Introduction: DIY Cat Water Fountain
Whenever I go to the refrigerator to fill up a glass of water, my cat BoBo runs as fast as he can to get a sip. Whenever he hears running water he runs to see if he can have any. He is crazy about water. I usually fill up old water bottles and he drinks out of them, so I thought why not make something to do it for me.
With a fountain from Salvation Army for 3.99, some popsicle sticks and a hot glue gun, this project was cheap, easy and fun. If you don't have a cat, it also serves as an elegant fountain with a beautiful sound.
Step 1: Disassemble the Fountain
The best part. With a hammer and five minutes, I had the fountain apart with just the bottom and the pump left.
Hot glue the pump to the bottom of the base and your all set for now.
Step 2: Assemble the Fountain
Once you have the pump glued to the bottom and the hose sticking up, grab and old bottle and cut a hole big enough for the hose. Using popsicle sticks and hot glue, position the bottle however you want it. Once it's in place, put the hose in the hole you cut. Now use hot glue and seal the hole so no water leaks out. This is important so that you don't end up with a mess.
I used some extra popsicle sticks to cover the back half of the base as you can see. It makes it look a little bit nicer.
Step 3: Wait for Cats
Now for the easiest step...wait for the cats. As soon as Bobo heard that water he ran to get some.
I hope you enjoy this instructable as much as I did making it!
Good luck!!
Good luck!!
