Introduction: DIY Cedar Fishing Lure
Picture of DIY Cedar Fishing Lure
This lure can be made in under an hour (not counting the painting process) and for about the price of a piece of cedar kindling. Warning: knives and drill presses should not be taken lightly. They can be dangerous.
Step 1: Cedar
Picture of Cedar
Get your kindling.
Step 2: Draw
Picture of Draw
Draw the outline of what you want to make. Here I am making a cigar shaped top water lure.
Step 3: Carve
Picture of Carve
Begin your carving. Be careful, knives are sharp.
Step 4: Saw
Picture of Saw
Once you get it fairly round, saw your carving off of the kindling.
Step 5: Drill
Picture of Drill
Put a dot in the middle of each end. Because small drill bits aren't very long (I used a 1/16 drill bit) you will probably have to go from each side. After drilling, stick your wire through to make sure the holes connect.
Step 6: Carve, Then Sand
Picture of Carve, Then Sand
Shape your lure and then sand it down.
Step 7: Wire Time
Picture of Wire Time
Twist the wire as shown.
Step 8: Repeat
Picture of Repeat
Repeat the last step on the rear of the lure and put a split ring on it. Then put a hook on the split ring. Now all that is left to do is paint it, put I'll leave that up to you.
omega65 (author)2014-08-27
Nice work I've been making and using my own lures for years. Your methods are very good. There are lure making part sources on line where you can get the wires and hooks. I like a double hook. Good luck!
safernandes (author)2014-08-25
Nice one!
Just need some help, tell me what wire do you use? and what gauge?
tetra28 (author)safernandes2014-08-26
i'm not sure what gauge of wire i used because it was just a scrap, but try to find something that doesn't bend very well without pliers.
safernandes (author)tetra282014-08-27
Thanks.. :-)
Got a length of 1.5 mm 306 Stainless Steel from the market and am gonna try to use the small file handles for the body of the lure.. will post when done..
JM1999 (author)2014-08-24
Is that a Buck 110? I love the Buck brand, they hold their sharpness for a long time!
tetra28 (author)JM19992014-08-26
Yes i love my buck knife too. I would recommend them to anyone.
Flash67 (author)2014-08-26
Can you only make top water lures with these or can you also make normal lures like this?
tetra28 (author)Flash672014-08-26
They don't have to be made of cedar, but i find that cedar carves well, has nice lifelike movement, and is plentiful. To your other question, you can make any lure you want! Even this lure pictured can go down by just adding a split shot. The purple and black one with the homemade copper lip on it goes down to about 10 feet and stays there.
And can they only be made out of cedar?
boetting (author)2014-08-24
They look like top-water stick baits, mostly, 'cept for the one with the spoon and the segmented one. What kind of luck do you have with them? I'm not good at top-water but the idea of making a stick bait and catching a bass on it is intriguing.
lilchumy (author)2014-08-23
Nice lures, I would recommend treble hook, I know they are not as easily found but it could make a difference of catching something.
johnstat000 (author)2014-08-23
Hope you catch something big!
MsSweetSatisfaction (author)2014-08-23
The lures turned out really nice looking. Also what a great use for scrap wood. Thanks for sharing!
About This Instructable
8,463views
219favorites
License:
More by tetra28:DIY Cedar Fishing LureDIY Altoid Fly BoxDIY Dubbin Needle
Add instructable to:
