DIY Custom Gun/Book Vault
3,960
6
Posted in PlayOffbeat
Introduction: DIY Custom Gun/Book Vault
About: I'm a 19 year old techie who likes to fiddle around with all types of DIY! I prefer to stick to less technical hacks and projects. Things like invisible book shelves or DIY-aftershave!
Here's a fancy instructable on how to make those fancy books that have guns in them like in the movies!
Yes, exactly like THIS MOVIE>> [Couldn't find a picture of one of those fancy books with guns in them. So, lets pretend! :D ]
Anyway, this is a "work-in-progress" instructable. As I decide how to cut and bind the book I'll edit this instructable with those pictures/instructions.
At the completion of this instructable, you will have a seemingly harmless book that actually contains a powerful home defense weapon.
Step 1: Measuring the Book and Gun
When selecting the book you're going to use, make sure to measure very carefully. The book should be wide enough to allow your gun to lay comfortably flat and be "deep" enough to allow adequate coverage of the weapon inside. Also, used book shops or your grandmothers library are a great place to look for old, thick books. Look for encyclopedias, pill manuals, etc, etc. Not a Bible! LOL
For this project I measured the width, length, and depth of both my book and my gun. In this case, an American made Hi-Point CF380.
This was, as stated earlier, to ensure plenty of room for the gun to sit flushly in the book.
Step 2: Tracing the Gun and Magazine
 Lay the gun in the open book a couple of hundred pages in. For my book, I chose the 380th page ;)
My book already had wide margins around the words that gave me ample room to cut (in a latter step) without making the walls of the vault too thin.
Make sure that you have your clip in your gun if you EVER want to store the gun in this position as sometimes the clip will protrude or add on to the length of the grip as mine does.
Also, make sure the magazine has at least one round protruding from the top if you ever plan on storing the clip with rounds. This is also due to the fact that rounds may protrude from the top of the magazine.
Once you've placed the clip in the gun, lay it carefully on the thickest part of the book and trace around your weapon. DO NOT Trace ridiculously close. If you do, then in the event that you need your weapon, it will be so tightly wedged into the book that it can not be removed in an adequate amount of time.
Now remove the clip (or use a spare if you have one) and load it with a single round protruding from the top. Lay it however you see fit, on the pages parallel to the gun and trace around it. Once again, DO NOT Trace ridiculously close.
Once you have your lines drawn, you may begin cuttting!
[THIS INSTRUCTABLE IS NOT FINISHED. I WILL UPDATE IT AS I CONTINUE THE PROJECT! CHECK BACK THE 20TH OF MARCH (2010) FOR AN UPDATE ON HOW TO CUT YOUR PAGES!]
Thanks for reading,
-McAfee15
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    3 Comments
    It's currently August 2013. Ummmm.. someone's over three years late.. o.O
    This needs to be pulled. 3 years latter and still not finished. This isn't an instructable, it's just an idea for one. Since the peoject is barely started and gives no info on how to finish it, it needs to be pulled since obviously the author is not going to be completing it.
    "[ THIS INSTRUCTABLE IS NOT FINISHED. I WILL UPDATE IT AS I CONTINUE THE PROJECT! CHECK BACK THE 20TH OF MARCH (2010) FOR AN UPDATE ON HOW TO CUT YOUR PAGES! ] "
    A year later and...??????
