Copper is a really good looking metal. It's rarely used for domestic applications, such as light fixtures. Almost everything, that is made out of metal these days is made out of stainless steel. I'm tired of it, so I thought: why not make something different. Something unique.
This instructable will show you how to make a very energy efficient and unique light fixture for illuminating your paintings or photographs.
I will also show you how you can make it light sensitive, so that it automatically turns on at night.
Remove these ads by
Signing UpStep 1Materials
- A copper tube. These are widely available. You can get them at Home Depot and other stores that sells plumbing supplies. They're available in many different diameters. Try not to get one, that is too thin, as it will make it difficult to wire up the LEDs. The one I used was 1.5 centimetres (0.59 inches) in diameter, and I don't recommend using a smaller diameter than that.
- LEDs. For this type of project, you'll definately want warm white LEDs. The normal white or cool white LEDs will often be more bluish in their light, and you don't want a bluish light on your painting or photograph. In the next step, I'll show you some of the many LED possibilities. The quantity depends on your needs and the length of the tube. I used 9.
- Some enemaled copper wire a.k.a. magnet wire. It's a good idea to use two different diameters, so you can easily identify the polarity.
- Resistors. The quantity and value depends on the type of LEDs and how many you use. I will show you how to calculate the value of the resistors in step 3.
- Two screws for mounting your fixture on a wall. Brass screws are the preferred ones for this project, because they almost have the same color as the copper tube.
- Some hookup wire to connect it to your power supply.
- Some thinner hookup wire to connect the two ends of the tube together.
- Heat shrink tubing. You'll need different diameters of it.
- A sheet of ordinary paper.
http://www.google.com/#hl=en&q=quantum+tunneling+transistor&aq=f&oq=&aqi=&fp=F2LdvTVQwLA
Me, I'm more the old fashioned bipolar type though :) Those work on PN junctions and migrating electrons and holes. Just wait until you're checking out characteristic curve traces of those puppies. Switching is pretty dull stuff. Yawn, I'm all about analog myself.
http://www.google.com/#hl=en&q=transistor+curve+tracer&aq=f&oq=&aqi=g1&fp=F2LdvTVQwLA
Then there are different ways of using a transistor in a circuit.
One way:
http://en.wikipedia.org/wiki/Common_collector
Short answer to a screwy question though a small current controls a larger current flow.
jay ess
http://importantless.com
The LEDs that I used has a cost of 11.49$ for a pack of ten (they're cheaper if you buy them in larger quantities)
The auto turn-on switch cost around 10$ to make in parts (not shure, since I already had most of the parts)
Resistors 1.5$
I don't know the price for the rest of the parts, since they were purchased a while ago, but they aren't overly expensive.
