3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Carbonator
DIY Carbonator
This short instructable will show you how to make a carbonating tank. This is useful if you want to make your own soda, maybe you like fizzy coffee, or making fizzy fruit. The principle is simple. Water can absorb carbon dioxide (CO2) if they are both pressurized together. The colder the water (ice is not water, so not freezing temperatures) the more CO2 it will absorb. When the pressure is released the CO2 will start to escape from the water and creates a fizzing action just like your favorite bottle of root beer (it's Virgils...only try it if you're willing to be addicted).
Our DIY carbonator is going to be very simple. We just need a tank to store our carbonating target that is capable of being pressurized to about 100 PSI. Rich Faulhaber over at Evil Mad Scientist Labs was nice enough to share the idea of using a water filter housing. Check out www.evilmadscientist.com/article.php/co2inator to see how he did it. Follow on to the next steps to see my take on it.
Step 1The CO2 Tank
The CO2 Tank
You can build all the carbonating vessels you want, but you can't carbonate anything without some CO2. Thanks to the popularity of paint ball, you can easily get a small CO2 tank and CO2. Just look up your local paint ball equipment supplier and buy a tank from them. The 20 oz tank I bought cost $25 and the "remote supply line" was $30.
The remote supply line makes this setup easy. One side screws onto the tank and the other usually has a quick connect system. I couldn't find fittings that would adapt the quick connect to the plumbing fittings on the water filter housing, so I just cut the paintball quick connect fastener off. With that out of the way, just use a barb fitting and a standard air compressor quick connect fitting to make things work with the water filter housing.
Be sure to use teflon tape on the threads of all connections to prevent leaks!
11 comments
Oct 1, 2011. 9:21 PMstevegt says:
Do *not* build or use this as shown, lest you find yourself with a face and eyes full of plastic shards. Google for "PVC compressed air", "hydrotesting tanks", or even "tire explosion" for more information and horror stories, but here's the short version:
(1) You need a regulator between the tank and the filter housing. Putting a pressure gauge on there isn't enough -- pressure gauges can clog or stick, you can get distracted while pressurizing, and so on.
(2) Always fill the filter housing to the top with liquid before pressurizing -- don't just drop fruit in it as shown. You need to get the air out. While that plastic water filter housing is fine for high pressure water, high pressure gas and plastic are a bad mix. Gas expands. Water doesn't. If the housing shatters when full of water, you get water all over the floor -- no big deal. But if the housing shatters when full of gas, the expanding gas will propel the pieces away from each other like shrapnel.
Sep 5, 2011. 9:57 AMdidgitalpunk says:
i did not get the use of this... What is it for?
Sep 6, 2011. 3:03 AMdidgitalpunk says:
haaaa so you can make fizzy fruts and such?
Sep 3, 2011. 3:25 PMCasquinha777 says:
How would one do the same thing with nitrogen (like Guiness does)?
Sep 4, 2011. 4:46 PMCasquinha777 says:
Thanks!
Actually, I don't like beer. But I was thinking about soda that doesn't produce carbonic acid. I figured nitrogen was inert enough that I can add my own acids as desired (like acetic acid/vitamin C). I figured since Guiness used nitrogen, there was some precedent that it would work.
Sep 3, 2011. 11:45 AMilpug says:
That is a good way to die. However, if you get free soda out of it, awesome!
Sep 2, 2011. 9:02 PMtrojan52 says:
I would highly suggest the addition of a pressure relief valve.
Since that CO2 canister can pressurize your vessel far beyond it's maximum rated pressure in a rely short time lapse, I think it's would a really good idea to use one in conjunction with the pressure gage.
Sep 2, 2011. 1:58 PMwhosdadog says:
The pressure in a paintball CO2 tank can reach 1000psi. So if you are releasing 100 psi into a slightly larger vessel, I believe you should get around 8 or 9 fillings from one tank, before it dips below 100psi.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:NearSpaceLuke(Night Sky Near Space Balloon)
