This is pretty similar to the instructables on how to create a whiteboard using the Wii Remote,
but I wanted something I could sit on my lap and move around. I can work a lot more intuitively if I can move around the surface I draw on. I came up with this
Remove these ads by
Signing UpStep 1Materials
http://www.instructables.com/id/Wiimote-IR-Pen/
http://www.instructables.com/id/Wiimote-Whiteboard-IR-Pen/
In order to create the display, you'll need these things:
1 x Flat Panel monitor
1 x Wii Remote
1 x 60cm length of PVC pipe (about 4cm diameter)
1 x 10 cm length of PVC pipe (about 4cm diameter)
[not shown]
An Infra-Red Pen
Some masking tape
a bluetooth capable PC with an external monitor connection
WiiWhiteboard software from Johnny Lee's site - http://johnnylee.net/projects/wii/
The latest Smoothboard version also has a floating toolbar whichprovides additional shortcuts for triggers depending on the softwarethat you are using.
Regards,
Boon Jin
www.smoothboard.net
However, since I wrote this I've started using Smoothboard, which allows you to connect two wiimotes at the same time, and assign shortcut keys to various buttons. Wiimote 1 is used to detect the pen. Wiimote 2 is used to handle common keyboard shortcuts. I find this a hugely efficient way to work, often faster than having a keyboard and mouse, or even a keyboard and tablet.
That said, people on related forums, including johnny lee himself, have said that webcams really arent as effective as the wiimote at tracking IR, so its best to stick with wiimotes!
Its great!
You can try to use Smoothboard http://www.smoothboard.net to get your shortcut keys. The outside screen area can be used to trigger keyboard keys.
Hope it will function well for you.
Regards,
Boon Jin
I thought from the second picture on http://www.smoothboard.net/features that both wiimotes were pointed at the screen, and that they combined for a better viewing angle and better accuracy? The set up I have works quite well, but sometimes it gets a little jittery.
I will definitely try it out tonight, with one wiimote for tracking, and one for controls!
