DIY Concrete Coasters
Published
Introduction: DIY Concrete Coasters
About: Hey, I'm Muhaimina! A crazy craft addict! Obsessed with swirls and polka dots... Love green craft and rustic home decors... and Instructables is pretty much my second home!
After making the concrete planters I had some concrete mix left but they weren't enough to make another planter so I had to come up with an idea to use them. As soon as I saw the small flat bowl set in the kitchen I thought of making a concrete bowl but ended up making 3 concrete coasters!
You can make these coasters easily in no time, even if you're not an expert in concrete and casting.
Step 1: Materials Needed
To make concrete coasters you'll need:
  1. Concrete mix or cement (and sand),
  2. Mold - small flat round object,
  3. Bucket for mixing the concrete or cement,
  4. Rubber gloves,
  5. Polythene paper,
  6. Fabric paint and paint brush.
Step 2: Mixing Concrete or Cement
Measure 2 parts cement and 3 parts sand.
Mix them very well,
Pour a small amount of water into the sand and cement mixture and mix them well with the water,
Pour more water if the cement mixture is too thick. But keep in mind not to make the mixture too thin or too thick.
Step 3: Preparing the Mold
I used small flat bowls for casting but you can use any shape or object as the mold. You just have to keep in mind that the thickness of the coaster should be between 1-2 cm.
To prepare the mold you'll need the flat object (with depth between 1-2 cm) and polythene sheet,
Cut a piece of polythene sheet, double the size of the flat object,
Place it on the flat object. Using polythene sheet will make it easier to remove the dry concrete, more precisely the polythene sheet will work like a mold release.
Step 4: Filling the Mold
Carefully pour the concrete/cement mix into the mould,
Make sure to fill 1-2 cm (depth of the mold) of the flat object.
Less than 1 cm thickness might crack and more than 2 cm thickness will make the coaster too heavy.
Allow the concrete to dry overnight (for at least 24 hours).
Step 5: The Concrete Coaster
After the concrete or cement dries you can easily get it out of the mould.
The flat surface of the concrete is the bottom of the coaster,
You can use sand paper to get a smooth bottom and it'll be better if you add a layer of felt on the bottom of the coaster.
Turn the moulding upside down and remove the polythene sheet.
Step 6: Designing the Coasters
You can use fabric paint to design the coasters.
I used black, red, white and golden fabric paint and did tribal designs on them.
After painting allow the paint to dry.
There, you have a set of artistic handmade coasters ^_^
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    24 Discussions
    i've just made some coasters with excess concrete mix from another project. i may sand/paint them when i have time.. thank you for sharing.!!
    Are these gonna hold the condensation drips? At the angle of the coaster, I'd say no... Now what? Cute and well painted, but not functionable me thinkest .
    Great job! I love the painting! :) Btw how well does the glass stay on them? I would be a little scared, that it could slip away (because you don't know how "handy" I am :D)
    Thanks so much! The glass stays on them quite fine. Well, in your case I think it's better to keep the top surface of the coaster completely flat :)
    Nice design,
    I would probably add felt to the bottom so the wont scratch the table tops
    Cool idea and you really pulled it off! The finished coasters look great. Nice documentation!
    How cute! I agree with Tarun, you are so good at painting...I have yet to find a design you made that I don't like, seriously! :)
    Love this!! Those designs make it look so awsome!!
