Introduction: DIY Cardboard Laser Piano , Cool !
Picture of DIY Cardboard Laser Piano , Cool !
ElecFreaks will show you a guide how to make a cardboard laser piano by yourself. By this way, I think you do not only could make piano , you can transform a table , a window or a wall to be a Laser Piano or a Laser Harp .
The Cardboard Laser Piano was based on Arduino UNO, with photosensitive modules, laser emitting diodes, JQ6500 voice module combined, the simple electronic piano detects high-low level current outputted by the adjustable photosensitive modules via laser radiation, thereby sending different orders which represent different notes to JQ6500 module. Users can replace notes and songs anytime, only they’ve downloaded the pre-recorded audio into JQ6500 module in advance.
The simple electronic piano can be easily ported to Raspberry Pi and other open source platforms. It’s easy to operate and convenient to DIY.
You can get some of the parts from our store.
1. USB mini audio
2. Sol gun
3. JQ6500 voice module
4. Adjustable photosensitive modules
5. The laser emitter
6. Knife
7. Box for installing the laser emitter and the photosensitive modules
8. Freaduino UNO
DownLoad
  1. Piano Audio File
  2. Arduino Demo Code
Step 1: ​Poke a Line of Holes in the Box for the Laser Emitter Installation With the Knife.
Picture of ​Poke a Line of Holes in the Box for the Laser Emitter Installation With the Knife.
Step 2: Weld the Laser Heads Together in Parallel With a Soldering Iron.
Picture of Weld the Laser Heads Together in Parallel With a Soldering Iron.
Step 3: Mount the Laser Emitters to the Holes and Fix Them by Sol Gun.
Picture of Mount the Laser Emitters to the Holes and Fix Them by Sol Gun.
Step 4: ​Fixed
Picture of ​Fixed
Fix the adjustable photosensitive modules on the other side of the box. Make sure that the laser emitted from the laser head should be directed at the photoresistances on the adjustable photosensitive modules.
Step 5: Fixed2
Picture of Fixed2
Lead the photosensitive modules to the outside of the box via DuPont lines, connect them in parallel via the soldering iron and fix them via the sol gun.
Step 6: Insert the Photosensitive Module Into Freaduino UNO
Picture of Insert the Photosensitive Module Into Freaduino UNO
Note: The simple electronic piano gets the signal pins of the photosensitive modules access to D4, and then D10 on UNO. Learners can choose different IO ports according to their actual situations.
Step 7: Plug the Voice Module in Freaduino UNO and the USB Audio in the Voice Module.
Picture of Plug the Voice Module in Freaduino UNO and the USB Audio in the Voice Module.
Note: Wiring the voice module with UNO as shown in the following table
So far, the building of the simple electronic piano is completed. Power up and download the codes, start to enjoy the audio feast it brings.
Carnage2089 (author)2015-08-20
Does this work with the arduino uno?
abigail.j.roden (author)2015-04-10
It would be nice if you could put a pinout and better pictures so we could see how to actually build it instead of just guessing and hoping for the best outcome.
goldenshuttle (author)2014-12-28
great project. I wonder how can you ensure laser hitting on the sensor, because cardboard is not stable. Did you try a softwood box maybe more rigid ?
hohum (author)2014-11-17
nice tut thanks for posting, please check step three, i think you meant glue gun to afix modules to card board
jdawg99 (author)2014-07-07
I love that idea!!!
Wow, this is so cool! Nice job!
About This Instructable
4,891views
17favorites
Bio: ElecFreaks is an open design house founded in March 2011. Our goal is to create rapid prototypes and give small-batch manufacture solution for makers and ... More »
More by ElecFreaks:Elecfreaks Motor:bit User GuideCreate an Electric Spirit LevelHC-08 Bluetooth UART Communication Module V2.4 User Guide
Add instructable to:
