring out something, otherwise I do it by my own.<br>The goal here is not to discriminate anyone, but to tell ppl to be a little bit more resourceful.
<p>Hi please could you tell me two things. First thing the lead screws you give the length but not the diamater and pitch . Second thing how do you install the skate bearings and are they adjustablei can't find any info on this . Thanks Dave.</p>
<p>How are the alu angles attached to the wood? So both at the ends of the wood and on the sides of the wood.</p>
Sorry tslots
I don't remember, i think I just got them in a store, when i saw them i was like : oh shit i need this !!<br><br>But you can find similar ones over the web, it you're in Canada you can try<br>http://www.leevalley.com/en/wood/page.aspx?p=61986&amp;cat=1,43455,61994&amp;ap=1<br><br>Enjoy
Where did you get the talbots at
Very nice design! <br> <br>Do you happen to have plans for 18mm MDF? <br>I just went to the store and got myself a nice plate of 244cm*122cm MDF with a thickness of 18mm, it was the closest to 3/4 inch. <br>
Well, I don't think there would be any problem, just be sure to drill the hole in the center of the plate. You might have to adjust some part but if you are good enough to build that CNC, I don't think that it's gonna be a problem to adjust the plans
what would i need to replace to make it a laser engraver or cutter?
Very nice work :D <br> <br>Its possible to put online the 3d files of the project? <br> <br>Best Regards, <br>Marco Gaspar
I am using stepper motor Nema23Part <br>No.: 57BYGH420 <br>Frame Size: NEMA23 <br>Step Angle: 1.8 degree <br>Voltage: 3.6V <br>Current: 2.0 A/phase <br>Resistance: 1.8Ohm/phase <br>Inductance: 2.5mH/phase <br>Holding torque: 12.6Kg-cm 132oz-in , with unipolar (For Bipolar connecting, the holding torque is 185oz-in) <br>Rotor inertia: 300 g-cm2 <br>Detent torque: 0.4 kg-cm <br>Number of wire leads: 6 <br>Weight: 0.7KG <br>Length: 56mm ! <br> <br>does it hold Nema23 ?
I think that is the bolt pattern I used.<br>Nema is a standart classification of frame size. It should work.
stepper motor torque 12.6Kg
Hi, <br>can i have the Catia V5 3d model of the CNC (or post it into this instructable)? <br> <br>Thanks
Of all the designs I've seen of home brew gantry mills this seems to be the simplest in the size I want. I'm beginning to cut MDF tomorrow.
It starting to come together. I'm making some small alterations to use up some 7/8&quot; MDF I have knocking around and glueing some of the joint which are unlikely to ever need to be separated. A minor point is unfortunately some of the Imperial drawings have metric dimensions.
Not too far off completing the build of the MDF chassis. I found I was able to dispense with the 1&quot; angle and use 3/4&quot; thoughout by carefully removing some of the MDF between the two V-grooves that the bearing &quot;skates&quot; fit onto. I've yet to decide what I'm going to do for drive screws. At the moment stainless all-thread (polished up with a green scouring pad) with home made anti-backlash Delrin nuts seems most likely. Then to think about the steppers, driver electronics and decide between Mach 3 or LinuxCNC. How do I load photos?
Oh really ?! Sorry about that ... anyway it's quite easy to to the conversion, I'm sure you'll get over that hehe.
Nice !! I want to see your pics when you'll get to the assembly part
METRICS AND IMPERIALS, ALL NEW DRAWINGS ARE AVAILABLE !!!!!
Thanks.<br><br>You are the MAN...<br><br>Merry Christmas and Happy New Year
can you arange the pdf with metric sizes??<br>Thanks
Done :)
You machine reminds me a lot of this:<br> <br> <a href="http://buildyourcnc.com/default.aspx" rel="nofollow">http://buildyourcnc.com/default.aspx</a><br> <br> Well, his earliest one at least. good luck. I can't wait to see the video of you running. I'd like to see what your machine can do.
you could gain a few inches of width by cutting out a portion of the gantry side, then shifting it to the back. So the router could go almost all the way right and left (if looking from the front). I see many designs with bulky router holders, and they end up wasting a lot of work area from it.
Hi. I really like this instructale tough its a bit incomplete. Very clean project. The problems i'm facing are the plans, they're incomplete. What i would like to ask you(more of a proposal) ... coy you give me the 3d model of the project and i'll give you my plans for a cnc and if you want ill make you all the complete drawings of all the pieces and gie them to you. You can mail me at victorbojica@gmail.com or pm me. Thanks.
I like this design a lot - one thing that seems to be missing is a good labeling from part name (ie from the pdf) to model mapping. Looks like a lot of parts need two copies, etc.<br><br>I would love to see more detailed assembly instructions, which would also help clear this up!<br><br>Kevin
Personally, i made my real design with a 3d picture and those pdf. I just figured out the rest my self.<br><br>As I said on the other comment, I will complete it in a few moment but the essential is already there !!<br><br>Thanks
Hey Spiky - <br> Spent more time looking through this, and the things I still can't figure out:<br><br>1. I don't see a pdf for the bottom portion (the base). While I can see the construction design, the dimensions (to ensure the rails are tight) would be helpful.<br><br>2. What is the mechanism to connect the leadscrews to the portion they drive? I can think of a couple of ways to hack it, but was curious what you did.<br><br>3. How is the rigidity? Looks like it could wobble a bit - how do you deal with that.<br>4. Any idea on the cutting speed?<br><br>All in all, I love the design. Simple, clean, &amp; looks like it requires very minimal tools. Would love to see a lot more detail. Perhaps you could post the 3D plans in sketchup format?<br><br>Thanks - looks great.
I have it in Catia format, i don't know if I can convert it in sketckup format or something else.<br><br>This is my first instructable and I did it quite fast. I'll try in the next few weeks to put more details on the leadscrew and mechanism.<br><br>I will also put letters or numbers on parts. If someone is panning to build one, dont hesitate to ask questions about parts you don't see. The the moment, i'm quite busy doing other thing but I promise that it will be all completed before the end of the summer.<br><br>Thanks to all
Great build!<br><br>I was wondering is there is much wobble and what kind of tolerance do you have.
Hmm, I didn't test it yet !
In the end what was the total cost of the build?
Seconded<br>
MDF Board : 35$<br>Bearings : about 30$<br>Lead Screw and antibacklash nut : 135$<br>Power supply : 50<br>Steppers : 49$ each ( 150$ )<br>Gecko drive : roughly 250$<br>Bolt and cross dowel : 50$<br>Aluminium angles : 55$<br><br>Rough total : 755$
What about the stepper motors, driving circuitry, and software?
great question<br>
I'll add it, i'm using the Gecko drive with Mach3 software
About This Instructable
110,616views
381favorites
License:
Bio: I'm an electrician, currently studying in electrical engineering. I'm doing those projects as a hobby. I like DIY projects and hacking stuffs :). Hope ... More »
More by Spiky1987:DIY Guitar with my diy cnc router 12V Fan Controlled by temperature DIY MDF CNC Machine 36x22
Add instructable to:
