3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Coin Cell Holder
Ever need something to hold some small batteries for a project you're working on? Here's how I modified an N type battery holder to accommodate a few of those coin cell batteries.
Ingredients:
coin cell batteries
Tools:
sharp wire cutters
super glue
clamp
Step 1With A Little Help From My Friends
Having picked up some 12v batteries and performed a little surgery a la Kipkay, I needed something to hold a few of the cells for a project I'm working on. In case you haven't seen it, check out his "12 Volt Battery Hack!" Instructable for more information.
The A23 battery fits very well in an N type battery holder (keep that in mind for the future), but I only need 4.5v. Just three of the cells inside the battery will work well. But three cells definitely will not fit in this holder. Let's cut it down a bit.
45 comments
1-40 of 45next »
Jul 15, 2009. 5:51 PMArbitror says:
I've never heard the term "Coin Cell" before... Is it European? In Canada (and in the US I think) we call them "Button Cells"...
Oct 2, 2009. 12:42 PMJodex says:
I say coin cell always when I speak English, but in Finnish it's nappiparisto (nappipatteri) and "nappi" means button and "paristo"(or "patteri") means Battery.... So straight from Finland button cell and maybe in English coin cell :D
Sep 17, 2009. 1:27 AMGonazar says:
I think the terms go button cells for smaller batteries as shown in these images, they're smaller than a half inch or around there
coin cells look like quarters, they're much wider diameter and thinner. most commonly used in motherboards for computers and LED throwies =D
Aug 25, 2009. 10:06 AMa2sidedcoin says:
lol, me too funny enough, and coin cell made perfect sense.. :) Do you know if they make a button cell stack for 6v?
Sep 22, 2009. 10:56 AMktalex says:
pretty smart i hated those little batteries.
Jul 14, 2009. 9:48 AMalex-sharetskiy says:
it looks a little funny : )
Jul 21, 2009. 1:24 PMChromatica says:
they are the only mammals to lay eggs
Jul 21, 2009. 7:53 PMChromatica says:
I have two types of bills, but they still aren't attached to my noes
Jun 19, 2009. 7:01 AMRazorConcepts says:
Now someone needs to come up with a DIY holder for the standard 2032 batteries. You can get those for 15 cents each but the holders cost more than 1 dollar!
Jun 23, 2009. 10:23 AMRazorConcepts says:
DealExtreme
Jun 25, 2009. 5:52 PMRadioactive_Legos says:
That's why RadioShack sucks. Over $5 for one! I got mine from the "Let it Glow" contest a few months back.
Jul 1, 2009. 2:52 AMpaewookyung says:
Yes. I notice that before....they are selling 7805regulator for $1.59 which I could get it on the local electic shop under 50cents -_-...
Jun 19, 2009. 7:37 AMrichelton says:
I've used standard office binder clips for button cell batteries in many projects. Just use a plastic layer to insulate one side of the battery from the clip while still using the clip's pressure to hold in place one of the leads. You can even solder the binder clip itself to a lead, or drill a small hole in the binder clip to hold a terminal screw.
Jun 29, 2009. 1:42 PMThreeshirts says:
Great suggestion richelton! I posted a question several weeks ago looking for good cheap button battery holder ideas. This fits my needs perfectly. Thanks for the suggestion!
Jun 24, 2009. 11:18 AMBartboy says:
Copier type person!
Jun 22, 2009. 5:23 PMrobotguy4 says:
GENIUS!
Jun 21, 2009. 4:35 PMZem says:
Cool! I've been looking for a way to make holders for all those little cells. I've found from experimenting that AAA battery holders work for some too.
Jun 21, 2009. 8:09 AMcarlo$ says:
ahhh. Thanks for your explanation. Excellent idea, I must have missed where you explained 4.5V. Now it is clear to me what your objective was, to get 4.5V. My bad. You got my vote.
Jun 19, 2009. 2:31 PMWyit says:
Beatles fan huh? This is a good Instructable.
Jun 19, 2009. 9:37 PMnotveryreal says:
Aw, I was going to say that. :[
Jun 20, 2009. 10:40 PMookid says:
OK, That is officially awesome! I just started looking for it and I figured it out... :)
Jun 19, 2009. 9:39 AMjsgraham says:
I use the four 357 sized button cells to power an altimeter in high power rockets. They're lined up in an N-cell battery holder. Instead of holding them in place with hot glue, I use heat shrink tubing cut to size. Heating it is not necessary if you get the correct size. The cells hold very well even under stress of up to 12-G's.
Jun 20, 2009. 1:40 PMjsgraham says:
What I do is use a tube of heat shrink long enough to hold the button cells. Then you can do one of two things. You can tape the cells into the N-cell holder, with black electrical tape. Or you can find a piece of heat shrink tube large enough to encapsulate the entire holder and cells. Down side to the second options is you have to cut the tubing off each time you replace the cells.
Jun 20, 2009. 8:25 AMcarlo$ says:
Excellent idea. Here is my opinion: since the batteries are in parallel it doesn't matter how many you use. Why don't you put in as many batteries as you can fit in the holder without cutting it? In fact the more batteries the more current you get and the longer your "project" will work. Weather you have three or five batteries (since they are in parallel) the net output voltage will be the same. If the batteries where in series then this project would make more sense. This would be a very useful project if space is an issue. It is not clear what your object was. Great idea thought.
Jun 19, 2009. 3:23 PMWeissensteinburg says:
They're so cute!
Jun 19, 2009. 11:15 AMthepelton says:
One thing that occurred to me is that most of these button cells are about the same size as a lot of pills. You could save those plastic and foil holders for pills, and drop button battery cells in the places of the pills. Just keep the whole thing out of the reach of a small child.
Jun 19, 2009. 5:56 AMuguy says:
I think these are "Button" cells, not "Coin" cells.
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
79
Author:pdub77
'eclectic' is a good way to start. . . I like to build things, make things, take things apart and mod things. No matter what, though, humor is the best medicine. And I can't believe how many times I...
more »
