Step 2We Can Work It Out
You can use a small fine toothed saw to cut out the bit of battery holder. If your saw is in a storage unit somewhere like mine is, a set of sharp wire cutters will work as well. Just cut down the sides, fold the base back and cut through that as well. I used a Dremel tool with a sanding band on it to clean up the edges and make them straight. Leave a bit extra with each cut to allow for this sanding.
Add Comment
