3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Cintiq Tablet using Wii Remote
Step 6Invert your desktop, connect VGA cable and connect wiimote via Bluetooth
Once everything is put together, connect your wiimote to your PC and run Johnny Lee's WiiMote Whiteboard Application. - http://johnnylee.net/projects/wii/
Calibrate the IR pen and voila! You have a Homemade Cintiq!
Here's a video of me using it. The only thing wrong with this arrangement is that the laptop needs to be close by so that the shortcut keys are accessible. It'd be nice to have some controls on the monitor that could be set up to act as shortcut keys. I'm thinking it might be possible to join up a second remote and bind the buttons to a few common keys.
Anyway, have fun and let me know if you do the same thing!
6 comments
Jul 2, 2010. 5:43 PMFuingurth says:
Or you could use the on screen Keyboard on windows. On XP its under Accessories>Accessibility>On-Screen Keyboard.
Sep 10, 2009. 10:52 AMiProton says:
Did it. Except I made an IR glove. There is a positive contact on the thumb and a negative one on the index finger, the LED is situated somewhere on the index finger's nail. I also use 2 displays, the main display, that is unaffected, is the iMac display, the second one is Asus, that I placed flat down on the table. The WiiMote stand is made out of LEGO and strapped to a coat hanger that I screwed to the bookshelf above my computer. I planned on making a second one, for 3D-ish interface work, but my current budget doesn't look forward to it.
Apr 14, 2009. 6:10 AMboonjin says:
Hi,
Its great!
You can try to use Smoothboard http://www.smoothboard.net to get your shortcut keys. The outside screen area can be used to trigger keyboard keys.
Hope it will function well for you.
Regards,
Boon Jin
Apr 14, 2009. 8:24 AMboonjin says:
Hi roryok, Currently, it supports up to two Wiimotes. The second Wiimote can be used as for the whiteboard portion (pointing at the screen) or as a Presenter Wiimote like you have mentioned. For your setup, why do you need an additional Wiimote to face the screen? Blockage by fingers? It already looks great. :) Regards, Boon Jin
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:roryok
