DIY Custom Matt Black Macbook Pro - Plasti Dip
16,174
171
13
Posted in TechnologyApple
Introduction: DIY Custom Matt Black Macbook Pro - Plasti Dip
Macbook pro retina display with Rust-Oleum Peel Coat (Like Plasti Dip)
1) Mask off ports
2) Clean Surface
3) Sprayed five coats of Peel Cost ( More = Thicker finish)
4) Peel off logo
5) Allow to dry for 24 hours
Step 1: Mask Out Ports
Step 2: Clean Surface.
Make sure it is spotless
Step 3: Shake Plasti Dip / Peel Coat
Step 4: Paint
Start with a very light coast and build up.
1 coat every 10-15 mins
I did a total of 5 coats
Step 5: Remove Making Tapes
Remove masking tape and paper before paint drys and sticks to the macbook
Step 6: Peel Off the Logo
Peel off the logo 10-15 minutes after the last coat.
Step 7: Allow to Dry for 24 Hours
You can start using it but if you want it to last longer allow it to dry for 24 hours before using your computer
    • Pocket-Sized Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    13 Comments
    :) the paint just peels off, that's why I took the risk
    But if it just peels off, then won't it start peeling off as you open and close it a lot and all that? Seems like it would just start looking junky after a short time.
    brilliant idea! have you peeled off the paint to verify that it hasn't stuck to the surface? My wife and I have identical macbooks for work and we've gotten them switched up before. I want to try this asap!
    You should make a video if you already haven't!
    Thanks! I have made a quick video and its on the top of this page.
    Did you need to cut the paint around the logo or anything like that? What kind of tool did you use to peel off the logo paint?
    you can use your fingernails or a blunt pencil
    Hi,
    Since this is a peel able paint you don't have to worry about masking the logo. The logo is slightly indented and the plasti dip creates a separate layer which you can easily rip off. But make sure you peel it off before it drys fully
    This is a really cool idea! I would have never thought to do this!
    Great idea! I might do this for my laptop.
    Try it! and if you dont like the results you can alwys just peel it off! :)
