DIY Carburater Clean; Removing the Top
1,867
19
Posted in WorkshopHome-improvement
Introduction: DIY Carburater Clean; Removing the Top
Unscrew Lawnmower Top using Phillips head screwdriver on two screws
Step 1: Filter Access & Removal
Unscrew Filter Compartment Using Flathead Screwdriver and remove Blue Filter
Step 2: Filter Compartment Removal
Unscrew three screws using 3/8 inch socket wrench, remove black filter holder
Step 3: Removing * Securing Fuel Line
Find Fuel line (black hose)
Use Channel Locks (tool) to pinch Fuel Line Clasp
Remove Fuel line (third pic)
Step 4: Spring Removal
Locate Spring in Picture 1
Remove Spring
Step 5: Throttle Control
Picture 1: Loosen throttle control using 1/4 inch socket wrench to remove screw from the Throttle control
Picture 2: What it should look like after removal
Step 6: Removing 3 Carburater Screws
Remove carburater Screws using 1/2 inch socket wrench
Utilize pictures 1 to 3 to see where existing carburater screws are located
Picture 4: Begin unscrewing
Step 7: Removing the Carburator
Notice the carburater is still attached to a pin using the first two pictures
Picture 3: close up of Pin Attachment location
Procedure: remove carburator by tilting sideways; visit photo 4 for finished look
Step 8: The Carburater
Place carburater on a surface you do not mind ruining such as a cardboard box
Use Carb clean (found at any general store)
Spray carburater using carb clean mixture at an angle from 6 inches away
Step 9: Finished Carb Clean
Dry wet Carburater by letting it sit for 2-3 minutes
Step 10: Reassembling Lawnmower
Revisit Slides 1-9 to Put back together the carb
Your lawnmower will now run more smoothly (and work)!
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    Great tutorial. I wish that I had this a few weeks ago when I had to clean the carburetor on my mower.
