3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Capacitor
DIY Capacitor
In this Instructable I will be making one of the easiest high voltage capacitors that I know of.....
WARNING High voltage electricity can cause death and serious injury.I do not recommend that anyone work with high voltage power sources unless they know how to do it safely.
Step 1Getting the materials
You will need:
1.A long screw
2.Some tin foil
3.A 2L bottle
4.some salt and hot water
5.Electrical tape
The first thing you do is get the cap and put a big screw in it.
317 comments
1-40 of 317next »
Mar 20, 2012. 8:22 PMmonney95 says:
Why is there no internal foil layer like in a typical leyden jar? I have made one and will test but am not sure if it will work for this fact.
Mar 30, 2012. 12:23 PMknexbuild says:
The saltwater (a conductor) acts as the internal foil.
Dec 15, 2011. 2:33 PMaliampolizzi says:
what is the capacity of this leyden jar?
nice project though.
Feb 21, 2009. 4:55 PMpolishdude says:
How do you charge the capacitor up?
May 9, 2011. 1:49 PMerichahn525 says:
High Voltages, Televisions work decently, high voltage transformers, or even a van de graph generator. But be very careful, if you build it larger than a masonry jar it can get dangerous and possibly deadly. Do not play around with electricity if you don't know what your doing.
Nov 5, 2008. 3:42 PMjakesllama says:
you know what im thinking? worlds strongest electromagnet ever! thanks for the compaciter i will try to make it!!
Jan 6, 2010. 12:20 AMTyMan210 says:
 The strongest ever is over 500,000x stronger than the earth's.
May 9, 2011. 1:47 PMerichahn525 says:
The strongest ever has been recently created using graphene inside a lab environment measured at about 300 telsas. To put this into relativity, a really strong magnet, one of those rare earth, or neodymium magnets are about .7 teslas. Read up on it here: http://www.rdmag.com/News/2010/07/Materials-Magnetism-Graphene-under-strain-creates-gigantic-pseudo-magn/ so 10 Million at this point!
Sep 12, 2009. 7:05 PMliny says:
I wouldn't recomend it but you could try. To make the world's strongest, you will need to beat the Navy's Gaussian guns (railgun and coil guns) with capacitors that can vaporize you. After that, you will need to beat the actual strongest (i think) electromagnet that can (more or less) defy gravity (it makes apples and stuff float, even water, just like an anti-gravity space). As a side note, the electromagnet is bigger than a house.
Nov 6, 2008. 10:00 AMhurtzmyhead says:
worlds strongest? your going to need a lot of 2lt bottles!!!!!!
Dec 28, 2009. 10:40 PMARJOON says:
still best to buy one 10X smaller
Mar 2, 2011. 7:11 PMteslacoilguitaramp,helpmeplz says:
when i saw this i thought. that looks unreliable and overly dangerous, and sketchy, i give a forewarning i would not do this, and i am tring to build a tesla coil. so i am being nice and revving a friendly warning.
Feb 26, 2011. 8:30 AMconb3 says:
If you add lemon juice to the water will it make it more conductive ?
Jan 1, 2011. 1:32 PMCrtek says:
could anyone tell me if the screw should be touching the water inside the bottle or not. i can't seem to find this info anywhere
oh and how would one connect multiple capacitors like this in series?
Jan 4, 2011. 2:21 AMnutsandbolts_64 says:
It should be. As for connecting them in series, connect the positive to the negative, then the positive of that capacitor to the negative of another etc. In short, foil to nail, foil to nail. As long as you don't connect the same capacitor to each other twice. By the way, why connect them in series? One is already powerful. People would usually connect them in parallel, but of course, that depends entirely on the use. What are you planning to do with them anyway? Just so that I can satisfy your questions.
Jan 4, 2011. 6:23 AMCrtek says:
i need them for a tesla coil
so would that mean i need to connect them in series or in parallel?
Feb 10, 2011. 8:50 PMbsomerville says:
series, for a tesla coil you want as high a voltage as possible (to prevent over-voltage) and as little capacitance as you can (to keep the frequency of discharges through the spark gap high) unless your not using a spark gap coil, in which case i have no idea.
Jan 6, 2011. 12:23 AMnutsandbolts_64 says:
A Tesla Coil? Sorry, I don't have experience building tesla coils. There are instructables floating around that could have people that can answer your question. Or you can post the question as a question in the first place.
Jan 29, 2011. 8:25 PMtechno guy says:
Is the bright spark in the last picture done with static electricity or with high voltage ac or dc? I made my own capacitor, its smaller but its awesome if you connect it with high voltage ac (500+ volts) like from a flyback it makes some awesone sparks and you could sometimes make small corona discharges.
Jan 31, 2011. 8:09 PM7654321 says:
you cant charge a capacitor with ac, can you?
Feb 9, 2011. 2:36 AMVoid Schism says:
Because it is alternating, it will charge in one direction, then when the current reverses it will be discharged.
If you want to use an AC source you need to rectify it. The easiest way to do that is to use a (high-voltage) diode to only allow current to flow in one direction, thus preventing discharge.
Jan 29, 2011. 8:40 PMtechno guy says:
To make a capacitor bank with these, what would be better, hook them up in parallel, or in series?
Jan 31, 2011. 8:03 PM7654321 says:
sorry didnt read well, what would you be using this for? if you want to increase the voltage, than do it in series, if you want to make it last longer do in parallel
Jan 31, 2011. 7:56 PM7654321 says:
With capacitors, in series reduces capacitance using formula (c1*c2)/(c1+c2), in parallel increases capacitance, so in parallel would be better.
Jan 16, 2011. 6:44 PMfostersfriend says:
Dude this just doesn't work i substituted the expensive table salt for driveway salt replaced the plastic bottle with a glass bottle I just happened to have after I did it all I was left with a worthless bottle of saltwater I tried charging it with a 9 volt then a dc power supply then a high voltage low amperage grill igniter and nothing no spark no reading on the meter nothing
What did I do wrong they make capacitors with glass layers?
Jan 4, 2011. 6:24 AMCrtek says:
by the way...i've seen loads of capacitors made from a can (Al) on the inside and Al foil on the outside
are those better in anyway or can i just make the water kind?
thanks for your answers
Dec 21, 2010. 9:42 PMrocket_man says:
Alright stupid question but about how much voltage could one of these charge up to
Aug 5, 2010. 12:19 PMBrian Wall says:
wats the srew for?
Sep 24, 2010. 10:16 PMmikmkt93 says:
its the contact. if u touche the the scw to the aluminum foil with a wire it sparks
Feb 27, 2008. 9:09 PMmicronxd says:
nice design! I never thought of using a bottle! I've only made a simple one out of paper... nothing like this!
Feb 23, 2010. 6:28 PMflubs says:
 how do you make one outta paper
Apr 1, 2010. 8:51 AMjj.inc says:
 a layer of foil, a layer of paper, a layer of foil.
Apr 7, 2010. 7:03 AMbeehard44 says:
nice and simple...
Jun 13, 2010. 7:04 AMnutsandbolts_64 says:
nice and simple *layers 20 of those and connects them together* SHI---
Jul 27, 2010. 4:18 PMJimmy Proton says:
i made one with paper once but it diddnt work
Jul 28, 2010. 3:43 AMnutsandbolts_64 says:
aww... I guess cardboard would do better :D
Jul 28, 2010. 10:47 AMJimmy Proton says:
i have a lot of that...
Jan 25, 2009. 10:21 AMclemsonguy1125 says:
do u need to charge it up
Feb 10, 2009. 4:06 PMmettaurlover says:
DUH. did you seriously think that it magically charged itself up?
Apr 7, 2010. 7:12 AMbeehard44 says:
Well, if you did it in a high altitude, exposed to the elements, the outer wrapping connected to a good ground and a long-enough wire going up and not grounded, add stormy or bad weather, and it CAN charge itself up.
i read an article that some HAM radio operators use that method to charge batteries for their HAM radios.
1-40 of 317next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:_Sean_
