DIY Clap Switch 555 Timer
Published
Introduction: DIY Clap Switch 555 Timer
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Todays instructable is about How you can make a clap switch
Step by Step Complete Guide
DIY In 6 Minutes
A clap switch has its many important applications some uses for security purposes some uses to control home appliances but i made it simple you can also add a relay to control high power devices .
The circuit i made is tested many others on Internet wont work i tried so many but this one is working fine.
WORKING DESCRIPTION.
A simple 555 used in monostable mode when the clap sound is detected by Mic it HIGH the input signal due to which the output of the 555 timer triggered .But due to its monostable state it again backs to its initial state by discharging through a electrolytic capacitor
You can adjust the capacitor value for how much time the switched should be ON and OFF by applying different types of electrolytic capacitors note a 10uf discharges fast compared to 47uf
Step 1: Hardware Required
All the hardware also given in the Video ...
Check it
Step 2: Breadboard Connections
Make all the connections as shown in the circuit diagram..
Step 3: Check It Out
CHECK OUT MY WORKING VIDEO HERE
A COMPLETE GUIDE ALSO GIVEN IN THE VIDEO DESCRIPTION........
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
