3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Cold Heat soldering iron
Step 10Wrapping it like a present...
Thoughts and ideas.. I'll add things here as I think of it, or as I discuss with people. I'll also post updates of further experiments and improvements.
The lead could be extended and if used carefully, it could be used to solder in places that many traditional irons could not reach.
This could be made into a tweezers. Pinching the part between the leads. Neato.
I should just replace the jumper wire on the power supply with a switch.
I could probably replace the PC supply with a battery pack. Sure, I would make it something like three car batteries on my back, but a few AA might work.
The tip does cool nearly instantly. The carbon radiates the excess heat off really quickly.
The middle spacer on the tip should really be something that won't melt. Let me know if you have any good ideas.
EDIT: Regular glass.. why didn't I think of that....
To regulate the power to the tip, I could use a simple rheostat. Something like a dimmer switch or the pedal from a sewing machine.
This is just a first pass at making something of this sort. Its delicate and somewhat unwieldy at the moment and I broke the lead at least three times while I was testing things. I leave it to you to make a better one. If I don't do it first.
I have now procured (Dumm dum dummmmmmmm) Two AA batteries I am going to strip for the carbon cores. If it works out OK, I'll update with pics and such.
This was fun and cheap.
Many thanks to my lovely future wife Jackie for picture-help. Come check out our other strangeness:
http://www.lovesickrobot.org
http://photozz.wordpress.com/
44 comments
1-40 of 44next »
Feb 14, 2011. 4:40 AMturbojet says:
If I can have an advice, you should replace the PC power supply with anything else, because it wastes lots of energy (at least ATX does). 10-15 Watts are quite enough for soldering, and since you built a soldering device, the new power supply can be built easily.
You'll need a casing, 230 VAC male connector with a cable, a 230 to 5 volts transformer, 4 diodes (5V 4A) for a graetz-bridge, a Zener connecting the 5V circuit to the ground for your safety, and a - let's say - 4A fuse also for safety. I assume you know how to build a simple power supply out of this. Then you just connect the output of the circuit to the soldering iron through a switch, push-switch, potentiometer, goldfish, goulash, testicles, whatever you want. The power drawn from the network will approximately equal to power used for work, and no power loss on monitoring and control circuitry will be introduced.
Jan 7, 2009. 12:39 AMPJA says:
Instead of struggling to cut grooves in hard, brittle dusty stuff, leave the insulating spacer flat and cut the grooves in the copper.
Feb 6, 2011. 1:38 PMyour_dragon113 says:
I used single-sided PCB for mine....worked out VERY nicely, and there's always enough of it to be found ;)
Sep 6, 2009. 9:45 AMrobmeofmyboredom says:
why dont you just use regular pencil graphite? its not too hard to remove and is way thicker and can be shaped to different points. also have you tried running anymore than 5 volts? i wanna see what happens with 12...
Sep 26, 2010. 2:36 PMsora says:
12 volts the pencil lead smokes...alot
Sep 30, 2009. 2:46 PMeyerobot says:
This is an excellent idea, And a fine instructible. I'll be actively testing materials for use on this project. If I find anything useful, I'll post it here for everyone.
Jan 13, 2009. 2:24 PMManifoldSky says:
BTW, an original, old application for this is as cigarette lighters while in jail! Don't ask me how I know ;-x
Jan 14, 2009. 7:51 AMManifoldSky says:
Well, mine was for not having a dog on a leash! (Yeah, don't mess with me,)
Jan 14, 2009. 2:28 PMcd41 says:
mine was for loitering im the true badass around here
Jan 14, 2009. 3:18 PMManifoldSky says:
Well, mine was actually (no lie) for having NINE dogs out without a leash. I did not even own nine dogs! I was in the hooskow for 3 F#$%& days. Viva la Revolucion!
Got to see lotsa people using dismantled pencils to light illicit cigarettes by sticking them in electric outlets for vending machines, though
(see how gracefully I brought it back on point?)
Jul 28, 2009. 6:44 AMjunkfactory886 says:
Mine was for walking my pet deathbot without first disarming his laser. He destroyed three city blocks, and i got three years in the clink. Yeah, don't mess w/ me.
Jan 16, 2009. 6:57 PMthreewingwonder says:
hey! nice work here....I absolutely love the Idea, I design and build robots and this would work perfect. Food for Thought........What about using some formed JB weld for the tip insulator? Its non-conductive and seriously strong......Just a thought
Jan 17, 2009. 7:55 AMthreewingwonder says:
I am working on a security bot noe , It looks similar to Johnny 5. It roams the house checking for locked doors and windows and smoke and fire and intruders, if smoke or fire or intruder is detected -it calls my cell and my wifes cell and 911. It has voice capability with a voice chip. all done with a Basic Stamp2 microcontroller.
Feb 3, 2009. 2:14 PMqwertyboy says:
JB Weld can withstand up to 600 degrees farenheight before it starts burning and smelling really bad. btw, i have that same multimeter that's in the background. lol
Jan 17, 2009. 7:50 AMthreewingwonder says:
We use it on engine blocks, rods and things on an engine and they heat up quite a bit. Anyway it was just an idea. I design and build all kinds of things. I havent done an Istructable because I dont have the time cause I always building and designinglol
Jan 21, 2009. 10:57 PMsensoryhouse says:
I think you should share your ides with us threewingwonder! now, how about that 'ible?
Jan 22, 2009. 3:16 AMthreewingwonder says:
I am working on an ible for a set of Driveway marker lights. They use another ible called "a Joule thief", a homemade solar panel, a white LEDand some other bits.The lights are alreadyup and running , I am just updating them . I am still working on it , but it will be here soon.Stay tuned!!
Jan 13, 2009. 5:55 AMManifoldSky says:
Not sure why you are going to all the trouble to cut the leads from the PSU and reconnect them with tape or wire nuts. Just wire the two ends from the iron to a spare male connector (get it from the same crappy PC you got the PSU from) and then attach to the female connector from the PSU. That way you can disconnect from the PSU when needed, and you don't have it bouncing around when you want to move things around. Just a thought.
Jan 13, 2009. 2:07 PMManifoldSky says:
You apparently do not own a ball peen hammer. Actually, I have found that any hammer does the job quite nicely.
Jan 13, 2009. 10:17 AMManifoldSky says:
And after a quick trip to the plastic surgeon for the sex change operation, you're all set (i.e., whoops reversed the genders of the connectors down there. Nothing a little intense Freudian psychoanalysis can't make worse.) This can also be interpreted as: this site needs an edit function
Dec 20, 2008. 9:35 PMMrs. Trydle says:
I used a curling iron, for most of the build, it has a built in thermostat, on/off button, and the pieces inside the barrel were perfect for attaching the leads. I had a short in my psu, but no soldering iron to fix the loose connection. Thank you for this instructable, it helped me soooo much.
Dec 20, 2008. 10:06 AMgwtnz says:
For those of you who want to get a bit more industrial / some other ideas what to do with it, check this model railroading link out: model railroading resistance soldering and this one that it's based on: Don Thomas resistance solderer
Btw, won't the sharp turn-on, turn-off power changes affect the PSU? Can't imagine that's too good for it, but hey, if it survives ok, it's a pretty neat hack!
How about some kind of momentary push button on the handle to make the prongs live, instead of a foot activated thing?
Also, the thin glass slides used for microscopes might be a useful substitute for the plexi / mica; don't know. Not sure how it would do for the heat aspect.
Dec 18, 2008. 4:17 AMKoil_1 says:
This is one of the sweetest ideas I've seen so far. I did things a bit different though. I took the bit out of a soldering gun and replaced it with contacts and some old carbon ark lamp rods I had. I carved them down with the Dremel and used automotive hose clamps to secure them to the posts. After cutting the slivers of carbon things were a bit messy. In hindsight I probably should have cannibalized a couple #2 pencils. The thing is this gives you a high amperage, low voltage source with a switch in it's own neat little package. I was impressed that it worked so much better than the Cold Heat that I got for Christmass last year. Thanks for the instructable! It's a direction I might not have otherwise taken...
Dec 12, 2008. 9:37 PMEstwald says:
Instead of Plexiglas why not unglazed ceramic ? The little pieces used in 2 pin halogen lamp sockets come to mind. A little work with a Dremel and a silicon carbide grinding point would make the grooves easy.
Dec 12, 2008. 12:12 AMZha says:
What a great idea! Mechanical pencil cartridges have many of the features that you're building into the tip with those random bits of material, including a reliable graphite handling and dispensing system and are often made of insulating material. They often come with a metal cylinder at the tip, to which you could easily solder +5 and ground. Mounting two such devices on the body of a drafting compass would provide a way to adjust and fix the tip width.
Dec 11, 2008. 11:24 PMkool_ass says:
wow, nice instructable. can i use the graphite lead of ordinary pencils, not the thin refills? I'm a klutz and so, a thicker lead might do the job for me. thanks
Dec 12, 2008. 4:28 AMsalec says:
Carbon-Zinc (cheapest, "ordinary" kind of batteries) AA batteries contain carbon rods ( + pole of the battery ) which can be sharpened with common pencil sharpener. So...now that you know that, don't just throw them into garbage when they are depleted. On a side note, Zinc (battery body) is also a precious industrial resource, so, you may want to collect that too!
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:photozz
