DIY Custom Make Up Brush Handles
3,821
32
7
Posted
Introduction: DIY Custom Make Up Brush Handles
Hair and Makeup Contest
Third Prize in the
The following is how to create custom makeup brush handles for when they break or just look ugly to start with.
Step 1: Tools, Materials & Supplies
-Your choice of wood (I chose Wenge and Maple for this one)
-Quick drying epoxy
-For this brush I used two different woods so I had to glue the pieces together but otherwise I wouldn't need it
-Some type of brush (I typically pop the top off of a cheap one with a bad handle and replace it)
-Wipe on or some other type of Polyurethane (This helps to protect the wood and make the brush handle last much longer and for countless washes)
Step 2: Roughly Sketch & Pull the Brush Off the Handle
-Make a sketch of your desired handle
-Pull the brush head off of the original handle. This is easily done by hand with some wiggling like its a tooth.
-Measure the depth of the make up brush head to determine what size tenon your new handle will need.
Step 3: Measure and Cut to Length
-Figure out how long you want your brush to be
-Then cut it to length (be sure to cut it a little long for the lathe)
Step 4: Glue Up
-Glue the pieces together using a water proof glue such as Titebond III or other
-Clamp or secure them (If you don't have clamps you can certainly use a big book or some rubber bands)
Step 5: Mark Center & Lathe
-Find the center of your brush blank then drill a slight hole to attach it to the lathe with a spur center
-Then lathe away
-Once you've made the correct shape sand the handle smooth (I went up to 240 on some and 800 on others)
Side Note: If you don't have a lathe (this one was only $150 dollars) or you certainly could file and sand down the blank by hand. Such as in my Hatchet Handle Instructable.
Step 6: Finish With Polyurethane
-After some trial and error I found that wipe on Polyurethane isn't as shiny as it could've been so I took a can of semigloss polyurethane and didn't shake it. I repeat DO NOT SHAKE IT.
-Then just dip it in trying to avoid the bottom of the can.
Suggestion: You can avoid this by just buying gloss instead of semigloss polyurethane. I also encourage you to seek out and try other finishes as well as materials.
Step 7: Epoxy on Brush Handle
-We used 5 minute epoxy but you can use any type of epoxy. I'm not so sure I would trust superglue here.
-Make sure you tape up your brush so you don't get epoxy on the handle.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    7 Comments
    you've an interesting portfolio hatchet handles and makeup brushes. Cant wait to see what you do next. cheers
    congrats on becoming a finalist xx
    Thanks. They were a ton of fun to make
