DIY Cardboard Night Oxygen Planter
1,962
55
Published
Introduction: DIY Cardboard Night Oxygen Planter
About: Always pass on what you have learned. https://www.youtube.com/yodha4u
DIY Cardboard Oxygen Planter with Snake Plant or Mother-in-Law's Tongue (Sansevieria Trifascia).
It’s a common ornamental plant and it significantly increases the oxygen density in our bedroom and gives a better night’s sleep.
Characteristics of Snake Plant or Mother-in-Law's Tongue (Sansevieria Trifasciata)
Air-Freshening Qualities.
Low Water Maintenance.
Gives Oxygen in Night.
Removes Contaminants from Air & Produces Large Amounts of Oxygen.
Items Required for Planter
1. Two Square/Rectangular Shape Cardboard.
2. Adhesive Tape
3. Scissor
4. Cement & Sand
5. Wooden Sticks, Some Plastic Wire
6. Regular Potting Soil Mix
7. Plants { (I used Mother-In-law's tongue (Sansevieria Trifasciata) }
Step 1: Needed 2 Cardboard Box
Required 2 cardboard box's, make sure they are in good condition.
Step 2: Add Adhesive Tape Smaller Cardboard From Outside
Use any adhesive tape and cover the entire box with tape. Make sure no place is left, add more layer in center and corners.
Note:- Add more tape on center and corner for the strength.
Step 3: Add Adhesive Tape on Bigger Cardboard From Inside
Same process is repeat, this time cover the entire box from inside and make sure no place is left behind, repeat the layering if necessary.
Step 4: Prepare Concrete Mix
Add Cement and Sand in 1:2 ratio, after adding cement and sand mix them well before adding water.
pour water slowly and make a good thicker mix.
Note:- Use a plastic cup for equal amount of cement and sand mixture.
Step 5: Apply Oil on Smaller Cardboard
Apply oil on outside of smaller cardboard box, Apply on adhesive tape portion.
Note:- Use any veg oil
Step 6: Apply Oil on Bigger Cardboard Box
Repeat the same process, apply oil on inside of bigger cardboard box.
Step 7: Use Wooden Stick for Supporting Mold
Use wooden sticks to prevent the mold from expanding there shape, Put stick in center of the cardboard and make a knot on all corners with plastic wire.
Note:- Do not make tight knot otherwise you end up with ruined shape of cardboard.
Step 8: Add Concrete Mixture
Now place a stone in center of the cardboard base and add concrete mix, filled the mixture until its level up with stone. thereafter gently put smaller cardboard in the center, Add some heavy objects to hold the smaller cardboard in center. Then add concrete mix from side and shaken up or vibrate the board after filling concrete or inbetween.
place a more heavy object and cure the concrete for 24 hours.
Step 9: Removing Cardboard
After 24 hrs of curing concrete, Remove the cardboard.
Note:- Use sand paper for sanding more smooth surface.
Step 10: Add Plant
Put stone just above drainage hole and add potting soil, make a small dig inside the planter to add both plants after
adding plants water them slowly.
Note:- Use regular potting soil and use tap water.
Step 11: Final Look
I am pretty excited with the end results and the planter looks awesome on my table adding night oxygen planter to the room gives me real excitement.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    2 Comments
    Nice and easy way to build a mold if you are not willing to spend money on wood.
    I think it can look very interesting because of that imperfection in shape, every planter will look slightly different.
    yes, I'm pretty sure every time it come up with new shape.
