Step 6The face plate
In the plexi we'll be mounting the power switch and drilling some holes for ventilation. First to cut the plexi I recommend the crack and score method. Simply drag a razor blade in a straight line across the plexi 5-10 times depending on how sharp your tool is. I recommend using a straight edge. Then bend the plexi and it will snap along the guides you just cut.
Next drill a hole to mount the switch. And some more holes for ventilation. Make sure you have clean cuts, I recommend using a drill press to keep the holes extremely evenly spaced, a hand drill might wander and look bad.
Finally, to wire the switch, take the green wire from the Motherboard Connector and a ground wire and wire them to your switch. Once this is done, you'll have finished your front panel.
Add Comment
