DIY Collapsible Shelf
1,202
23
5
Posted
Introduction: DIY Collapsible Shelf
Make this DIY handy collapsible shelf
Step 1: Cutting the Wood
We have taken 3 12mm ply wood of a suitable dimension ( 3ft * 10 inches sample which we took) , filed all the edges properly so that we a get a smoother finish
Step 2: Metal-criss Cross
Step 3: Grooves
We had taken iron sheet and made 16 L-brackets were made using the milling machine and drilled holes and grooves accordingly and the screw was fitted
Step 4:
Step 5: Painting the Shelf
The shelf was painted using an enamel which was left to dry for a day and then any colour of the user's choices can be applied.
Step 6: Assembling and Oiling
The metal parts of the shelf are oiled and and the entire shelf (along with a cloth hanger is assembled)
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
5 Comments
use with caution, scissor design very hazardous. there's a reason you don't see that design around much without lots of safeguards.
How is a scissor lift dangerous?
Hold and lift the plank and not the scissor parts.. it wont cause any problem then?
also, gloves, glasses, faceshield. plastic can melt/catch fire easily from sparks. sleeves down,it will block and absorb a broken disc better than raw skin. proper shields walls i think there's some instructables out there for that.
That's a great way to make it save space when not in use :)
