3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Custom Picture Frames
Avoid the high prices of buying custom frames by making your own. Its easier than you think.
Step 1Introduction
Nothing helps improve the appearance of a photograph, drawing, print or other artwork than a good picture frame. Frames are available in some standard sizes, however often what one wants to frame does not fit in a standard frame. Many would have you believe that creating a custom frame requires arcane skills that only a select few can do, and they charge accordingly.
This tutorial shows how one can create their own custom frames to show off your works of art, and save a good deal of money in the process.
Some of the pictures in this tutorial are way out of focus but they still get across the meaning. I'll update them next time I make a picture frame.
16 comments
Jun 19, 2010. 1:23 PMgeorgem21275 says:
Cool frame work! At this point in the process I like to glue a sheet of paper across the back of the frame to help prevent dust from finding it's way in.
May 21, 2010. 8:33 AMnancyamy says:
Please--the term is "rabbet." You'd normally do this with a dado cutter.
Dec 30, 2009. 1:33 PMtmsmalley says:
You can help keep the metal straight edge from moving around (and messing up your cut!) by fastening squares of coarse emory cloth (cloth sandpaper) to the straightedge's bottom with some double stick or 3M ATG tape. If it's a long straightedge, tape it and the matt board to be cut to the work surface with some blue masking tape. It takes a couple of extra minutes, but saves messing up a $10 piece of matting with a croked cut.
And believe me you WILL notice that goof every time you look at the picture.
Jun 13, 2006. 4:02 PMjustbesimple says:
i've been thinking about making my own frames for a while - now i don't have any excuse. thanks!
May 25, 2009. 1:32 PMkaelaria says:
www.americanframe.com has awesome prices, gives the mounting board and cut mat board free for anything non-clearance. Save the trouble and get something that will actually function. Unless you buy the materials in bulk you can not do it cheaper at home unless you just want absolute crap for useless stuff you are framing like kids stuff. Walmart, JoAnnes and Michaels also regularly have complete frames for $5-$30 up to 24x36.
Oct 4, 2009. 6:21 PMTinkerbell2 says:
Awww, now haven't you just got the sweetest way with words! I happen to like the 'crap useless stuff' of my child's art/photos. Also, this instructable WILL actually 'function' (weird word to use since is has no moveable parts, not electronics). If you want to promote americanframe, put an add in the paper. Have a little more respect for the publisher of this instructable. And finally, read the comment policy.....Be positive and constructive with your comments.
Jun 25, 2009. 4:03 AMStoryAddict says:
I concur with longouyang. I'm going to try and copy/paste to notepad and clean it up to read. sad day :/
Jun 15, 2009. 12:19 AMlongouyang says:
the html formatting doesn't seem to work here, and makes the page kinda hard to read.
May 7, 2009. 10:56 AMheybeachnik says:
"Rabbit" is a small furry animal. When you're writing instructions like this, it's important to spell words like 'rabbet' correctly.
May 2, 2008. 5:41 PMArtLover19 says:
Another alternative that may turn out to be most cost efficient is to purchase a custom frame online. A site like www.CustomFrameSolutions.com offer near wholesale prices on solid wood custom frames (i.e. starting at $0.29 an inch). Cost varies by moulding style and width. They chop, route, and wedge your custom sized frame and FedEx it free the next day. Make you own frames if you enjoy doing it, not if your sole purpose is to save money. Once you factor the cost of materials, storage, tools, waste, your time, and the occasional goof up; the cost is actually quite high.
Apr 28, 2006. 2:00 PMredgren says:
How'd you do this rabbit cut? Router? Table saw?
May 18, 2007. 6:31 PM3sidedorchid says:
You've given very clear directions, and it's nice to see the awknowledgement that something should be done to protect the image from the acid in the framing materials -- but the acid free paper used is hardly going to do anything against the high acidity materials used here. A fully protected image should have a 100% acid free mat, tape and backing (both the backing paper and the backing board), plus a metal acid free tape lining along the frame interior to prevent the acid in the wood from seeping into the image. I know you didn't claim it would last forever, I'm just pointing it out so people are aware. (if you did want it to last forever, you'd have to add uv protective glass). I also think it's pertinant to mention that anyone with a work of value shouldn't use this method b/c there's glue used on the picture. Acid-free or not, the moment any adhesive touches an image (with the possible exception of archival quality linen tape, which is fully removable) you've decreased the image's value. You don't mention how much the materials cost -- but if it's anything over $130, you've paid more than you could have custom framed the image shown for -- with better materials and higher quality (I say that b/c personally, I'd have to buy a lot of the tools to complete the project as instructed).
Aug 30, 2006. 11:36 PMfrugalmurphy says:
My daughter's 14, and draws and paints beautifully. I have had her drawings framed when I could, but it's very expensive. Your directions are very clear, and I'm going to attempt to do this. I'll keep you posted. Thanks so much!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:paperrhino
