DIY Cardboard Deer Head
 by Soupraok
Featured
I have always wanted a Cardboard Deer Head like the ones you see at trendy shops or at http://www.cardboardsafari.com/shop/product_cbs1002.php but couldn't justify spending money on something I know I can make myself.
In this Instructable I will show you how I made my Cardboard Deer Head. Its not perfect but I am happy with it. The total project took me about 10+ hours off and on. My best advice is too take breaks and don't get frustrated (cutting gets a little tedious).  If you had a laser cutter this would probably take you less than 30 minutes of actual work.
PLEASE NOTE
Cutting cardboard can be difficult. Please be careful to not cut yourself, always cut away from yourself!
Shall we get started?
Step 1: Supplies and Materials
The Best part about this Instructable? ITS FREE! That"s right free, that is of course if you have most of the supplies on hand.
Scissors
Box Cutter
Hot glue gun
Tape (masking tape works well)
Optional (but recommended)
Exacto-knife
Materials
Cardboard (best if it is clean, not bent up, and doesn't have anything printed on it)
Template printed off (I attached a .zip file with the template scaled so you can print at any standard printer. Also a much larger .png file if you want to scale up or play with)
Pop top
Step 2: Cut out the template
Start by cutting out the template. (I provided a .zip file on the last step)
Once you cut out all the pieces tape together any pieces that weren't able to be printed on one page. ( The head with the antlers and the middle) Look at the closer images for reference. If you have any questions feel free to ask
After you have taped the pieces together that needed to be, loop your masking tape on the back of the template pieces.
Step 3: Start cutting out the cardboard
Once you have a piece taped down carefully start cutting out. I put sheet of cardboard down so i wouldn't cut my carpet up.
Go slow and take brakes. Use you scissors or exacto-knife for smaller more detailed cuts.
Don't worry about cutting the notches where the pieces go together just yet. I saved that for the next step to assembly line the processes.
Be sure to recycle any scrap cardboard and paper. No point in putting that in a land fill.
Step 4: Cut the Notches out
This part in my opinion is the hardest, but dont let that discourage you.
This is where having an exacto-knife set comes in handy. Due to the varying sizes of cardboard thickness, use the printed lines more as guides vs actual.  Luckily for me I had a square exacto-knife perfect for my cardboard.
Carefully cut out the notches if your cardboard is thicker than the template be sure to center your cuts. (be careful not to cut off or rip piece that shouldn't be, I did but its not a big deal)
Take the paper and tape off, and RECYCLE IT!!!
Step 5: FINISHED. Put it all together
Finishing
Following the guide I have provided, start at the bottom and go to the top putting the pieces in the notches. Its basically biggest to smallest. When I took these photos I switched around 8 and 9 no big deal. I have since fixed it but haven't taken new pictures.
Glue the Shields together
Glue the antlers on
Glue the pop top onto the back of the shield for something to hang it with.
Finally glue the head to the shield
And done, its like your a hunter. you can now brag to your friends that you hunted and mounted your own buck.
Optional
You will notice if you used a box cutter the edges will be jagged. I sanded down the edges to smooth it out.
Other ideas
If you are like me you want something a little different. I am eventually going to spray paint mine, but you could also cover each piece in old maps (http://24.media.tumblr.com/tumblr_ku5dpjz1CS1qzn34eo1_400.jpg). You could also cover it in camouflage duck tape.
With election season coming up you could make this out of corrugated plastic political signs.
The possibilities are endless. Feel free to post other ideas on what to do.
Please post pictures of your deer head.
Final Thoughts
I had a lot of fun making this project, and would appreciate any positive feed back. Feel free to modify the template I have provided.
My hope is to make more projects like this one. Moose head, bull head, maybe even an elephant head? Who knows?
mollldoll says: May 18, 2013. 10:14 AM
Thank you for the great plans! Spent the afternoon making this :)
Imeanhoneybee says: Apr 22, 2013. 5:01 PM
Here's mine, not finished yet because I may have made it a tad too big for our house!
kasaiyuri says: Apr 21, 2013. 9:59 AM
do you think this would work with plywood?
or do you think it would be too heavy?
scarnz says: Mar 27, 2013. 4:44 PM
Does anyone have a template for other animals? Rhino, unicorn...
Flybell says: Mar 23, 2013. 10:50 PM
mounted a horse head today based on similar principles. the clippers are there because I
I'm still waiting for the glue to dry!
iditkosti says: Feb 19, 2013. 1:40 AM
Thanks a lot for the great instructions!
brongier says: Feb 11, 2013. 5:50 AM
I did it on my own... after a long work... and a lot of cutter blades...
Thanks for the template... I am so proud of my deer!
smattson1 says: Jan 29, 2013. 8:23 AM
I put this one together this weekend, fun project, had some leftover paint in the garage so...
borregotv says: Jan 19, 2013. 3:39 PM
Amazing going to try this, also a question how do you design the template? I love to do some other animals too
Thanks
gfxdug says: Jan 8, 2013. 9:35 AM
Thanks for the template! I had a lot of fun making this. Used Black Foamcore & burlap.
marywasadj says: Jan 3, 2013. 5:10 PM
I love this thing SO much! I just made one from USPS boxes! THANKS SO MUCH!!
Marcus Gibson says: Sep 29, 2012. 10:48 PM
Great design, Soupraok. Thanks. Here's a jumbo version, from a jumbo box.
Soupraok (author) in reply to Marcus GibsonDec 14, 2012. 7:14 PM
Did you blow up the original plans?
deesseau says: Oct 23, 2012. 8:13 AM
Thank your for this very nice project. I did mine with scraps of foam sheets, just to try it ; i will do a much bigger one in black foam board soon.
Soupraok (author) in reply to deesseauDec 14, 2012. 7:14 PM
I like the different colors!
rlievens says: Dec 6, 2012. 8:24 AM
Pictures
Soupraok (author) in reply to rlievensDec 14, 2012. 7:14 PM
That turned out great!
rlievens says: Dec 6, 2012. 8:22 AM
Inspired by this tutorial I made my version of this deer head. http://www.cardboardsafari.com/shop/product_cbs1001.php
This is my prototype (plastic). I will maybe upload a tutorial on how to make this :)
catchaba says: Jul 22, 2012. 9:29 AM
Here it is.
Soupraok (author) in reply to catchabaJul 22, 2012. 6:36 PM
That looks amazing! I love the black!
catchaba says: Jul 22, 2012. 9:28 AM
Thank you for the template. Here are my pictures - as you wished:)
Jordan Dyck says: Feb 19, 2012. 6:50 PM
another question how did you re size the pics im not the best at computer stuff
Soupraok (author) in reply to Jordan DyckMar 29, 2012. 8:18 PM
Any photo editing program. Gimp is a good free one.
PeterW1965 says: Feb 23, 2012. 3:35 AM
I would love to do this on a larger scale, but i cant seem to find the PNG file...
Soupraok (author) in reply to PeterW1965Mar 29, 2012. 8:17 PM
Step 1 Last photo
or
http://www.instructables.com/file/F9EXUXBGYKQ5O6M/?size=ORIGINAL
at00263 says: Feb 24, 2012. 9:09 PM
JUST finished this project tonight and I love it! Perfect size and everything (I was worried it'd be too small) Thanks for uploading such awesome instructions~ :)
Soupraok (author) in reply to at00263Mar 29, 2012. 8:15 PM
Good to hear man, I had the same concern when i was making it lol.
bobthebuilder728 says: Mar 25, 2012. 1:55 PM
I made one! Thanks alot for the idea, I was just about ready to give up, it took me 4 hours, but I finished, and its going above my mantle.
Soupraok (author) in reply to bobthebuilder728Mar 29, 2012. 8:10 PM
That looks great man! Good job!
jdaley99702 says: Feb 17, 2012. 12:34 PM
This gives me an idea, I might take your template and put it onto some 1/4 or 1/8 in wood and make it out of that. Nice job
Soupraok (author) in reply to jdaley99702Feb 17, 2012. 8:13 PM
That is what I wanted to do but don't have the proper tools. Let me know how that goes, maybe post a picture when you are done? Good luck!
Jordan Dyck says: Feb 17, 2012. 8:11 PM
hey bud about how many square feet would you say you need to make this thing? i work at Canadian Tire and want to get it all in one go.
Soupraok (author) in reply to Jordan DyckFeb 17, 2012. 8:11 PM
No idea. Really its as big or small as you want to make it. If you have the skills to print. I used halve of a microwave box. Any fairly decently big box will do.
Lorddrake says: Feb 15, 2012. 4:59 AM
excellent job.
now take it to the next step .. using the cardboard as a skeletal support cover it in papier mache, or plaster bandages. Then add some faux fur and presto ... home made lifelike deer head to decorate your wall.
the vengeful aug in reply to LorddrakeFeb 16, 2012. 4:12 PM
Or he could take it even further. He could shoot a real one!
Lorddrake in reply to the vengeful augFeb 17, 2012. 5:00 AM
if he had the tool, skills, and desire to ... I agree
Some people don't hunt, some people don't eat meat, and that is their choice.
Personally I think deer are quite tasty. But if you aren't going to eat it ... don't kill it.
*steps down off his soapbox*
the vengeful aug in reply to LorddrakeFeb 17, 2012. 6:07 AM
Yeah I was kidding. But we eat everything we shoot and it tastes pretty good.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
