D.I.Y. Can Safe
5,726
38
5
Posted
Introduction: D.I.Y. Can Safe
This instructable will tell you how to make a safe disguised as a can. The "can" has a un-screwable bottom, which allows access to what is inside.
Step 1: Materials
What you will need:
An empty can (opened from the bottom)
An empty milk carton
Super glue
A clamp
Sandpaper
Step 2: Cutting the Milk Carton
Open the bottom of the can with a can opener and get rid of its contents. Clean it and dry it. Next, cut the top of the milk carton so that the circumference is slightly bigger than the can's. Throw away the bottom half (or recycle it).
Step 3: Making It Able to Screw on and Off
Take the piece of the milk carton and press it in to the can (face up), just enough so that the top is level with the top of the can. The edge of the milk carton piece should "click in" to the grooves on the inside of the can. BE SURE THAT THE OPENING IS IN THE CENTER. It is important that it is in the center, because if it is not, it will not screw on properly. Sand the top of the milk carton's lid so that you have a rough surface to glue. Also sand the bottom part of the can (the part you used the can opener to take it off). Once that is done, put super glue on the rough side (top) of the milk carton cap. Place it upside down on the center of the bottom of the can. To keep it together and in the center put a clamp on it, for about 5 min.
Step 4: Finishing
Once the glue is dry, you can screw it together so that it looks like a normal can again. It may need a little adjusting so that fits together okay. If you need to you can move the pieces a little until it fits. As soon as it fits, you're done! Congratulations!
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    5 Comments
    I wouldn't like to go to your house, everything would be hidden.
    Nice cool safe
    Just a quick observation for those who want to try this - take note of the type of can opener that's being used in this instructable.. The cutting wheel works on the OUTSIDE of the lip, rather than the more common type that cuts INSIDE the lip.
    Good idea! I will try this when I actually have money.
    Nice! I like the screw-on lid especially. Good pictures.
