DIY Cold Cathode Lamp
The Ultimate lamp for any die hard computer user. This is a pretty simple process to build and I was really satisfied with my end product.
Now like any computer mod project I do have a worklog posted here so you might find any questions you need already answered here..
DIY Cathode Worlog
Step 1Supplies and the first steps
The material
- 3/4 inch Dowel
- Wood, I used 1x6
- Cathode and inverter
- CDs - preferably some economy ones with reflective layers on both sides.
- Acrylic tubing. Link here
- plexi glass
- PSU micro atx is preferable
below is the general prototype of what we're aiming for
First step is to cut your wood. You can cut this to any real length you want. I ended up making my box about 5.5 x 5.5 x 5.5 so make sure you cut all of your wood to fit which ever size you want. You will have three pieces the same because these will be the top and bottom of your base as well as the top piece of the lamp. Then you will have two pieces for the sides, and one piece for the back.
53 comments
1-40 of 53next »
Feb 24, 2011. 10:36 PMwilbster says:
I know this is an old post, but instead of using a power supply couldn't you use a small power inverter? The lamp does output at 12 volts, right? I am only curious, because I am thinking about building one.
Nov 15, 2010. 11:58 AMMadScientist101 says:
whats a psu?
Jan 7, 2011. 11:30 AMmaewert says:
Power Supply Unit
May 14, 2007. 12:00 AMpmilg says:
I have well over 1500 AOL CD's any ideas what I can make with that many?
Jun 7, 2009. 1:52 PMReCreate says:
Make an Exploding EPIC Tesla TURBINE! :P If you spin them at 22000 RPMS It Explodes! Plastic AOL Cd Shards everywhere!
Aug 17, 2008. 3:28 PMJunkyard John says:
A search on a site called instructables.com might give you some ideas.
Feb 10, 2008. 9:09 AMneotom666 says:
send them back!
Sep 26, 2007. 5:19 PMKataze says:
You could make the exact same number of any of the following items: Frisbees Shurikens Otherwise deadly spinning object Broken CDs Pocket Mirror XD
Sep 3, 2007. 12:18 PMARVash says:
a small tent
Oct 4, 2007. 4:00 PM!Andrew_Modder! says:
a RICK rhombus. :-)
Dec 31, 2008. 10:28 PMShut Up Now says:
OMG!! Computer Geeks using power tools!! i see TROUBLE!!!
Jan 22, 2008. 5:36 AMtbird45039 says:
it would be easier to just use a 12 volt dc power suply. than craming that psu in there
Dec 22, 2008. 9:17 PMiBurn says:
His way's cheaper.
May 9, 2007. 9:33 AMdigitizelife says:
Oh man... this just gave me a great idea! Change the cathode to a UV cathode, swap out the CD's for hard drive platters, wire them up to a transformer, and you have yourself a DIY bug zapper! For the circuit, every other HD platter should be + and - so if something comes between any two plates, the circuit can arc through the object to complete the circuit. Two sets of coils, one heavy gauge surrounding a light gauge, with an AC pulse on the large coil, should induce a very high amp pulse into the smaller coil which is wired to the platters. If the platters come close enough, or something is placed in between them, an arc will occur. Someone more qualified with electronics could verifiy this and/or suggest an alternative
Dec 7, 2008. 10:22 AMXellers says:
Unfortunately that wont work for a few reasons: 1) UV light doesn't attract the types of bugs you want to zap (a mosquito will fly right by UV light without landing) 2) Bug zappers have two grids and the bug comes between them and completes the circuit. If you were to make each of the platters charged positively or negatively, then you would need some very high voltage. Unfortunately, you would have to worry about corona leakage, and the wires leading to each platter would have to have about 2 inches of insulation on them because high voltage jumps right through normal insulated wire. 3) Other than that (solvable problems), it would cost less to go out and buy a conventional bug zapper than to make one from this lamp.
Sep 11, 2008. 9:47 PMiBurn says:
Sombody better post an instructable on that...
Aug 17, 2008. 2:19 AMYerboogieman says:
i broke my Cathodes while camping, but, just the filament, not the casing, anything i could do with those?
Sep 1, 2008. 12:46 AMthermoelectric says:
Filament?
Sep 1, 2008. 3:29 PMYerboogieman says:
inside glowey thing?
Sep 1, 2008. 10:22 PMthermoelectric says:
I didn't thing cold cathode tubes had filaments, Just my 2 cents, i'll check it out now
Sep 2, 2008. 6:48 AMYerboogieman says:
yea.
Sep 2, 2008. 2:10 PMthermoelectric says:
You sure the 'filament' is on the inside, mind taking a picture?
Sep 2, 2008. 3:24 PMYerboogieman says:
yep the light emitter.
Sep 2, 2008. 10:46 PMthermoelectric says:
But they look like they still work?
Sep 3, 2008. 8:17 PMYerboogieman says:
thats when they did work..:-(
Sep 3, 2008. 9:59 PMthermoelectric says:
BTW, what type of battery did u use to power them?
Sep 4, 2008. 6:18 AMYerboogieman says:
duracell ultra alkaline
Sep 4, 2008. 2:35 PMthermoelectric says:
Hehe i thought u used a small SLA battery
Sep 4, 2008. 4:55 PMYerboogieman says:
huh?
Sep 4, 2008. 10:35 PMthermoelectric says:
Sealed Lead Acid, Like a car battery but are smaller
Sep 3, 2008. 9:58 PMthermoelectric says:
can u take a pic of them now?
Sep 4, 2008. 4:56 PMYerboogieman says:
my dad brought his truck home, they're in his car.
Sep 8, 2008. 12:51 AMthermoelectric says:
has he got his car now?
Sep 8, 2008. 8:45 PMYerboogieman says:
there they are, thats my old bike, i posted pictures of what happened to it, my neighbor gave me a new bike, so i piecing this one for parts and putting them on that one, same style frame, different brand.
Apr 14, 2008. 9:26 PMajmontag says:
its not properly grounded, as the metal casing of a PSU is added ground protection, i have used PSUs for a 12v power source, and chopped off a female molex (4 pin) connectior and ran wires off of that from the PSU, leaving the PSU untouched, just jumping the purple (?) and ground wires to get pwr. let me know if you want better details.
Aug 12, 2008. 5:59 AMlivesteamfan says:
Green to any ground wire.
Dec 24, 2007. 11:02 AMoptimized4perfection says:
i have an insect killing thing that looks exactly like that
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:faceless105
