Introduction: DIY Cable to Use OTG and Simultaneously Charge the Device (Windows and Android)
You can use this cable with all android and windows devices to use the OTG function and simultaneously charge the devices.
Step 1: Materials Required
- Micro USB male A,
- USB Male A,
- USB female A
- DPDT or 2P2W or 2P2T switch
- and some wires.
Links to purchase the items:
DPDT Switch: https://goo.gl/GHzVb1
Micro USB Male A: https://goo.gl/MtGTcF
USB Male A- https://goo.gl/ZnDXQj
USB Female A: https://goo.gl/ZnDXQj
Step 2: Wiring Micro USB
Wire the Micro USB male A according to the schematic shown and USB guidelines.
Step 3: Preparing USB Male a and Female A
Strip and tin the wires of the USB male A and female A
Step 4: Wiring
Wire the connectors to the switch as shown in the diagram below. A clear explanation has been given in the video and working has also been demonstrated.
Hi,
I was just wondering why does D+ need to be switched as well. Only switching ID to ground will not work?
I wonder if it would be possible to do this with a small timer circuit instead of a manual switch....
In short:
1. Make cable as per schematic in Step 4: Wiring.
2. Switch to 'Charge'.
3. Connect everything: Phone charges.
4. Switch to 'OTG': USB device is connected to phone, and phone is still charging.
(I haven't made it yet though.)
I've been needing this for a project! Thanks man :D
