DIY Cat Scratching Post
3,094
34
6
Published
Introduction: DIY Cat Scratching Post
My friend said she wants to buy a scratching post for her cat, and I said "I can do it for you, you don't need to buy."
Step 1: Materials and Tools
Materials,
A cardboard tube, 500 mm length
10 m rope, (I chose jute rope, which is not synthetic)
Adjustable cabinet foot (I cut mine so that it can fit inside the tube),
500x500x10 mm MDF,
screws, suitable to cabinet foot and MDF
piece of fabric,
a thick cardboard, same dimensions as MDF,
A jar lid, same diameter of cardboard tube.
Tools,
Hot glue Gun,
Screwdriver,
Scissors.
Step 2: Base
1. Assemble the foot to the center of MDF board.
2.cut a hole to the center of cardboard with the same diameter of tube.
3. using hot glue, fix the cardboard to the MDF. hole in the cardboard should face the cabinet foot.
4. Cover it with fabric using hot glue. Make a hole in the center.
Step 3: Post
1. Fit the other part of cabinet foot inside the tube and fix it using hot glue.
2. Wrap the rope around the tube. Hot glue can be used to fix the rope at some points.
3. Cover the jar lid with the fabric.
4. Place the lid to the top of the post using hot glue.
Step 4: Assembly
Put together the base and post. Since an adjustable foot is used, post and base can be separated for easy transport and/or storage.
Edit: Final product and target customer...
    • Make it Move Contest
    • Stick It! Contest
      Stick It! Contest
    6 Comments
    I designed and made a cat scratching post myself, and covered 2 posts (tubes) with jute rope. A third post I covered with a scrap of loop pole carpet. The cats have never even touched the jute, but I've had to replace the loop carpet twice already. They rip it to shreds. The jute was pretty expensive and a waste of money. Are my cats just contrary, or did your cats like the jute? Thanks. Your tube to base attachment hardware was better than mine.
    Cats can be brats and very contrary. Maybe try misting it with catnip spray?
    I thought that, too.
    Sorry I just saw your comment.
    I made it for m friend's cat, and she says the cat doesn't touch it :D But I hope he will learn how to use the post.
    Thank you.
